Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 56
  1. #31
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Default Re: Handling Filled Tires
    Quote Originally Posted by crazyal View Post
    The Kubota tires, at least the 40 series, mount to the center disc differently.
    Attachment 298098
    A little different design from the LS but the same principle. Kubota has one bolt whereas my LS has two bolts holding the rim, plus the LS is solid all the way around the rim with the S turn in and out continuously rather than just a single little lug. Install the center hub on inside or outside of the connection on the tire rim to change track by 2" per side. Flip the rim to move 4+ " per side. Your's looks to be at max width now.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  2. #32
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    Attachment 298098
    It is obvious from your photo that if the center disc were as they are in this photo, they were already flipped to cup outward. Most tractors are installed with the cup in and the tire installed as you now have yours depicted. THis is why most folks have to flip the center disc rather than remove the outside hub.
    Trying to get that bolt back in the rim from the inside and put an nut on by yourself must have been a real bear, I know it was on my LS front tires when I had to swap the rim lugs from outside to inside and it was only loaded with air.
    I just removed and replaced both tires on my Kubota B26 this morning looking at the hydraulic relief valve and strainer. It took about 2 minutes to remove the lug bolts using my Harbor Freight 3/4" impact, pull the tire, then 5 minutes of looking at the PRV and determining that I couldnt work on it with what I had then not more than 5 minutes to reposition and mount the tire. It is only a 12.4x16 R4 and not loaded but I didnt lift it, just rolled it and raised or lowered the tractor as needed to get the bolts aligned, tightened the nuts which snugged and centered the other lug bolts. Then tightened them with the impact and all done. Of course having the backhoe stabilizers made quick work of lifting and lowering.
  3. #33
    Gold Member
    Join Date
    Nov 2012
    Posts
    442
    mansfield,Il
    john deere
    Yes definitely get a helper if you are the least bit in doubt . They are very heavy and if they decide to go you are not going to stop it . Make sure the floor is clean and dry . no slick spots or trip hazards .
  4. #34
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,066
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    yep.. plan your path.. and have an escape route!
  5. #35
    Elite Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    4,701
    Northern Vermont
    Quote Originally Posted by Gary Fowler View Post
    The Kubota manual has three positions for adjusting the width. The center discs can't be reversed without the tire rubbing on the inner fender. The inner most position has the tire with the valve stem facing in. The next position is having the valve stem facing out but the disc on the outside of the brackets on the wheel. This is slightly, maybe an inch wider, than the inner most position. I have my wheels set in the widest position (as seen in my picture), the valve stem facing out and the disc on the inside of the brackets. To go from the innermost to outer most position requires the wheels to be swapped side to side. To go from middle position to the outermost would require the center disc to be removed from the tractor and the wheel so it can be mounted to the inside. Simply looking at where the valve stem is, facing out or in, should tell you if the wheels are in the innermost or middle position. Mine were set to the innermost when I got it.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer
  6. #36
    Gold Member
    Join Date
    Nov 2005
    Posts
    408
    Colebrook, N.H.
    Kubota L3830HST
    Well, I finally did it! Got my wife to help me move the tires and got them swapped side to side. I took the advice about taking off the disks with a grain of salt, and loosened the lug nuts and bolts just in case, but I tried removing the rims from the disks first. The tires were too heavy to slide, even with a pry bar, and wiggling them back and forth was going to take forever until the rim would clear the disk, so I put a couple rim bolts back in and removed the lug bolts and nuts. Using the bottle jack I could get the height just right to rock the wheel free. Then we carefully rolled the wheel back and forth until it cleared the hub and we could roll it clear. We then switched around the disk on the wheel, set it aside and attacked the other one the same way. Getting them back on went well, by raising and lowering the axle with the bottle jack until we got them hung on the lug studs, and we were home free!
    Thanks again to all who offered suggestions and encouragement. I really wanted to do this myself, and I was 95 percent sure I could, but the weight of the tires made me think twice about it. Having it in the garage, with a smooth floor helped a lot. I wouldn't have wanted to be rolling those tires on rough ground.
    Now to get some chains!
    -Jim
  7. #37
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    2,823
    Tennessee Vols Country
    My tractor is an old M... F... and red too.
    Default
    I'm glad you had some help. As you well know now, they are a handful. Always best to be safe than sorry. - robert
    Sent from my iPad iOS 6.01 - TNB v1.6
    Retired and enjoying life and my grandchildren -robert
    "life is too short.. eat your cake first" ~rpk
    My 1965 MF 135 Z145 Refurbish project
    About ME
  8. #38
    Join Date
    Mar 2002
    Posts
    42,066
    Central florida
    glad you got help.
    if nothing else.. it's someone to call 911 for you ( NO JOKE ).
    i always tell my wife if I'm going out to work on something that could pin me..e tc.
  9. #39
    Join Date
    Jan 2009
    Posts
    1,514
    Rushville, Ohio
    Massey 180 Diesel
    That's exactly one of the reason's I put this up in the new shop. Have my self spoiled with the one I put in my other shop, and not going backwards now.
    I pulled the rears on my Massey 180, loaded 15.5 -38's, along with the spin-out rims, and center cast hubs all in one piece, one at a time, with a chain hoist on a trolley. Then rolled it away from the tractor, out of harm's way. Then brought another hoist on trolley in place to remove the axle housing. Oh soooo sweet.....!!
  10. #40
    Join Date
    Mar 2002
    Posts
    42,066
    Central florida
    nice shop!
Similar Threads
  1. Tires Filled tires?
    By dayrunner in forum Owning/Operating
    Last Post: 06-10-2012, 07:54 PM
  2. Tires Filled tires or not?
    By sqdqo in forum Owning/Operating
    Last Post: 09-19-2009, 01:23 AM
  3. Tires How are tires filled?
    By yekrut in forum Owning/Operating
    Last Post: 06-24-2007, 12:42 AM
  4. Tires Handling Liquid-Filled Tires
    By Ortis in forum Owning/Operating
    Last Post: 03-25-2005, 12:56 PM
  5. Getting Tires Filled??
    By Anonymous Poster in forum Kubota Buying/Pricing
    Last Post: 03-04-2003, 05:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
