Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
  1. #11
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    1,519
    Lancaster County, PA
    Kubota L3200, Ford 1210
    Default Re: Do you maintain/repair your own equipment or dealer service/repairs for you ?
    I do the maintenance work. Fortunately I can handle most repairs but I have a realistic idea of my limitations. I wouldn't venture into engine internals. The most involved repair I've done was probably when I split my Ford to replace the clutch.
    Fuel comes from a convenience store that sells ORD in 5 gallon yellow cans.
  2. #12
    Bronze Member moriboy's Avatar
    Join Date
    Jul 2010
    Posts
    88
    Oregon
    Kubota M7040. MX125, Ford TW-5, NH 7840
    Default
    I do everything I can to all of our equipment. The last time we used a dealer was for installing a new piston liner in one of our bigger tractors. All of our fuel is ag, purchased from a CFN station.
    2012 M7040 QA w/ 3rd function
    BH 76 Hoe, LP 96 " twin rotary cutter, LP 96" grading scrapper
    bale spear, LP pallet forks, Anbo 72" grapple, LP 4084 rear blade
  3. #13
    Join Date
    Dec 2006
    Posts
    57
    Dripping Springs, Texas
    New Holland TC30
    I've done everything on my used TC30 so far. Even if I have to rebuild the engine (not likely in the near future) I plan on doing the work myself except for any machine shop work. It's the reason I bought used and saved a chunk of change - if used but not abused, these things can outlive their owners.
    And fuel is from a regular gas station whenever I fill up the Rover - I don't burn enough to buy ag fuel. I do add Optilube though.
  4. #14
    Join Date
    Nov 2012
    Posts
    114
    Hawthorne, FL
    Kubota L285
    Default
    I hate to admit I use ULSD because its just easier. I dont like it, it doest even have that good diesel smell, and it probably long term is not good for an old 1976 engine.
  5. #15
    Join Date
    Jul 2012
    Posts
    58
    Goochland, Va
    Bobcat 773
    I have done everything on the Bobcat skid steers myself, welding, maintenance and repairs. I would hand it to the dealer if it was a serious issue - something that needed more than a days worth of work from me.
  6. #16
    Elite Member dodge man's Avatar
    Join Date
    Oct 2008
    Posts
    3,045
    West central Illinois
    Kubota BX2350
    I do everything for maintance in my Kubota. I would be comfortable doing even major repairs, its just a matter if I feel like it or have the time. So far I've been lucky, just routine mainance for my BX.
    Dave,
    BX2350
  7. #17
    Elite Member WilliamBos's Avatar
    Join Date
    May 2004
    Posts
    3,795
    Innisfil, Ontario, Canada
    MF 1635 12x12 Powershuttle
    Default
    Ours has only been back to the dealer once, for a leaky brake arm seal. We do our own maintenance and repairs now that warranty has expired.
    Thanks,
    Will
    I do not care if someone's net nanny is watching!! You need to stop...
  8. #18
    Member
    Join Date
    May 2009
    Posts
    33
    I have with the exception of one time with my skid steer brought any of my equipment to a dealer for repair. That time I was in a time crunch and needed it done now for a paying side job.
    Two winters ago I rebuilt one of my 4020's pretty much from the ground up. Should be good for another 50 years now, the other one if I decide to keep it will get the same treatment next winter. That being said, the newer tractors are a bit more complicated than the old iron. There is a possibility that if and when my TD5050 goes down it may have to go to the dealer for repair if its related to the computers or maybe even electrical.
    As far as fuel goes. I get it delivered 500 gallons at a time and have a 75 gallon drag up tank in the back of my truck for refueling tractors in the field.
  9. #19
    Gold Member
    Join Date
    Nov 2005
    Posts
    408
    Colebrook, N.H.
    Kubota L3830HST
    We bought our L3830 new in 2004, and, knock on wood, the only time I've had to take it to a shop so far was when I punctured a loaded rear tire. When we got the tractor I bought the shop manual and the parts manual, but I don't find them very helpful. Better than nothing, I guess, but the shop manual leaves a lot to be desired in my opinion.
    I buy as much maintenance stuff as I can at NAPA, but most parts and special filters have to come from Kubota, especially the super-duper HST fliud.
    We're lucky that where we are now, the local gas station has off road diesel.
    -Jim
  10. #20
    Join Date
    Jul 2011
    Posts
    594
    Mahindra 4510
    I do all my own work everything from my cars, trucks and tractor. At least I know it is done right, not saying dealers are bad but I am saying I have higher standards than most. Only service my tractor saw at the dealer was the 50hr to maintain warranty, took it home and front Axel fluid was low, promptly redid the whole service. For fuel I use the yellow can because I had to get rid of my yard tank after I punched out the building inspector over an unrelated dispute, he got fired I got probation.
Similar Threads
  1. Equipment repairs, Excavator Gum Surgery!
    By mike69440 in forum Projects
    Last Post: 07-10-2012, 08:51 PM
  2. Replies: 8
    Last Post: 05-18-2011, 11:05 PM
  3. And you say I don't maintain my equipment
    By RegL in forum Power Trac
    Last Post: 09-07-2009, 10:34 AM
  4. Will your JD dealer pick up your new tractor for repairs?
    By andrewj in forum John Deere Owning/Operating
    Last Post: 07-02-2006, 09:11 PM
  5. Dealer kioti dealer service and repairs
    By shawnrogan in forum Kioti Buying/Pricing
    Last Post: 04-03-2005, 07:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
