Results 1 to 7 of 7
01-26-2013, 11:34 PM #1Veteran Member
- Join Date
- Jun 2012
- Posts
- 1,299
Help for moving fire wood wth Pallet Forks
I just bought my first set of pallet forks for my L3540 Kubota tractor. They were used and thrown in with another purchase. I thought they might come in handy for moving fire wood from the splitter to the house. I am looking for proven methods that others have used and hope to find an idea that will work for me. I am thnking I could keep my wood in the back yard away from the house, and bring down a pallet load as I need it. Has anyone designed a box or rack that green wood could be piled on and moved later when dried?
01-26-2013, 11:38 PM #2Veteran Member
- Join Date
- Jul 2009
- Posts
- 2,223
- Location
- SW WA
- Tractor
- Kubota BX2360
Re: Help for moving fire wood wth Pallet Forks
Plenty of solutions in this one thread:
http://www.tractorbynet.com/forums/p...transport.html
Lots more ideas:
Do a Google image search:
site:tractorbynet.com firewood
01-27-2013, 01:34 AM #3Gold Member
- Join Date
- Dec 2010
- Posts
- 254
- Location
- Pocahontas, Arkansas
- Tractor
- John Deere 4200 4wd/ 420 loader, 4 wd,08 polaris 700 ranger crew
Thanks of the link,that is what I need to do with our wood. I stack in the garage basement,our furnace is in the basement. My wife asked what are your gonna do with that extra wood that is left in the garage,I dont want it in here after wood burning season is over,afraid snakes will get in it. So that threw a red flag up.So these ideas will help next year. Bring it in on pallets. Whatevere is left,take it out on pallets. LUTT
01-27-2013, 08:33 AM #4
If your forks are the bucket-mounted kind there may be a problem with the weight and lifting ability of the tractor. Having the weight at the end of bucket forks greatly increased the leverage. In any case, a heavy ballast will be necessary on the 3PH.
If it is green wood (directly from the splitter) then weight is even more a factor. Test how much you can haul and adjust your pallet stacks appropriately.
There are a lot more threads on TBN on this subject if a search is done. Try "firewood" as a search topic.2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
2002 Kubota L48 TLB, 12", 18", 24" HD buckets
2001 Kubota BX2200, Turf, LA211 FEL
7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
01-27-2013, 08:46 AM #5
That's the problem with trouble.
It always starts out as such fun."
- Randall Brown
01-27-2013, 09:56 AM #6Bronze Member
- Join Date
- Jun 2011
- Posts
- 59
- Tractor
- TYM 350
Here is one made out of scrap metal 4'x4'x4'.
In the second pic I added some rebar between the pipe to make it eazier to walk into.
01-27-2013, 01:52 PM #7Veteran Member
- Join Date
- Jun 2012
- Posts
- 1,299
I should have said that it is quick attach forks to attach to the FEL.
Similar Threads
3ph Pallet Forks vs FEL forks
By meledward23 in forum AttachmentsReplies: 17Last Post: 08-02-2012, 08:53 AM -
Clamp on pallet forks or debris forks?
By Gio in forum AttachmentsReplies: 17Last Post: 10-19-2010, 01:49 PM -
Forks Moving quail pen with pallet forks
By Oleozz in forum AttachmentsReplies: 1Last Post: 09-10-2007, 03:14 PM -
Chipper Pallet Forks & PTO Wood Chipper Recommendations
By gmsssi in forum AttachmentsReplies: 6Last Post: 05-21-2005, 06:48 AM -
Forks Pallet Mover vs. Pallet Forks?
By aloha in forum AttachmentsReplies: 12Last Post: 09-23-2004, 12:50 PM
