Results 1 to 5 of 5
  1. #1
    Join Date
    Mar 2012
    Posts
    95
    Sioux City IA
    TYM T603 52' Ford 8N
    Default
    I guess that it has been a good reliable engine in my 2007 club car utv but it has had an annoying problem for several years. I cannot remember if it did it when it was new, but When you hit the gas it putts and spits for a while, like it is missing a cylinder, then takes off like every thing is just dandy. It's not a serious problem but it is absolutely horrible in the cold, you have to let it warm up for a few mins before it won't stall. It does it not as bad when you have been moving hay for an hour. It will not do it if you briefly put the choke in and out. Thanks for any reply that I get.
  2. #2
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Default Re: 20 hp honda v-twin
    Lack of fuel. Check out the whole system.
    Murph
  3. #3
    Gold Member
    Join Date
    Jan 2012
    Posts
    330
    Brookshire TEXAS
    LS R4047
    sounds like a low speed mixture problem. I don't know if that carb has adjustable low speed needle or not. but thats where I would start.
    2012 LS R4047 , FEL , Backhoe, kingkutter finish mower,68 " rachet rake, Titan skidsteer 72" root Grapple, JD 145,JD166 ........Dodge 3500 cummins, Kenworth w900l Cat powered ...
  4. #4
    Gold Member duroc's Avatar
    Join Date
    Feb 2012
    Posts
    340
    Michigan
    NH T1510 HST
    Quote Originally Posted by AroniaFarmer View Post
    Putting the choke in/out and it runs better is a good sign of fuel starvation (lean mixture). Before I got into the carb, etc., I would first try "Sea Foam" Sea Foam Motor Treatment, 16 oz - Walmart.com in the fuel tank to see if that helps clear it up.
    "If con is the opposite of pro, is Congress the opposite of progress?"
  5. #5
    Join Date
    Mar 2012
    Posts
    95
    Sioux City IA
    Default
    Quote Originally Posted by duroc
    I have some sea foam on hand. I'll give that a try before starting with the carb
Similar Threads
  1. Honda GX610 V-twin
    By tylermcfee in forum Honda
    Last Post: 01-07-2013, 12:05 PM
  2. Honda Rubicon and honda oil
    By maynard in forum ATVs & Utility Vehicles
    Last Post: 04-10-2007, 02:24 PM
  3. LT 1045 with a V-Twin????
    By spawndn72 in forum Cub Cadet Tractors
    Last Post: 05-04-2006, 08:39 AM
  4. Twin Calves
    By JESSE1 in forum Photos
    Last Post: 01-23-2006, 10:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
