Results 1 to 9 of 9
01-01-2013, 09:37 PM #1New Member
- Join Date
- Dec 2012
- Posts
- 19
- Location
- Huber Hts, Ohio
- Tractor
- Kubota BX2200
Kubata BX2200 4-way valve hydralics don't work properly
Hello,
I'm a new Kubota BX2200 tractor owner and I have very little knowledge of hydralics. Mt BX2200 has a 4-way valve joystick-type hydralic countroller mounted on the driver's right side. I have a BX2711 front-mounted quick hitch which has (2) hydro hoses to adjust the up/down pump and a BX2763 snowblade which has (2) hoses to adjust the blade's angle of attack pnmp. All the hoses are connected but their movement is very minimal; both only have about 1/4" to 1/2" of travel. Basically, the blade is currently at a straight 90 degree angle of the tractor and is positioned about 6" off the ground. I can't adjust the blade at a slanted angle or lower it closer to the ground. Any ideas what may be occuring or what I may have done wrong?...
I posted this issue in a different thread but it was buried under a couple pages of dialogue so I figured I'd repost in a new thread.
Thanks for any thoughts or guidance.
01-01-2013, 10:10 PM #2Super Member
- Join Date
- Mar 2008
- Posts
- 6,481
- Location
- Northern Fingerlakes region of NY, USA
- Tractor
- Kubota L3830GST, B7500HST, BX2660
Re: Kubata BX2200 4-way valve hydralics don't work properly
In what order are your hoses connected? On our BX2660 with the BX2763A blade, there are 4 hydraulic connectors in a row. The inner two are for one function (angle?) and the outer two are for the other (lift?).
Aaron ZIf mankind minus one were of one opinion, then mankind is no more justified in silencing the one than the one - if he had the power - would be justified in silencing mankind.
John Stuart Mill
01-02-2013, 06:52 AM #3
Is the joystick locked? There is a mechanical lock to keep the joystick from moving I think-just not sure what it looks like on your Kubota.
John Deere 4110HST
FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
John Deere 4x2 Turf Gator
View some of my projects/adventures in my Picasa Album
Simple JDParts Tutorial HERE
01-02-2013, 07:38 AM #4Gold Member
- Join Date
- Nov 2007
- Posts
- 360
- Location
- PA
- Tractor
- Kubota L3130 HST 4x4
If the BX2200 is anything like my Dad's there is a joystick lock that prevents the handle from being moved if desired. It is located near the base of the lever and flips down from the cover. It has a U-shaped detail that limits joystick travel.
His spool valve and hose set-up did not use quick connects, thereby requiring the hoses to be threaded making changing implements a real pain. I'm guessing the hoses are connected wrong. The hoses for the up-down motion should use the two inner most connections (inner with respect to the tractor) and the two outer used for the angle function.
Perhaps the photo will help. Yellow for the UP-Down and Green for the angle.
Kubota L3130 HST 4x4, FEL LA723 w/QA, Backhoe BH90, L2185 72" front snow blower, 7' back blade, carry all, Pallet Forks w/QA, Sun Shade, Turf tires & Rubber Chains for the winter, Extra forward and rear lighting. BearCat 73454 Wood Chipper. LandPride RCR2672 Rotary Cutter. Approximately 230 hours
01-02-2013, 08:06 AM #5
After reading the first post. first question that came to my mind is are you hearing the relief kick in? if it does then the hoses most likely is connected wrong. The other question that popped up is if this is your first install of the blade, I wonder if the the hoses were empty, and now your HST oil is low?
Kenny is correct- I'd check the lever lock as its the easy thing to overlook. I'd check the hst oil level before starting up to make sure its not low. As for the hoses connected wrong, its possible - is the blade hoses have color tape on them? Do they correspond with thoses on the loader ports?
01-02-2013, 08:36 AM #6Super Member
- Join Date
- Mar 2008
- Posts
- 6,481
- Location
- Tractor
John Stuart Mill
01-02-2013, 01:40 PM #7New Member
- Join Date
- Dec 2012
- Posts
- 19
- Location
- Huber Hts, Ohio
- Tractor
- Kubota BX2200
Thanks aczlan, that was it...it is working perfectly!!!
01-02-2013, 01:44 PM #8New Member
- Join Date
- Dec 2012
- Posts
- 19
- Location
- Huber Hts, Ohio
- Tractor
- Kubota BX2200
Thanks to all the responders for your guidance. I was connected each set of hoses horizontally vs vertically.
My unit also has the U shaped lever to limit travel but that was not the problem. Again, I thank you all for your input...I really like this site! The members here are very helpful!
01-02-2013, 07:57 PM #9Gold Member
- Join Date
- Nov 2007
- Posts
- 360
- Location
- PA
- Tractor
Good to hear it was easy to fix!
Similar Threads
Hydralics only work when a backhoe valve is cracked open slightly?
By Tim Dawson in forum HydraulicsReplies: 3Last Post: 03-07-2010, 10:19 AM -
How does this valve work??
By jgrreed in forum HydraulicsReplies: 9Last Post: 12-22-2008, 10:09 PM -
Kubata L1500 brakes
By chuckinNC in forum Grey Market TractorsReplies: 1Last Post: 04-30-2005, 08:39 AM -
3 PT Attachments That Work With A BX2200
By NY_Yankees_Fan in forum AttachmentsReplies: 6Last Post: 03-20-2003, 01:11 PM
