Results 21 to 24 of 24
12-08-2012, 08:52 AM #21Platinum Member
- Join Date
- Sep 2010
- Posts
- 632
- Location
- Eastern Ontario
- Tractor
- Kubota MX5100
Re: raising trusses for pole barn
I did this by myself for 12' walls on my garage using a 'man lift'. Reason I didn't rent a heavy duty forklift was the distance from the rental place. I could easily attach the man lift to my truck and get it home. My trusses were 'attic trusses' with a 12/12 pitch so I had to get quite high and let me tell you, I won't do it again. Took me a weekend to do it and the last few, especially the ladders were a real pain. I would rent a crane next time and get another couple guys to help. Installing trusses by yourself is challenging.
2011 Kubota MX5100, BH92, BH BB72, Walco Bush Hog and Snowblower, Wallenstein 310 Splitter & Forks
12-08-2012, 01:28 PM #22Elite Member
- Join Date
- Oct 2006
- Posts
- 3,238
- Location
- N.E., Ohio
- Tractor
- GC2310, Toro Reelmaster 5100D
12-08-2012, 03:10 PM #23
I was kind of thinking the same thing. I own a 35' tow behind boom lift, but have never used it to set trusses. The bucket capacity is only 500 lbs., so I guess it would depend on the weight of a couple of guys plus the truss.
If that wouldn't work I'd suggest a snorkel type lift. I'm thinking much more weight capacity. Fasten the truss to it, have a couple guys in the basket and a guy on top of each wall to follow your layout marks and make sure it's OK for side to side fit.Todd
_____________________________________________
"The trouble with quotes on the Internet is that it's difficult to discern whether or not they are genuine." --Abraham Lincoln
2008 Bobcat S185 Skid Steer with enclosure, heat & A/C • Erskine model 2010 73" blower •TSC Boom Pole adapted to QA • Bradco 48" pallet forks • JLG T350 Boom Lift • 1997 Ford F Super Duty 7.3 Powerstroke w/ Altec AT 200A aerial lift • CAM Superline 6x12 dump trailer
12-08-2012, 03:45 PM #24
I used my 65 MF with a telescoping boom on it for 12' high walls and had 4 helpers, it went very fast.I think the boom might have been designed for a 3 pt. hitch but I put it on my front end loader. I borrowed it from a guy at work.
Similar Threads
Steel Trusses Pole barn
By Ledgbro in forum Build-It YourselfReplies: 4Last Post: 03-18-2012, 01:33 PM -
raising pole barn posts
By acausey1 in forum ProjectsReplies: 15Last Post: 03-12-2010, 12:28 AM -
Trusses for a traditional style barn?
By Limecuda in forum ProjectsReplies: 12Last Post: 01-11-2008, 09:28 PM -
Boom Pole for Setting Trusses (check out the pics)
By SteveCornell in forum AttachmentsReplies: 5Last Post: 10-31-2005, 11:18 AM -
Pole Barn Trusses
By Mark_in_IN in forum ProjectsReplies: 10Last Post: 08-21-2004, 12:32 AM
