Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
  1. #21
    Veteran Member sam5570's Avatar
    Join Date
    Jan 2012
    Posts
    1,429
    south west virginia
    new holland tn70
    Default Re: Do you maintain/repair your own equipment or dealer service/repairs for you ?
    well same here as most i do all the work on my tractor my truck's and ever day driver's. if i run into a major problem that im not sure about i call a guy who worked for new holland for several year's. i help him with his vehicle's he helps me with the tractor. i get my fuel 10 gallons at a time from local station has ORD. i have just seen so much bad work come out of dealler ships that i am very hesitant about letting them work on anything of mine.
  2. #22
    Join Date
    Dec 2009
    Posts
    1,907
    S. W. Virginia
    Kubota B3200, Ford NAA, IH 454D, Case 1845C
    I now do 100% of the work on all my equipment and vehicles. I truly believe most dealer mechanics are vastly incompetent and would never allow them to lay a wrench on my things. This is based on many bad experiences in the past with my own and my family's vehicles/equipment. I even go as far as to do my own work even if it is covered under warranty, I'd rather eat the cost of parts and have it done right than have something else go wrong due to the mechanics screwing something up.
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    Case 1845C skid steer
    JD 265
  3. #23
    Gold Member unbidden's Avatar
    Join Date
    Dec 2010
    Posts
    426
    R.I.
    Kubota BX2660
    240 hours on my BX so far and it hasn't seen the dealer since delivery. I do all the easy stuff myself and you'd be amazed at what you can find in tutorials on this site and others. Check youtube also, I recently watched a video on replacing bearings for a rear mower deck.
    Foster Center, RI
  4. #24
    Veteran Member xring100's Avatar
    Join Date
    Dec 2012
    Posts
    1,470
    Livingston County, Michigan
    Kubota M8540, ZD1211 60"
    Default
    Typically do all my own work on every thing from appliances ,motorcycles to my tractors. Usualy get ORD locally in 55 gallon drum and transfer it to a 300 gallon tank. Mine is all treated with a biocide to prevent algae growth , and a stabilizer/lubricant/antigel
    Dave
    Dave
  5. #25
    Veteran Member D7E's Avatar
    Join Date
    May 2006
    Posts
    2,256
    manitoba
    Many
    We do everything from service to tyre changes to engine rebuilds / clutches etc . Transmissions and computer is about all we are'nt brave enough to do . Then we wont use dealer and prefer a good private mechanic .
    And i wont touch small gas engines
  6. #26
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    I do my own maintenance, but in about 1500 hours in 10 years, nothing serious has needed to be repaired. I did have one loaded rear tire that I backed over a fresh stump and pinched the tube, that I took to a tire shop that does truck and tractor tires.
    With a gear transmission, no computers, no cab, etc., it's a pretty simple machine as far as things that can malfunction goes.
  7. #27
    Gold Member
    Join Date
    Jan 2012
    Posts
    321
    Moores Hill, Indiana
    MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
    I try to do most everything myself. However, "a man's got to know his limitations" said in my best Clint Eastwood voice. Simple oil change or unbolt and rebolt parts I do. Internals or electronics, dealer does. Occasionally you can get lucky and find by word of mouth a dealer mechanic that does side work cheaper (relatively speaking). As far as diesel, I lucked onto a craigslist tank with a 12 volt gasboy pump. I have the local co-op bring offroad diesel in bulk. For the gasonline tractors, that comes in 2.5 and 5 gallon cans. Kroger offers reward points that can be redeamed on gas. 100 points is $.10 a gallon up to 35 gallons.
    MBA = More Bad Advice
  8. #28
    Veteran Member RPW's Avatar
    Join Date
    Aug 2009
    Posts
    1,026
    Default
    Same here. As much of the maintainance as possible. Dyed fuel. A bit further to get but the process difference makes it a no brainer.
    2008 JD 5103, FEL, 6' Frontier, 6' HD boxblade, 7' Landscape rake, More impliments to come, Bobcat (clark) 742 SS.
  9. #29
    Gold Member BlackRaptor's Avatar
    Join Date
    May 2008
    Posts
    382
    SEMN
    John Deere 3320
    I do all my own work once the warranty expires.
    Fluids I dont trust the shop guys to take as much care as i do.
    I use road diesel only because the 3320 uses so little but i've been toying with buying 100gal tank from the local co-op. 100 gal would last me a crazy long time.
    Chad.
    2012 John Deere 3320 Cab 300CX FEL
    2010 John Deere Z910a
    1962 JI Case 830 wide Front
    1960 Farmall 460 Narrow Front
    1954 John Deere 70 Wide Front FEL
    1947 Farmall M Narrow
    1945 Farmall H Narrow
  10. #30
    Super Member CompactTractorFan's Avatar
    Join Date
    Jul 2010
    Posts
    7,963
    Pennsylvania
    Kubota BX25
    Fluids, filters, and the like we do ourselves most of the time. For repairs, it goes out to the dealer. We buy ULSD at the local service station.
    Kyle - CompactTractorFan
    Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
    2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
Similar Threads
  1. Equipment repairs, Excavator Gum Surgery!
    By mike69440 in forum Projects
    Last Post: 07-10-2012, 08:51 PM
  2. Replies: 8
    Last Post: 05-18-2011, 11:05 PM
  3. And you say I don't maintain my equipment
    By RegL in forum Power Trac
    Last Post: 09-07-2009, 10:34 AM
  4. Will your JD dealer pick up your new tractor for repairs?
    By andrewj in forum John Deere Owning/Operating
    Last Post: 07-02-2006, 09:11 PM
  5. Dealer kioti dealer service and repairs
    By shawnrogan in forum Kioti Buying/Pricing
    Last Post: 04-03-2005, 07:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
