AJ197816134
The Tier 4 Scare is out there.. But here is my 2 cents on this. DPF and Regeneration is going to be something we are stuck with... However if you look at this point I feel tier 4 other than replacement cost is effective.
You need an engine to burn clean and hot.... Well if you run your diesel over 1800 RPMs you should have no issues, heat is a friend of the DPF> I believe this is why you see some mfg's coming up with smaller turbo style motors, because the engine will run hotter and burn cleaner. On fire apparatus the big scare was DEF fluid, believe it or not in this application the DEF helped the apparatus, they had LESS regen cycles, they worked to eliminate drag on the belt/accessory drive, reduced drag on engines some diesels now have a factory fill of 10w30 HDEO or 5w40
When they were able to work through the revision and criteria of the tier 4 they were able to open the engines back up, provide better fuel consumption numbers and then bring DEF in to cleanse the system per say..
Pick up owners with diesels don't operate or use them to what they are meant to do. I see guys that just drive and run around in them with more problems than those who work their trucks harder, be it towing or hauling. Short trip, incomplete warm up cycles and more lead to problems with ANY regeneration system...
IS there more cost?> YES but the fact of a quieter running, cleaner burning engine is a gain. I love the sounds of the old Detroit 6V 8V engines but were they really good for the environment? I am no tree hugger but I do believe in preserving or placing less impact on what we have now so we have more to enjoy later.
Tier 4 in my recent tractor purchase did not scare me, what scared me was how some companies have you STOP and regen and others you can work through
