Results 1 to 4 of 4
  1. #1
    Join Date
    Mar 2012
    Posts
    66
    Sioux City IA
    TYM T603 52' Ford 8N
    Default
    Hi everyone. I am trying to get some more information on my Perkins/cat engine. It is a four cylinder 60 hp, and runs very quiet and smooth. I have 170hours on it so far. Are there any concerns that I should have with this engine? When it was newer ( around 50 hours) it over heated bad. Never totally got into the red but I've been thinking about it lately Now I know that I have to blow the radiator out every once in a while. Other wise it's been goodagoodengine. Could I have warped anything by over heating I
    Attached Thumbnails Attached Thumbnails More info on my engine-image-2335871639.jpg
  2. #2
    Join Date
    Mar 2012
    Posts
    66
    Sioux City IA
    Default
    Quote Originally Posted by AroniaFarmer
    Hi everyone. I am trying to get some more information on my Perkins/cat engine. It is a four cylinder and runs very quiet and smooth. I have 170 hours on it so far. Are there any concerns that I should have with this engine? When it was newer ( around 50 hours) it over heated bad. Never totally got into the red but I've been thinking about it lately Now I know that I have to blow the radiator out every once in a while. Other wise it's been goodagoodengine. Could I have warped anything by over heating I
    Wow my computer wasn't happy about that last sentence. Sorry about that haha!
  3. #3
    Platinum Member MHarryE's Avatar
    Join Date
    Feb 2009
    Posts
    834
    Northeastern Minnesota
    2011 Kubota L5740; 2005 Cat 301.8 MiniHEX; 2012 Kubota RTV 900
    Default
    You didn't say which model engine. Cat/Perkins makes a lot of 4's, now up to 175 HP on the top end and I don't remember on the bottom. Smaller ones are built on license from Shibura and those can be a bit iffy. I have one of the smallest, a 3 cylinder, in my mini-excavator. Radiator plugs pretty easy - there isn't a lot of extra cooling system room available in such a small machine. Mine has been in the red several times before I caught it and I haven't had any noticeable problem - I have close to 1,500 hours on it now. Probably not a good sign that Cat as gone to Kubota engines in their new skid steers, mini-excavators, and compact wheel loaders, but it may just be a sign they were having trouble meeting emissions, have to re-engine every product in their lineup, and they could reduce development by using somebody else's engine. If I were you I really wouldn't be greatly concerned because there s a margin between start of red and oops, there is a problem. Watch your oil consumption, change your oil if you feel you may have cooked it, and go on. My little 3 cylinder uses a quart about every 50 hours which is a bit high but my engine has always had a lot of blow-by out the draft tube, especially after letting it sit idling for a long time.
    L5740 w/FEL, 301.8 MiniHEX, RTV900, 13' tandem disk, 1 x 2 btm plow, 12' 3pt cultivator, bale spear, 7' rear blade, grading scraper, 6' KK tiller, pallet forks
  4. #4
    Join Date
    Mar 2012
    Posts
    66
    Sioux City IA
    Default Re: More info on my engine
    Quote Originally Posted by MHarryE View Post
    Thanks for the reply. I was a bit worried about oil consumption but I guess that a little usage here and there isn't the end of the world. Do you think that they are good engines? Other than the radiator problems so far its done everything that I have asked for it to do. I cannot remember if I changed the oil for the first time before or after the over heat. But I think that it is about due for its 3 change. Right now it has a wix filter in it and mobal 1 full synthetic turbo diesel oil in it.
Similar Threads
  1. BX1800 Engine Info/Specs...
    By criz067 in forum Kubota Owning/Operating
    Last Post: 02-02-2012, 02:09 PM
  2. Case 446 engine info
    By Dr Natedogg in forum Case / Ingersoll
    Last Post: 11-28-2011, 09:26 AM
  3. Need Yanmar Engine Info
    By FarmerGeorge in forum Yanmar
    Last Post: 01-03-2008, 10:37 AM
  4. Need Yanmar Engine Info
    By FarmerGeorge in forum Buying/Pricing/Comparisons
    Last Post: 01-02-2008, 04:11 PM
  5. 7232/3/4/5 engine info?
    By ekrampitzjr in forum Cub Cadet Yanmar & CUTs
    Last Post: 07-14-2003, 10:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
