Results 1 to 2 of 2
02-03-2013, 07:43 AM #1New Member
- Join Date
- Jan 2013
- Posts
- 5
- Location
- Hegins Pa.
- Tractor
- IH 185 Low Boy
184 Low Boy
Can anybody tell me which cylinder is #1 ? Radiator or seat end ?
Also how many revolutions of the flywheel after after you have piston #1 up a tdc on compression is it till piston #4 come up to tdc on compression? I need to adjust the valves. TIA
02-03-2013, 01:18 PM #2Veteran Member
- Join Date
- Jan 2009
- Posts
- 1,512
- Location
- Rushville, Ohio
- Tractor
- Massey 180 Diesel
Re: 184 Low Boy
#1 cyl. is nearest the radiator. Being the firing order is 1-3-4-2, and it fires a cylinder everytime it hits TDC, 2 revolutions should put you at TDC compression for #4.
I don't have a Cub, but all of my C-113's and C-123's are checked hot when running at a slow idle, other than if they have just been OH'd, then adjusted cold, by turning the engine until the particular cylinder valves are at rest. Being your adjusters are on the side, that could get a bit messy adjusting when running...
Similar Threads
Cylinder location 184 Low Boy
By mickeyt in forum Oil, Fuel & LubricantsReplies: 2Last Post: 02-10-2013, 09:01 AM -
Loaded International Harvester Lo-boy 184 Tractor - $5500 (Souderton, PA) 18964)
By jcottom in forum Private Party AdsReplies: 0Last Post: 05-22-2011, 01:32 PM -
1971 cub low boy 154
By kawman14733 in forum ProjectsReplies: 6Last Post: 11-24-2010, 06:43 AM -
Cub Lo Boy 184 losing its ground
By Patty Gilbert in forum Owning/OperatingReplies: 7Last Post: 09-21-2009, 02:48 PM -
IH 184 Lo-Boy PTO clutch Slipping
By rottiezucco in forum Parts/RepairsReplies: 2Last Post: 07-23-2009, 05:49 PM
