Page 2 of 7 FirstFirst 12345 ... LastLast
Results 11 to 20 of 64
  1. #11
    Platinum Member Army grunt's Avatar
    Join Date
    Dec 2009
    Posts
    775
    Georga
    TC 30 Newholland
    Default Re: OK to leave my loader up?
    >>--->GROUND ALL BLADES, BOOMS,AN BUCKETS<<----<<<
    "Be who you are, say what you will, those that matter wont mind, those that mind don't matter".
  2. #12
    Join Date
    Feb 2011
    Posts
    1,743
    Trivoli, IL
    SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
    setter down on the ground.
    turn off tractor
    cycle all the hyd levers and 3pt hitch (act like you are raising and lowering FEL and 3pt hitch, with tractor off)
    this will reduce chance of someone thinking all is safe and hitting a lever and loosing a toe or being trapped.
    i am not a real fan of most cylinder lock outs, were the lock just lays down over a cylinder rod. most that i have seen, someone could nock into fairly easy and nock the lock out of place and have things come crashing down.
    treat the tractor like a industrial machinery when it comes to safety.
    Ryan
  3. #13
    TSO
    TSO is offline
    Gold Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    341
    SouthEast Michigan
    LS R4047 HST
    Default
    Point taken fellas, thanks
    Sent from my Motorola Photon using TractorByNet for Android
    LS R4047 HST (47hp Mitsubishi) 4x4 on R-4's
    QA 6' bucket, QA Forks, 6' Back Blade, 6' Rake, 66" Box Blade, 3pt Auger, Middle buster plow
    Hustler Z Diesel 66" ZTR mower (25 hp Shibaura)
  4. #14
    Join Date
    Jun 2006
    Posts
    1,242
    West Cascades Washington State
    PT 422
    Yes definitely issue, also try to keep the hydraulic rams retracted, if possible, to reduce rust issues.
  5. #15
    Advertiser sweettractors's Avatar
    Join Date
    Jul 2003
    Posts
    6,894
    Central Kentucky
    JD 6403 CHA-JD 3130 CHA
    Quote Originally Posted by cqaigy2 View Post
    X2. Ken Sweet
    http://www.sweetfarms.com/
    Sweet Farm Equipment LLC (Internet Sales, Shipping All States)
    Shipping Facility
    1815 Defries Rd., Canmer, Ky 42722 Toll Free 1-866-528-3323
    Ken Sweet sweet@scrtc.com
    Shipping Example: Can ship 800 lbs from Ky. to Dallas for $165
    The Northeast shipping corridor is a little more expensive.
  6. #16
    Join Date
    Apr 2004
    Posts
    617
    Try that here and you will have you ***** hauled into the office for your 1st and last warning.
  7. #17
    Gold Member
    Join Date
    Nov 2012
    Posts
    462
    mansfield,Il
    john deere
    As long as you have a safety brace should not be a problem , can't tell from your pictures . Lift the loader set the brace and set the loader on it . And those rods are not going to rust . We park machinery exposed and have had no problems . Those rods have a microscopic film of oil on them ,I have yet to see any rust .
  8. #18
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I think that you will find that if you tilt the bucket down so the cutting edge is straight up and down, it takes up about the same room as raising it up unless you can raise it to highest level. If you wish to keep it up high, then buy some cylinder lock sleeves to block it so it cant fall. Install them on the boom cylinders as many as you need, then lower the FEL to rest on these blocks. Just remember that you have to raise the FEL, remove the blocks before you can lower it down. Oh, and those things aren't cheap either.
    As for rusting the cylinder rods, just how long are we talking here, it takes a long time to remove the oil coating and rust thru the chromium plating. I have found that the biggest cause of pitting on cylinder rods is from iron contamination which causes rust to form and pit the coating. Normal storage of a few weeks or even months with rods exposed is not going to hurt it most especially if it is under a shed. We had no sheds to store our farm equipment and the disks would set with the cylinder rods exposed all winter out in the weather and we never had any rust on any of them, but they weren't laying in the dirt up against a pile of iron either. They were on the equipment at least 30" off the ground.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  9. #19
    Gold Member
    Join Date
    Nov 2012
    Posts
    462
    mansfield,Il
    john deere
    I am truly amazed at what I see here .
  10. #20
    Veteran Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    2,190
    Southern VT
    '10 Kioti DK 40se/hst
    Try removing whatever is attached to the loader and you will find some extra walking room in front of your QA plates when in the barn. I would NEVER leave a loader in the up position unless doing maintenance, and then only with something supporting it safely.
    Accidents are preventable, especially if one does not allow for potential known results to likely occur.
    Think ahead, be safe.
    Thanks for asking- it's a good question, but not worth the risk for a few feet of extra space. JMHO.
    2010 DK-40se/hst, Kioti KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower, 72" Ratchet Rake. HLA Series 2000 7' snowplow, Aquiline MPC Rear chains. Diamondplate aluminum canopy. Fit Rite Top-N Tilt hydraulics.
    Scag Wildcat: Kawasaki 26HP.
    Bunch of STIHL chainsaws : 011, MS192T, MS200T, MS180C, MS230, MS270(Wood Boss), 038 Farmboss (1986 Anniversary edition).
Similar Threads
  1. Leave it running?
    By GreatWhitehunter in forum John Deere Owning/Operating
    Last Post: 05-05-2009, 07:43 PM
  2. Replies: 6
    Last Post: 04-25-2008, 07:57 PM
  3. Leave it or love it!
    By Farmwithjunk in forum Related Topics
    Last Post: 11-08-2005, 01:56 PM
  4. Think I'll leave this alone for a while...
    By riptides in forum Photos
    Last Post: 11-11-2003, 07:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
