Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
  1. #21
    Silver Member heviduty's Avatar
    Join Date
    Apr 2012
    Posts
    156
    central NC
    Kubota L3400HST/LA463 loader JD 318 / 3ph(cat. 0)
    Default Re: Don't let this happen to you.
    The kit has a tap, t-handle insertion tool mandrel. and what I first thought was a tapping fixture to help get the tap started straight, but after reading more online about HeloCoils, I think it is a prewinder.
    Like I said, I have never used Helicoils before.
    Instructions on the package are sparse. From what I gather, the coil is placed in the slot in the prewinder and wound into the tapped hole with the mandrel while holding the prewinder still, is that right?
    Happy as if I had good sense.
    One orange, one green.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #22
    Veteran Member banjodunn's Avatar
    Join Date
    Jun 2008
    Posts
    1,000
    Oz
    G'day the kit should have a tap, insertion tool with collar, and sometimes a tang break off tool ( looks like a straight bit of rod). After you tap the hole put the tang of the helicoil in the slot of the insertion tool ( 'T' shaped handle ) and slide the collar down so the tang cannot sit right in the bottom of the slot as you have to put slight pressure into the hole to get the insert started, if you are pushing on the tang and not the top it is possible for it to jump a thread and give you a bad thread to screw into.
    When you have got the insert just under flush in the hole then take the insertion tool out and get the tang remover tool and put it down the hole until you rest on the tang then give it a sharp rap on the end to break the tang off, if you haven't got a removal tool then you can use the insertion tool just put it down the hole with the slot at 90 deg to the tang and do the same thing. Do not try to wind backwards as you will not break it off that way and you may damage the tool.
    Good luck with it
    Jon Merry Christmas HO HO HO
  4. #23
    Join Date
    Apr 2012
    Posts
    156
    central NC
    Well, it's done. The bolts were ruined. Had a hard time finding replacements. Ended up with 50 mm long instead of 40, so I added flat washers.
    The cast iron was drilled and tapped dry. I stopped every few seconds and blew out the swarf.
    Thanks, everyone, for all your help.
    Attached Thumbnails Attached Thumbnails Don't let this happen to you.-dsc01700-large-.jpg   Don't let this happen to you.-dsc01702-large-.jpg   Don't let this happen to you.-dsc01706-large-.jpg   Don't let this happen to you.-dsc01723-large-.jpg
  5. #24
    Platinum Member sparc's Avatar
    Join Date
    Oct 2011
    Posts
    750
    NJ
    Ford 2600, NH TC-25, Bobcat M610, JD X534, DigIt Model 158
    Quote Originally Posted by heviduty View Post
    Thanks, Jon, I'll look into that. I thought HeliCoil was only for small sizes but I just checked and they go up to 1 1/2" / 39mm.
    But watch out for the price of those helicoil taps when you get over 1".
    You can make an insert tool from a bolt if need be.
  6. #25
    Join Date
    Apr 2012
    Posts
    156
    central NC
    Quote Originally Posted by sparc View Post
    Let's hope we never break anything that big!
  7. #26
    Bronze Member mkow1969's Avatar
    Join Date
    Dec 2011
    Posts
    51
    Newfane, NY
    New Holland T1110
    Funny thing is i just looked at mine the other day and said to myself... I should check those. But then I got lazy and said i'll do it later.
    Thanks for the posting and inspiring me to schedule this for first thing tomorrow morning!
  8. #27
    Gold Member
    Join Date
    Apr 2012
    Posts
    341
    Northern Ontario, Canada
    2012 Kioti CK27HST
    Quote Originally Posted by mkow1969 View Post
    Me too! I will go out first thing in the A.M. and do mine. Wheel nuts, too.
  9. #28
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    5,001
    Northern Vermont
    Never even thought of checking mine but I got a 1/2" Milwaukee 18v impact wrench for Christmas so I went around checking everything. Nothing was loose but it's probably wise to check them every so often.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer
  10. #29
    Join Date
    Jan 2010
    Posts
    1,353
    Piedmont, NC
    Kubota L4610 & BX2230, Farmall Super M, Super A
    Glad your repair worked! Can't tell from your great close-ups but are the diagonal reinforcements running from the top of the loader mount to the front of the tractor still on the tractor? I could see someone removing them to make working under the hood easier, but that would put severe loading on the bracket mount and might explain why they worked loose so badly.
    Attached Thumbnails Attached Thumbnails Don't let this happen to you.-images-006a.jpg
  11. #30
    Join Date
    Apr 2012
    Posts
    156
    central NC
    Quote Originally Posted by Grandad4 View Post
    Grandad4,
    there are no braces going from the loader frame to the front of the tractor, just the two underneath going to the rear end. I don't remember the loader type, but I'll check and see if it should have the front braces also.
    Thanks for the heads up.
Similar Threads
  1. I told them it would happen, but never expected it to happen like this...
    By sandman2234 in forum Trailers & Transportation
    Last Post: 07-20-2012, 04:37 AM
  2. Why does this happen ?
    By Avondale in forum News/Feedback
    Last Post: 01-30-2012, 06:52 AM
  3. Ever had this happen?
    By s78wingrider in forum Chainsaws
    Last Post: 01-04-2011, 09:14 AM
  4. How Did This Happen??
    By hobbyfarm in forum News/Feedback
    Last Post: 09-14-2005, 02:56 AM
  5. How did this happen!!!!!
    By Chris in IN in forum John Deere Owning/Operating
    Last Post: 05-09-2001, 08:16 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
