Page 1 of 7 1234 ... LastLast
Results 1 to 10 of 61
  1. #1
    Gold Member
    Join Date
    Nov 2005
    Posts
    408
    Colebrook, N.H.
    Kubota L3830HST
    Default Preferred Style Of Tire Chains?
    I'm in the process of looking for chains for my Kubota L3830, with 17.5Lx24, R4 industrial tires. I'm leaning strongly toward ice-studded chains in an "H" pattern. I've seen them in use around here, and they seem pretty aggressive, which is what I'm after. I'm dealing with snow and ice on hilly terrain. Our driveways are gravel and we live on a gravel road, so the "tear up" factor is low. We also intend to head into our woods for firewood, and may be dealing with mud, come Spring and Summer.
    I don't have clearance issues now that I've set the wheels out to the widest position. I now have four inches of space between the back sidewall and the fender.
    This style of chain is quite pricey, and I guess a more economical compromise would be the "duo" style, which is basically a ladder type chain with every two cross chains hooked together, to keep them up and out of the tire tread lugs. Apparently this style gives a bumpy ride because of the space in the tread with no chain.
    Just wondering what others prefer, and why? Maybe I've missed something...
    -Jim
  2. #2
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,836
    Frederick County, VA
    Kubota BX2360 & L4240 HSTC
    Default Re: Preferred Style Of Tire Chains?
    If you don't plan on going on the pavement vbar chains will be great. They will be really good on ice. I have always ran regular ladder chains on a ford 8N without problems. I don't have chains for the 4240 yet but after we get a good ice storm I am sure I will want some. If you want some real aggressive the duo ladder vbar combo chains, but they are expensive. Tirechain.com has some good prices.
  3. #3
    Platinum Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    987
    Rochester, MN
    Kubota BX2230
    I don't have chains as my driveway is fairly level and paved, so I can't give a personal opinion.
    However these are probably the most aggressive set of chains I've seen in a picture here. Almost scarey!
    http://www.tractorbynet.com/forums/k...ml#post3136727
  4. #4
    Join Date
    Dec 2002
    Posts
    1,922
    Foster, RI
    JD 750
    I think you'd be well pleased with a set of 2 link ladder chains. If you need ice grip because of dangerous terrain, then get the v-bars. If not, even regular chains will turn your tractor into a grip monster.
    Attached Images Attached Images
  5. #5
    Elite Member
    Join Date
    Apr 2004
    Posts
    4,764
    Bay Area-Ca and Olympia WA
    Cat D3, Deere 110 TLB, Kubota BX23, Craftsman Mower
    Chains seem to be real cheap here at garage sales...
    I picked up a couple of truck sets for almost nothing and put them together to fit my BX.
    They are V-Bar style.
  6. #6
    Veteran Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    1,664
    NorthEastern, VT
    Kubota L3010DT, Dresser TD7G Dozer
    The price of these were $365 in 2005 they are 8mm chains on 12.4 X 24 R1's. So they are going on 8 years old. They last a long time. They say that inflation is low but everything I look at it seems the price has doubled or trippled.
    Attached Thumbnails Attached Thumbnails Preferred Style Of Tire Chains?-tractor2.jpg
    "If you're not making any mistakes then you're not doing anything"
    L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  7. #7
    Gold Member
    Join Date
    Nov 2005
    Posts
    408
    Colebrook, N.H.
    Kubota L3830HST
    Gordon, those are the type chains I'm interested in. Granted, my size being wider, they'd be a bit more money, but I'm seeing $900-$1000 range. That's why I'm still looking. Glad there's no inflation.
    I called Labonvilles in Gorham, NH. I figured they'd have high quality chains, and they do, but $1700(!) was a little rich for my blood.
    -Jim
  8. #8
    Join Date
    Apr 2007
    Posts
    1,664
    NorthEastern, VT
    Mine were made in Norway by Tellefsdal. I believe they came to my dealer ( now closed ) via Canada.
  9. #9
    Veteran Member Jay4200's Avatar
    Join Date
    Nov 2005
    Posts
    1,616
    Hudson/Weare, NH
    L4200GST w/ LA680
    Quote Originally Posted by jimainiac View Post
    2-link v-bar ladders are pretty nasty. I've been running them on the front of my L4200 for the last 3 years - I bought regular 2-link ladders for the back too, but haven't found a need to even put them on yet.
    17.5-24 Tire Chains
    JayC
  10. #10
    Join Date
    Dec 2002
    Posts
    1,922
    Foster, RI
    JD 750
    Quote Originally Posted by Jay4200 View Post
    17.5-24 Tire Chains
    JayC
    Couldn't agree more. Shouldn't consider ladder type chain out of the picture at all as they will certainly make a world of difference. Plus they are less than $700. You can pay almost twice that but performance will not go up accordingly. Any chain makes a remarkable difference. Enhancement of chain such as v-bars just builds on the remarkableness. (if that isn't a word it should be)
Similar Threads
  1. Replies: 2
    Last Post: 06-14-2012, 03:41 PM
  2. Replies: 7
    Last Post: 10-28-2011, 08:26 PM
  3. Chains Rubber style tire chains
    By Michgriz03 in forum Owning/Operating
    Last Post: 12-28-2010, 05:28 PM
  4. Tire Chains - best style
    By Jay4200 in forum Owning/Operating
    Last Post: 09-26-2010, 09:20 PM
  5. Are rubber tire chains better than steel tire chains?
    By tacarima in forum Owning/Operating
    Last Post: 05-09-2010, 07:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
