Page 5 of 6 FirstFirst ... 23456 LastLast
Results 41 to 50 of 56
  1. #41
    New Member
    Join Date
    Jan 2013
    Posts
    2
    Duvall, Wa
    bobcat c235
    Default Re: Handling Filled Tires
    Well, I'm new here but here goes my first post. The solution is easy. You buy another tractor to move the tires on the other tractor. :-)
    Not being a stranger to moving heavy tires (we have a m35a3 2 1/2 ton truck), I have found a come along to be one of your best friends. that, and a ceiling strong enough to hold the weight of the tires. and that come along is just so handy for so many other things!
    Jerry a.k.a badmastard.
  2. #42
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    2,010
    Rochester, MN
    Kubota BX2230
    I like your thinking BadMastard. A second tractor is the ideal solution!
    Welcome aboard!
  3. #43
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,214
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    "Only" a second tractor...????
  4. #44
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,772
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Quote Originally Posted by DJ54 View Post
    he's slackin'..
  5. #45
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,901
    South West MI
    John Deere 2030, John Deere 6415
    With FEL and pallet forks
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  6. #46
    Join Date
    Sep 2011
    Posts
    2,010
    Rochester, MN
    Kubota BX2230
    That's only a minimum, not a maximum!
  7. #47
    Gold Member
    Join Date
    Nov 2005
    Posts
    491
    Colebrook, N.H.
    Kubota L3830HST
    All kidding aside, I wonder how that would work, to bring a tractor up to the side with forks, grab it and back up, set it aside and grab the other one. Couldn't do it in the garage, it would have to be out in the open with room to maneuver. Seems like it would still be dicey to keep that tire upright with the forks under the middle of it. I think the flop-over factor would be huge. Unless you put the forks together and picked it up from the inside of the wheel. Anyone ever done that?
    -Jim
  8. #48
    Join Date
    Mar 2002
    Posts
    52,772
    Central florida
    i've used a tractor with a loader to shuttle tires right up to the hub and then use a prybar to walk it off the loader bucket and lean against the hub
  9. #49
    Join Date
    Mar 2002
    Posts
    52,772
    Central florida
    i had to swap some tires off this rowcrop and put new ones on ( ouch$$ ) on some different ones after some rim repair and a new brake drum... loader cam in handy.
    Handling Filled Tires-a33127-jpgHandling Filled Tires-a33126-jpg
  10. #50
    New Member
    Join Date
    Jan 2013
    Posts
    2
    Duvall, Wa
    bobcat c235
    Oh. I hung mine by the loader bucket on a come along. On the deuce that is. But forks would work too I think. :-)
Similar Threads
  1. Tires Filled tires?
    By dayrunner in forum Owning/Operating
    Last Post: 06-10-2012, 07:54 PM
  2. Tires Filled tires or not?
    By sqdqo in forum Owning/Operating
    Last Post: 09-19-2009, 01:23 AM
  3. Tires How are tires filled?
    By yekrut in forum Owning/Operating
    Last Post: 06-24-2007, 12:42 AM
  4. Tires Handling Liquid-Filled Tires
    By Ortis in forum Owning/Operating
    Last Post: 03-25-2005, 12:56 PM
  5. Getting Tires Filled??
    By Anonymous Poster in forum Kubota Buying/Pricing
    Last Post: 03-04-2003, 05:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
