Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Elite Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    Default Re: Suggestion on tractor to lift big round bales
    If you pull up tractor data.com you can side by side compare loaders. The 553 JD that fits on the 5xxxE tractors and others lifts 3133 lbs to full height and the Kabota LA1153 loader lifts 2326 to full height but reaches 10 inches higher. Both should do 1000 -1500 lb bales easily on a properly set up and ballasted tractor. Having the rear tire tread set to it's widest width and the rear tires loaded plus a 1000 to 2000 lb counterweight gives the widest safety margins and places the least strain on the front axle parts.
  2. #12
    New Member
    Join Date
    Feb 2013
    Posts
    2
    north of Dallas Tx
    Kubota L282
    thanks for the great suggestions! We'll be handling round bales moving from the pasture onto a 16 ft trailer and stacking in a barn. Have 45 acres half in coastal hay we'll be cutting but not bailing ourselves. Some hills so a good counter balance is a must, and looking at a 4wd. good thought about the auto transmission, didnt consider that previously. MUCH appreciated to y'all that replied.
  3. #13
    Super Member texasjohn's Avatar
    Join Date
    Oct 2005
    Posts
    6,048
    Central Texas, Jarrell
    Kubota Grand L5030HSTC
    A tightly wound, fresh cut big coastal bale will be every bit of 1500lbs, perhaps more. If rained on, clearly more until it dries out.
    Joy is having the tools you need and needing the tools you have!
    Kubota 5030 HSTC, BB, Danueser PHD, LA853 QA HD FEL w JD toothbar, 3pt chisel, 3 pt disk, 6' shredder, Kubota FEL hay spike, 3pt hay fork w carryall, Kubota RTV 1140
  4. #14
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    Quote Originally Posted by ciaobb2 View Post
    I have no trouble doing loader work with my gear type transmission in a JD5045E. It is just a matter of what you are used too and I find the fact it is sincroed forward to reverse in all three ranges to be all I need. Test drive both types and see how You like each.
  5. #15
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,803
    Nova Scotia, Canada
    Bale handling on a friends farm picture.
    Suggestion on tractor to lift big round bales-img_0084-jpg
    Suggestion on tractor to lift big round bales-img_0063-jpg
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  6. #16
    Join Date
    Apr 2012
    Posts
    743
    pa
    kubota 7040sud
    a 7040 fel hydrolic shuddle shift loaded rear cast centers and 3 extra wheel wieghts will lift round bales and carry them safely i lift alot heavier then that if you need proof FOREMAN ETEXAS bales round bales with his 2 7040 s and loades them
  7. #17
    Gold Member XSKIER's Avatar
    Join Date
    Apr 2011
    Posts
    460
    Fenton, MI
    '11 Deere 1026R
    Default
    This has got to be my favorite bale mover!
    Suggestion on tractor to lift big round bales-image-1939097235-jpg
  8. #18
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    2,002
    Rochester, MN
    Kubota BX2230
    Quote Originally Posted by XSKIER View Post
    Indeed, that's a mighty mite. But I think you better keep that one on very level ground.
Similar Threads
  1. Big round bales
    By Mark Page in forum Owning/Operating
    Last Post: 08-14-2012, 06:19 PM
  2. Buying Advice How big of Tractor to unload round bales from Semi?
    By texvet45 in forum Buying/Pricing/Comparisons
    Last Post: 09-05-2011, 09:45 PM
  3. Tractor for moving and stacking big round hay bales
    By richardbro in forum Owning/Operating
    Last Post: 01-13-2009, 07:54 PM
  4. how big for round bales
    By jimmyj in forum Kubota Buying/Pricing
    Last Post: 02-06-2008, 06:31 PM
  5. Big round bales
    By GrantMO in forum Rural Living
    Last Post: 02-04-2002, 07:32 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
