Results 11 to 20 of 56
01-16-2013, 02:30 PM #11Gold Member
- Join Date
- Nov 2005
- Posts
- 408
- Location
- Colebrook, N.H.
- Tractor
- Kubota L3830HST
Re: Handling Filled Tires
Thanks to everybody for the good advice. Especially the point about taking off the wheel disks. I never would have thought of that. That's a trick you either have to learn the hard way, or learn from an experienced hand. I'm still trying to come to grips with the reality of moving something that heavy, even though it's round. I also hadn't thought of the necessity of using a pry bar to move the tire in and out to line it up.
This might seem like a dumb question, but since you have to swap sides to keep the tread in the right direction, you have set the first tire aside somewhere. I wonder if I could lean it slightly against the wall?
I heard an interesting opinion, that if I was just moving the wheels out for use with chains, you could just pull each rim off and spin it around. The tread direction would now be backward, but supposedly with chains on it wouldn't matter. I'm hoping that I will leave the wheels spaced out once I change them, chains or not, so I wouldn't want to do that.
Still trying to get the courage up to tackle this project. I always prefer to do things myself if at all possible, but sometimes that gets me in trouble. Seems like once the bolts are removed I will have passed the point of no return...-Jim
01-16-2013, 02:45 PM #12Veteran Member
- Join Date
- Aug 2010
- Posts
- 2,041
- Location
- South West MI
- Tractor
- John Deere 2030, John Deere 6415
After you had one wheel/tire off you could remove the center disc and reverse it, bolt it back in the wheel and then put the tire/wheel back on. (If this what you are trying to do) that way the tractor will always have one wheel/tire on, vs pulliing both and swapping side to side.
John Deere 2030 JD 245SL Loader
John Deere 6415 mfwd JD 640SL Loader
01-16-2013, 02:54 PM #13Veteran Member
- Join Date
- Aug 2010
- Posts
- 2,041
- Location
- South West MI
- Tractor
Glad to hear an 18.4-34 loaded is doable. I need to pull the left off my JD 6415 to install a fuel tank guard. My plan is to find out what size the axle hub bolts are and get two more as long as possible and cut off the heads to make guide studs. I am thinking of using a pallet jack and pulling the wheel/tire straight out far enought to install the fuel tank guard.
I have successfully R&R a 16.9-28 that was loaded and had a cast iron center.John Deere 2030 JD 245SL Loader
01-16-2013, 04:52 PM #14Elite Member
- Join Date
- Apr 2012
- Posts
- 2,814
- Location
- Tennessee Vols Country
- Tractor
- My tractor is an old M... F... and red too.
I'm with you on this Rick. Like on a MF135 there are many combinations to bolt the rim to the disk to get the spacing you want. Doing it with the entire wheel off the tractor would be the easiest. I can't imagine trying to line those holes up rim to disk with loaded tires. I'd also suggest positioning the tractor backed up close to a solid wall so when you removed one you wouldn't have far to go to lean it against.. I would also break all the nuts loose ( rim to disc) (wheel to hub) before jacking it up and removing the entire wheel. Leave them snugged but you can exert more forced leverage with the wheel still mounted. Just like you would do an auto wheel.
Retired and enjoying life and my grandchildren -robert
"life is too short.. eat your cake first" ~rpk
My 1965 MF 135 Z145 Refurbish project
About ME
01-16-2013, 05:31 PM #15Super Member
- Join Date
- Sep 2000
- Posts
- 6,256
- Location
- Eastern NY
- Tractor
- Case 885, JD 730D, Oliver 660 Ford 4000
That's about the most dangerous way I can think of to (try to) move tractor wheels. I'll bet that is a keyboard dream that has never been attempted by the person that posted. The darn things are round; they will roll just fine on their own.
When I was doing road service full time I routinely removed loaded 16.9x30's on New Holland tractors by myself to access the transmission control valve. Usually doing this job by myself is easier than coordinating movements with a helper. Not to say having someone around if things go south is a bad idea.If you can read this, thank a teacher.
If you are reading this in English, thank a veteran.
01-16-2013, 07:11 PM #16Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,061
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
yep.. upright.
I'll roll up to 13.6-28 loaded .. if they are larger I 'loader' them into place then move around.
14.9-28 and 16.9-24 are the heaviest i've moved without laoder help.. and both of those were probably too heavy to be safe.. thus my new lower range..
be safe.. and if it starts to go.. let it and jump out of the way.. you can always leverage them up later while you aren't hurt.
01-16-2013, 10:29 PM #17Platinum Member
- Join Date
- Apr 2005
- Posts
- 702
- Location
- Erin, Tenn.
- Tractor
- 2001 Mahindra 4110
Another point to watch is how you jack/block the tractor too. If you do like I did the first time and put a floor jack under the center of the rear diff like you would do on a car or truck and remove the first tire, the weight of the other side will want to tip the whole tractor to that side and could really throw you off balance - it did for me as I did not know the tires I was removing were loaded to begin with. Either use jack stands or blocks on each side if jacked in the center or use two bottle jacks to raise it so it won't tip to one side. Good luck with your chore !!
2001 Mahindra 4110, FEL w/5' & 6' QA buckets & forks for the 5', 6' Atlas boxblade, older 6' Howse rotary, Leinbach 7300 PHD w/9" & 12", MF 2/3 bottom plow, 20"x6' bog disc, KK subsoiler, KK middlebuster, Kubota BL60C 5' tiller, Maschio 6' finish mower.
01-16-2013, 10:49 PM #18
Kubota L4240,Case 580K backhoe, Case 450 Dozer
01-16-2013, 10:55 PM #19Elite Member
- Join Date
- Apr 2012
- Posts
- 2,814
- Location
- Tractor
About ME
01-17-2013, 08:24 AM #20Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,061
- Location
- Central florida
- Tractor
yeah.. side to side..
and deffinately DO use plenty of cribbing and jack stands.
DO NOT rely on a single jack pont in the rear!!!!
Similar Threads
Tires Filled tires?
By dayrunner in forum Owning/OperatingReplies: 18Last Post: 06-10-2012, 07:54 PM -
Tires Filled tires or not?
By sqdqo in forum Owning/OperatingReplies: 6Last Post: 09-19-2009, 01:23 AM -
Tires How are tires filled?
By yekrut in forum Owning/OperatingReplies: 11Last Post: 06-24-2007, 12:42 AM -
Tires Handling Liquid-Filled Tires
By Ortis in forum Owning/OperatingReplies: 16Last Post: 03-25-2005, 12:56 PM -
Getting Tires Filled??
By Anonymous Poster in forum Kubota Buying/PricingReplies: 1Last Post: 03-04-2003, 05:40 AM
