Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    Elite Member CurlyDave's Avatar
    Join Date
    Dec 2005
    Posts
    3,940
    Grants Pass, OR
    JD TLB 110
    Default Re: Damaged Threads in Wheel Hub - Thread Chaser or Tap - Or Call For Help
    The first think I would try is to run a bolt into the hole from the back side. The threads there are not damaged and the bolt will easily follow the threads in and will push the distorted metal back into the right shape. This will cut the least amount of metal and will be the best repair you can get.
    If you can not do that, a thread chaser from the front side is probably better than a tap. Again it cuts a smaller amount of metal.
    If you end up having to buy both a thread chaser and a tap you are still way ahead of the game vs. replacing a hub.
    40 Acres on a hill - fantastic view. JD 110 TLB, 4-n-1, 12" bucket, 18" bucket, Addington thumb, rock bucket (doubles as root grapple)
    Not only do we not understand the universe, if someone explained it to us, we would not know what he was talking about.
    Isaac Asimov
  2. #12
    Super Member
    Join Date
    Feb 2006
    Posts
    6,764
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Quote Originally Posted by CurlyDave View Post
    These are the best options. Without some prior experience you are likely to get a hit or miss on finding the proper lead in thread from the front side. If you come from the back you are guaranteed. If you do using a bolt be sure to use moly anti seize paste on the threads to prevent galling.
    larry
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, Hesston Haybine, JD Rake
    Bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  3. #13
    Platinum Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    933
    Roosterville, MO
    JD 955/70A/7 TLB
    Quote Originally Posted by DKCDKC View Post
    I bought the bolts from the JD dealer for that $1.63 each. But as hard as I looked online at the JD site and others, I could not find the specs on the bolt. Could you tell me where you found the dimensions?
    And thanks for the info.
    JD Parts
    Damaged Threads in Wheel Hub - Thread Chaser or Tap - Or Call For Help-info.jpg
  4. #14
    Join Date
    Feb 2012
    Posts
    592
    Staunton, VA
    John Deere 3038E
    Thanks for all the ideas. I had not thought of running the bolt in from the back. I did. It tore up the bolt some and left the threads in the hub a bit shallow in places. But I took a new bolt and then ran it in from the front normally. It went in fairly smoothly and took the proper torque. So I think it's good.
    But I have learned to check mundane things like bolts and taps from now on. Making it a routine part of my pre-use check. I do learn from mistakes.
  5. #15
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I can see through the bolt hole so I imagine I can access it on the inside. The tires are loaded so I hope I can work through the bolt hole there. Handling loaded tires is hard. I have used taps in the past, but not in this kind of metal - in things like pipe fittings. I think I would call a neighbor who has more experience.
    The other issue is getting a tap of the exact size and thread angle. I have a bolt, but can find nothing online anywhere to give me the exact metric size and thread. I may have to take it to a local Fastenal shop and see if they can measure it for me.
    While at the Fastenal place pick up one of the bolt sizing and thread gauge identifiers They are about $8 and cover all the different SAE and Metric thread with thread pitch visual reference guide for each thread. I got one last time I was there getting some bolts for my tractor. Easy to use and even has a ruler for getting those mm lengths just right. It is just a little plastic jobby, but it works.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  6. #16
    Join Date
    Feb 2012
    Posts
    592
    Staunton, VA
    John Deere 3038E
    A Fastenal place only recently opened in town and I did visit. It is amazing all the stuff they have. Wish they were here when I was fishing for bolts for my old JD and some equipment. They have it all, and know what they're talking about. However, this time I just trotted down to the JD place and bought 6 wheel bolts for about $1.60 each, as I recall. I ran one in from the back to clean out the threads. The threads were visibly damaged, but enough left to hold. So I then ran a bolt in the normal way and it took normal torque... So all is good. Thanks.
  7. #17
    Join Date
    Dec 2012
    Posts
    93
    Ottawa, Ont
    Ariens
    before replacing the hub, if there is enough clearance from behind ( and the head of the bolt will not hit anything ) just buy a longer bolt (about an inch longer) and an acorn nut that matches your wheel profile... thread the bolt in from the back and tighten it down to lock it in place , the longer thread sticks out the front thru your wheel , put the nut on and torque it down.
  8. #18
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,345
    Northwest, WA
    I thought that was what Hoss was talking about in post #5 ?
    ::Sent from a standard desktop keyboard::
    My Photobucket
  9. #19
    Join Date
    Dec 2012
    Posts
    93
    Ottawa, Ont
    Ariens
    true ... but if the hub is too badly damaged, a longer bolt AND nut will save buying another hub.
  10. #20
    Platinum Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    553
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    You might look at thread restoring taps.
    Craftsman 48 pc. SAE & Metric Thread Restorer Kit
    If the threads are too badly damaged though, you might have to helicoil, or weld and tap.
Similar Threads
  1. Tap/thread sizes
    By BTackett in forum Build-It Yourself
    Last Post: 06-01-2012, 01:07 AM
  2. Wheel stuck on hub
    By PointyHairedBoss in forum Kubota Owning/Operating
    Last Post: 12-15-2010, 03:02 PM
  3. Can wheel hub be repaired?
    By ernemats in forum Parts/Repairs
    Last Post: 05-14-2010, 06:12 PM
  4. rtv wheel hub
    By jsl777 in forum ATVs & Utility Vehicles
    Last Post: 12-11-2009, 05:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
