Results 41 to 50 of 61
02-02-2013, 08:34 AM #41Gold Member
- Join Date
- Nov 2005
- Posts
- 408
- Location
- Colebrook, N.H.
- Tractor
- Kubota L3830HST
Re: Preferred Style Of Tire Chains?
I'm inclined to agree with you, Gordon, but I thought I'd pass that on to see if others had heard of that practice. Compared to those beefy studded chains on the rear, the standard car/truck chains (no v bars) on the front are pretty puny. I can't imagine that the fronts would grip more than the rears. It just seems like a good idea to have a little bit of extra gripping power on the front to help out. Just leaves me without any chains for the truck!
And you're right, it's a challenge to work the brake pedals and the HST pedal at the same time. I don't think Kubota gave that enough thought...-Jim
02-02-2013, 08:58 AM #42Veteran Member
- Join Date
- Dec 2002
- Posts
- 1,922
- Location
- Foster, RI
- Tractor
- JD 750
Well if the tractor fronts work the same as a car's open differential that has 4 wheel drive ( which is mostly in reality 2 wheel drive) I suppose chaining the drive wheel will offer some additional grip. Backing up however might alter this if directional change effects drive wheel transfer. A cars Posi Traction works mostly on clutches within the unit that when one side slips, the other side grips. An open differential just stays slipping on one side unless the torque is so great that enough energy is applied to the other tire as well. I've seen very powerful cars that have an open diff (no posi) cause both sides to burn out although the other side is not as long. A locking differential is when equal force is applied to both sides. I'm thinking most 4wd tractors have open diffs on their fronts.
02-02-2013, 09:28 AM #43Veteran Member
- Join Date
- Dec 2002
- Posts
- 1,922
- Location
- Foster, RI
- Tractor
- JD 750
The Norwegian type chains are the best all around chain in my opinion. Having said that and what is good about this discussion, is that one does not necessarily need to go that route dependent on what they are looking for traction wise. My 4 ladder chains suffice for me as I am mostly logging or plowing snow. They aid traction in icy ,snow covered ground. I have nothing "critical" such as hills or fall offs that necessitate constant grip on ice such as the Trygg type chains provide. The front chain comes in handy (2 link ladder) when coming onto an ice encrusted ground formation of snow covered rock. What is aiding traction most in frozen or snow covered ground however is the thousand pound tree stem hanging off the 3 point.
02-02-2013, 05:13 PM #44Gold Member
- Join Date
- Jan 2008
- Posts
- 372
- Location
- Western PA
- Tractor
- John Deere 5083E MWFD, Kubota L3400 HST
Arrow, I love a good discussion and have been known to be hard headed and stubborn but I always learn something the easy or hard way. I wasn't trying to say that your tires were old. But the depth of your lugs is MUCH less than the depth of mine. I dont think I gave you enough credit with the loose chains though. The side chains appear to be about 6 inches out of synch and cause the cross chains to ride nicely on the lugs.
And to quote tirechains.com "PLEASE NOTE: To insure maximum life and performance of your tire chains,
tire chains must be installed as tight as possible. Tensioners are recommended." tirechains
Directly from their webpage.
As for the "If you cannot run your chains a little loose for clearance problems, then you may run into the trouble you are describing but it is not a standard,be all axiom for chains to always attempt to state: "these chains are no good because they ride between the lugs" in my experience." UNLESS the chain is taller than the thickness of the tire lugs. IF the chain is shorter than the lug, it doesn't help a lick since the chain is completly hidden by the lug. Your chains are obviously taller than your lugs and the out of time per say and ride nicely on the lugs. I am all about getting by for cheaper, but I dont think it would work in my instance. IF there is no pressure from the lug onto the chain, it doesn't have any grip.
I think that covers anything, let me know what I missed! Getting any snow out your way? I just ordered 8 duo v-bar patterns to tighten up the pattern on my fronts and the chain tool to boot. It was actually a funny conversation with the guy when I ordered them. He said I dont think you can do that. And when I asked him why not. HE paused for a second and said WEll i dont see any reason why not, but I dont think the company would do that. Which I dont understand why they wouldn't take a custom order but that complicates things quite a bit. Boy thats long winded!'11 John Deere 5083E, 563NSL Loader, MX10 Mower, 78" Bucket, Forks/Bale spear (interchangeable)
L3400 Kubota HST Loader, finish mower, rake, scraper blade, Gin pole, Kustom Fab front hydraulic snow plow (Inspired by ASGAR),
'01 International 4700 LP, DT530, Allision 3000, Air Ride, Crew Cab
'11 Moritz 20+5 14.5K GN with adj. Tail
'95 CR 500
FIL-JD 4020; Ford 9600,5000
02-03-2013, 02:47 AM #45Gold Member
- Join Date
- Nov 2005
- Posts
- 408
- Location
- Colebrook, N.H.
- Tractor
- Kubota L3830HST
Here are a couple of pictures of my chain setup. This shows why I don't think the fronts are in danger of having more traction than the rears. Turns out you couldn't put anything larger on the fronts anyway, because when the wheels are turned all the way you could just about measure the clearance to the loader arm supports with a feeler gauge. The front chains are borrowed from my pickup, which has 245-75x16 tires, so they don't come very far down the sidewalls here, but with the bungees keeping them tight I think they'll be all right. I'm happy with this combination so far.
