Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
  1. #31
    Platinum Member kw22614's Avatar
    Join Date
    Dec 2012
    Posts
    548
    Manassas, VA
    Kubota BX1860
    Default Re: Do you maintain/repair your own equipment or dealer service/repairs for you ?
    Try to do all repair/maintainance on all my vehicles. Been doing it so long now in the driveway in front of my garage(wish I had a shade tree there), on what's turned out to be a busy road that started out as a little traveled rural lane almost 30 yrs ago. Lots of the neighbors now bring me their vehicles too. Every once in a while, when working on something, even get 'new folks' stop to ask for help or if I can work on theirs. Usually always have something in the driveway waiting to be worked on. 2005 Mustang (neighbors) right now and 2002 Sentra (new folks) next up - though time for some maint on wifey's 05 Santa Fe real soon.
    2012 BX is my first tractor and first dealings with diesel, haven't reached my first 50 hr sched maint yet -but looking forward to it. Had a couple warranty issues, one where I had to trailer her back to the dealer and twice where their service truck came to me. Just doesn't feel right having someone else turn wrenches on my stuff! My BX only holds 6.6 gals of fuel so I have 2 - 5 gal yellow cans so far that I try to keep full from a BP station up the street(only place for diesel close to me) @ $3.99/gal.
  2. #32
    Gold Member unbidden's Avatar
    Join Date
    Dec 2010
    Posts
    426
    R.I.
    Kubota BX2660
    Quote Originally Posted by kw22614 View Post
    In reading your post, I'm sure you are more mechanically inclined than I, however if you haven't seen this post it'll be worth a look before you do your 50 hr BX service. http://www.tractorbynet.com/forums/k...s-filters.html
    By the way, what issues did you have with your BX?
    Foster Center, RI
  3. #33
    Elite Member JerryK's Avatar
    Join Date
    Feb 2004
    Posts
    2,757
    Vanderbilt, Michigan, USeh?
    Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154S
    I only take stuff back if it is warantee work, but only if it is something that is real expensive. Most of my stuff never sees a dealer unless brand spanking new. After that, I do just about everything... even if it costs me a little more the first time to gain experience/special tools/etc. I know that I do good work.... not so sure about someone else...
    78" [26"X10"fan] Mahindra front blower,72" Mahindra front blade, 48" CID QA forks, 6' EverythingAttachments Land Plane & Landscape Rake, 78" JRW rear blower[26"X8"fan], homemade 1 ton rear weight, 6' Ford rear blade, big homemade 3pt box/carrier, 8" wood chipper
  4. #34
    Join Date
    Feb 2012
    Posts
    732
    Germanton, NC
    Kubota MX5100F IH McCormick Farmall 140, Massey Ferguson 135
    I do all the maintenance and smaller jobs like replacing an axle seal etc. and as much small engine work as I can. A friend a few miles away (like 3 or 4) does anything involved. He did the brakes and clutch on my Farmall recently. When I take things to him, they always come back better than when they left. He takes care of stuff that he sees that just needs doing. In doing the clutch and brakes, he replaced the bolts that hold the rim to the center of the wheel. Small but it was needed. Plus I trust him and his work is reasonable.
  5. #35
    Join Date
    Dec 2012
    Posts
    548
    Manassas, VA
    Kubota BX1860
    Quote Originally Posted by unbidden View Post
    Thanks unbidden, I found and saved that thread a couple months ago. I plan on using it when I do mine.
    The 1st issue was a very minor one - dealer promised to weld on a bucket hook, when delivered it wasn't there. I called and they came out within a week to weld it on.
    The 2nd(which also became the 3rd) I started this thread : Leak at steering cylinder & other ??s in the Kubota owning/operating forum.
    Sorry, I tried to send the link but can't figure out how to do it - these computers use different wrenches than I'm used to !
    Got instruction, from here on TBN to add the link. Hopefully, here it is http://www.tractorbynet.com/forums/k...r-other-s.html
  6. #36
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    I do all of my own maintenance always have always will. The tractor is still under warranty so I have warranty work done by the dealer it is there right now had a leak on the front drive shaft and warranty runs out in march gonna pick it up this weekend. All work will be done at home after that been doing that for a long time rebuild several tractors, cars, snowmobiles what ever. The only thing I really don't know much (if anything) about is diesels so I might have the dealer do some of that if I ever need it that is. But I am sure I will try and get it right even if I have to ask questions, unless I need the tractor like right away because I never said I was speedy!
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  7. #37
    Platinum Member Dead Horse's Avatar
    Join Date
    Feb 2009
    Posts
    670
    New Hampshire
    Too bad the OP didn't make this a poll, (can you do that here?)
    I have two tractors and do all my own repairs including making repairing parts I can't source or don't need to as they are just pieces of steel.
    I purchase Ag fuel and store it in a 250 gal tank with an electric pump, locked up in a barn. Go through a tank about every 12 - 14 months.
    "We a two tractor family"
Similar Threads
  1. Equipment repairs, Excavator Gum Surgery!
    By mike69440 in forum Projects
    Last Post: 07-10-2012, 08:51 PM
  2. Replies: 8
    Last Post: 05-18-2011, 11:05 PM
  3. And you say I don't maintain my equipment
    By RegL in forum Power Trac
    Last Post: 09-07-2009, 10:34 AM
  4. Will your JD dealer pick up your new tractor for repairs?
    By andrewj in forum John Deere Owning/Operating
    Last Post: 07-02-2006, 09:11 PM
  5. Dealer kioti dealer service and repairs
    By shawnrogan in forum Kioti Buying/Pricing
    Last Post: 04-03-2005, 07:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
