Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Aug 2012
    Posts
    15
    Graham, WA
    John Deere 1530 Diesel
    Default Drag Link/Tie-Rod Installation Tip
    Most folks already have this figured out but a installation tip for installing tie-rod ends/drag links is to use three jamb nuts. I had a problem getting the taper portion of the tie-rod to seat and not spin. Use one thin jamb nut next to the steering arm to pull it down and use two jamb nuts on the end bound against each other at the end of the threaded portion and use a wrench there to keep the tie-rod end from spinning. I had to use this procedure when I installed a new steering drag link on my JD tractor and the threads on the new part were metric (?#%@!? on a JD replacement part?) and it was not drilled for a castle nut, it came with a nylon locknut. The drag from the nylon locknut would spin the tie-rod and it would not seat. So a trip to ACE and 4 jamb nuts later I had the pins installed. I left the one jamb nut that pulled the pin down installed (so I could remove the locknut later if needed) and just put the locknut over the top of it.
    Another tip that works like anti-seize and a lubricant is to use a little latex paint on the threads of the bolt. Paint/dab/dip the end of the bolt with latex paint and spin on the nut and torque. It dries on the threads keeping them from rusting, helps hold the nut in place, lubricates the nut as you torque and is soft enough later to not impede the removal of the nut. DO NOT use enamel as it dries too hard and can make removal later a pain.
  2. #2
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,169
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: Drag Link/Tie-Rod Installation Tip
    Good tips. Must be a cost savings not to drill the threads for a cotter pin.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
Similar Threads
  1. Steering shaft rod ends and Tie rod ends
    By HiTork in forum Chinese Tractors
    Last Post: 05-20-2014, 11:56 PM
  2. Track rod assembly (tie rod end)
    By kevin3251 in forum New Holland Owning/Operating
    Last Post: 12-10-2011, 06:32 PM
  3. Need a tie rod
    By ktm250rider in forum Parts/Repairs
    Last Post: 05-15-2007, 06:55 PM
  4. CK 25 Tie Rod
    By rmahlert in forum Kioti Owning/Operating
    Last Post: 11-15-2006, 08:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