-Jim
02-03-2013, 07:33 AM #46Veteran Member
- Join Date
- Apr 2007
- Posts
- 1,664
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Dresser TD7G Dozer
"If you're not making any mistakes then you're not doing anything"
L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
02-03-2013, 01:12 PM #47Gold Member
- Join Date
- Nov 2005
- Posts
- 408
- Location
- Colebrook, N.H.
- Tractor
- Kubota L3830HST
Gordon, since I put the fronts on we had a mild stretch with rain that settled the snow here, but I think that if I get wallowing around in deep snow I'll probably still have to use the independent brakes for tight turns. I really wanted to have them on there to help cope with glare ice situations on an incline, to have something up front to grip as opposed to nothing.
The Trygg website shows that their studded chains come in several different sizes of chain, and I think the ones I got would be considered about medium, 9.5MM. Labonvilles had chains in my size, but I think what they carry is a heavier chain. For $1700 I would think so! That was exactly double what I paid for these, and that hurt plenty. That would be way overkill for me. I really like these. As I mentioned before, one of the neat things about these "Flexi" chains is the ability to shorten the sidechains by way of three removable links evenly spaced around the diameter of the tire, front and back. That lets you snug up the chains without having to use tensioners to pull the slack out of the sidechains.Last edited by jimainiac; 02-03-2013 at 01:37 PM. Reason: more info...
-Jim
02-03-2013, 03:16 PM #48Platinum Member
- Join Date
- Jun 2004
- Posts
- 657
- Location
- Armstrong, BC
- Tractor
- Kioti DK35 SE HST (2011)
02-03-2013, 08:49 PM #49Veteran Member
- Join Date
- Dec 2002
- Posts
- 1,922
- Location
- Foster, RI
- Tractor
- JD 750
I think RN that the aspect of tight chain recommendation from a place that sells them for all kinds of vehicles has more to do with high speed rotation. You would not want a loose chain on a truck tire or automobile so as to not throw the chain and so they come out with a generalized edict that might not fit every application. I do not use tensioners and they stay on just fine. The tractor is moving too slowly for looseness to be an issue. No matter which way I position the links, my lugs on the new tires are always taller than the chain and yet, they work fine. If your rears are making 3/8 chain minuscule, perhaps we need to rethink that on your type of tire size, chains to be effective without going into all kinds of chain configurations, must be made of larger link like more of what you'd find on a log skidder. I wonder if you'd have this problem with 2 link ladder chain made out of 1/2" link. Your tires are just too large to come out of this cheaply. This past summer I drove my bils 5083 to cut grass while in Kentucky. The rears are huge and this was a 2wd machine.
This season so far we've gotten one 12" snow fall and a couple 3 or 4 inchers. Its all gone now as last week we had 2 days of almost 60 degree weather.
02-04-2013, 07:11 PM #50Gold Member
- Join Date
- Jan 2008
- Posts
- 372
- Location
- Western PA
- Tractor
I talked to an older gentleman on the phone and he did not really seem to keen on the idea. He also screwed up the order. I got 8 pairs of non v-bar duo grips instead of the v-bars. I should have listened to him though when he offered to include the tractor chain tool in the order and after messing around with some 5/16 dually chains I promptly went online and ordered them!
I would agree with you that they are probably making a blanket statement to cover their rears. And a tractor shouldn't ever need to be moving more than a couple mph but some machines are capable of running 25 mph, which is what they say the max speed for their chains are. I'd be very curious to see what 1/2" chains would look like on my machine, but I think im going to have to settle for the 3/8" for now. I would be more than willing to try some 2 link ladder bars especially with v-bars, I think that would be just about all the height I would need even if they were laying perfectly between the treads which would almost never completely happen. I have often wondered what those great big ring chains would ride like in a tractor. Its pretty soft out in the woods, I think a hard packed driveway might just about jar my teeth outta my skull with them though. My mind tends to wander alot farther than my wallet can follow!
Good discussion all.'11 John Deere 5083E, 563NSL Loader, MX10 Mower, 78" Bucket, Forks/Bale spear (interchangeable)
'95 CR 500
Similar Threads
Tire Chains, Front Tire, John Deere x749 Tractor
By amtf in forum AttachmentsReplies: 2Last Post: 06-14-2012, 03:41 PM -
Chains is it possible to make 12.4X16 tire chains from truck chains?
By BC Dave in forum YanmarReplies: 7Last Post: 10-28-2011, 08:26 PM -
Chains Rubber style tire chains
By Michgriz03 in forum Owning/OperatingReplies: 13Last Post: 12-28-2010, 05:28 PM -
Tire Chains - best style
By Jay4200 in forum Owning/OperatingReplies: 42Last Post: 09-26-2010, 09:20 PM -
Are rubber tire chains better than steel tire chains?
By tacarima in forum Owning/OperatingReplies: 9Last Post: 05-09-2010, 07:45 AM
