Page 16 of 47 FirstFirst ... 61314151617181926 ... LastLast
Results 151 to 160 of 468
  1. #151
    Super Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    Default Re: BACKHOES LETS SEE THEM
    Quote Originally Posted by fordoutback View Post
    Here is mine. A Bradco 485. I have a 10" and an 18" bucket. Hopefully I will have a thumb before summer gets here.
    Attachment 301456
    Which thumb are you wanting to get? Looks like Bradco went cheap and do not install the articulated link mounts on the dipper stick anymore.
    hugs, Brandi
  2. #152
    Bronze Member fordoutback's Avatar
    Join Date
    Apr 2012
    Posts
    53
    Upstate, NY
    Mahindra 4035
    I havent found one yet. I have access to a machine shop and plasma cutter and was planning on designing my own. THere are brackets with holes already welded on the backhoe for the upper mount. I want to put a longer pin in the bucket mount for the lower mount and will design the thumb with a curve so that it wont "spit out" the material I'm trying to pick up.
    The more I want to get something done, the less I call it work..........
  3. #153
    Elite Member
    Join Date
    May 2005
    Posts
    2,677
    Balls Creek, NC
    New Holland Workmaster 50, Ford 4610 SU
    I've got an old International 3616 that I hope to get pictures of this weekend...
    It is old and worn but runs well...
    I think that my dad had the heads re-built years ago...
  4. #154
    Join Date
    Feb 2007
    Posts
    6,955
    Willis, Texas
    Mahindra 6520 4WD
    Fordoutback,
    Are you going fixed or hyd. thumb? I see the upper mount holes, but you don't have the mounting holes already on the dipper stick like on my 511 in the photo. The Bradco articulated fixed link nests in these holes stowed. The thumb comes with a longer pin and a "D" shaped retaining block that fits the existing flat and secures the pin, thumb, and bucket all in one. The upper unused hole on my dipper stick is for the hyd. installation.
    I think you are on the right track with the curved thumb. My thumb's teeth are 1 inch thick hardened still. I forgot the "T" number of the steel.
    hugs, Brandi
    BACKHOES LETS SEE THEM-5-5-07-booger-jobBACKHOES LETS SEE THEM-11-3-07-backhoe-thumb
  5. #155
    Join Date
    Apr 2012
    Posts
    53
    Upstate, NY
    Mahindra 4035
    Quote Originally Posted by bindian View Post
    Fordoutback,
    hugs, Brandi
    My plan is to build an adjustable manual thumb. I have some 7/16 wall 3" tubing that I plan to slide 2 1/2 tubing inside with multiple adjustment holes. My friend with the machine shop has some hardened 3/4 inch plate for the teeth. I am going to make the templates out of plywood first to get the dimensions I need before I plasma cut the teeth. (measure twice, cut once, lol). Hopefully everything goes as planned. I will definately post pictures when I build this.
  6. #156
    Join Date
    Apr 2012
    Posts
    53
    Upstate, NY
    Mahindra 4035
    Fordoutback,
    hugs, Brandi
  7. #157
    Platinum Member farmall 55a case's Avatar
    Join Date
    Oct 2011
    Posts
    506
    case ih farmall 55a
    Default
    I need to build me a thumb for my backhoe. As many trees that I have been digging up that would be handier than a pocket on a shirt!
  8. #158
    Join Date
    Jan 2013
    Posts
    165
    Brookfield,Nova Scotia
    Sears GT
    great pictures of backhoes.I'm kind of leaning towards a towable when the time comes.
  9. #159
    Gold Member
    Join Date
    Nov 2012
    Posts
    295
    Montgomery, AL
    craftsman lt1000/jd 717a/ mahindra max26 hst
    I'm planning on building a thumb for mine before too long, but I've been working mine out without it. finally starting to get decent with it.
    from the controls
  10. #160
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Quote Originally Posted by Relic View Post
    they are all towable.. just need the right trailer..
Similar Threads
  1. Lets just say......
    By Soggy Bottom Outdoors in forum Case-IH
    Last Post: 01-04-2013, 04:37 PM
  2. Ok lets try this.......
    By ron45 in forum Kioti Owning/Operating
    Last Post: 05-19-2012, 11:39 AM
  3. lets see if I can get a picture on here ! ??
    By virgil in forum Kioti Owning/Operating
    Last Post: 01-29-2007, 07:01 PM
  4. lets be safe out there.
    By gws in forum Rural Living
    Last Post: 07-17-2004, 11:15 PM
  5. Lets see what happens
    By PaulB in forum Kubota Owning/Operating
    Last Post: 05-03-2000, 09:41 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
