Results 41 to 50 of 64
02-14-2013, 09:52 AM #41Elite Member
- Join Date
- Apr 2008
- Posts
- 2,797
- Location
- Tractor
Re: OK to leave my loader up?
If the hydraulics were to fail as you're under the brush hog or the loader you'd be thinking differently... in a hurry.
As far as "Acceptable Risk" is concerned, I think risks such as the one's you cited are easily mitigated by planning ahead. You know you may encounter fence wire when brush hogging so having something to prop it up with (just in case) would mitigate that risk, with the same being true for working on the loader..
02-14-2013, 05:31 PM #42Super Member
- Join Date
- Sep 2000
- Posts
- 6,262
- Location
- Eastern NY
- Tractor
- Case 885, JD 730D, Oliver 660 Ford 4000
If you can read this, thank a teacher.
If you are reading this in English, thank a veteran.
02-14-2013, 06:03 PM #43Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I am with being safe as much as the next guy, but come on folks much of what you are siting has about as much chance of happening as getting hit by a meteorite. Lifting up your FEL to drive a lawnmower out from under it and having it accidently blow 2 hydraulic hoses and fall on you is pretty slim to none chance. Having hydraulic failure is also pretty slim to none chance. I would almost guarantee that if someone is trapped under a piece of hydraulic equipment, it was because of human error, someone let it down on them, not because the hoses blew or the earth suddenly increased gravity to the extent that the hydraulics could no longer hold the equipment up.
After saying that, I do have a 4x4 block that I have especially cut to set up under my bush hog if I need to work on it but this was because my old Yanmar leaked down. I would trust my LS to hold the 3 PH up for months and not leak down which it has done many times. If you have kids, grandkids, wife, etc that wander around and mess with your tractors, DO lower, lock, take precautions to keep them from hurting you or themselves. I have no issue leaving my 3 PH raised if I want or the FEL if I want which by the way has to be raised up to get to the grill protector which has to be moved out in order to raise the hood. You can do it with it down but you have to be a contortionist and it is a head knocker for walking around so I raise mine up if I need to be under the hood and don't worry about it falling on me because no one is out playing around in the cab (I could lock it up if it were ) To me that is Acceptable RISK. NOW would I crawl under my raised disc to work on it, **** no even though I know it isn't going to fall, the consequences are too great if it did, so that is not an acceptable risk.
Working on the tractor with FEL up, no risk as if it did come down it is not a pinch factor (unless one were standing under the bucket which there is no reason to do that), just tight quarters.2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
02-14-2013, 06:05 PM #44New Member
- Join Date
- Feb 2013
- Posts
- 5
- Location
- Colebrook NH
- Tractor
- kubota L3130....FEL...brush hog...grapple...JD350 dozer
02-14-2013, 06:38 PM #45
LOL, you guys are cracking me up. I'm always a safety first guy too, once again, the point of this thread was addressing any concerns 4 damage and wear & tear to my loader, if I leave it up for any length of time.
Sent from my Motorola Photon using TractorByNet for AndroidLS R4041 Shuttle (41hp Mitsubishi) 4x4 on R-4's
QA 6' bucket, QA Forks, 6' Back Blade, 6' Rake, 66" Box Blade, 3pt Auger, Middle buster plow
Hustler Z Diesel 66" ZTR mower (25 hp Shibaura)
02-14-2013, 07:03 PM #46Elite Member
- Join Date
- Sep 2009
- Posts
- 3,185
- Location
- Murray, KY
- Tractor
- 265 MF / JD 310B Backhoe
Just passed by a job site they had it parked for the night with arms raised and loaded with scaffold boards, etc.
My welding shop owner's BH did belong to his late BIL before the FEL came down and crushed him when he was working on it.
He was using ropes to make it go up and down while he was under it and the user designed rope control system failed for some reason.
02-14-2013, 07:07 PM #47Elite Member
- Join Date
- Apr 2008
- Posts
- 2,797
- Location
- Tractor
02-14-2013, 07:42 PM #48Gold Member
- Join Date
- Oct 2010
- Posts
- 322
- Tractor
- 08 Cub Ex3200
This is exactly what should be done if you plan on doing something under the bucket, even just driving under it for a split second.
Its your life, only you can determine how you go through it. I for one dont want to be found under some implement hours/ a day or two later suffocating under its weight or bleeding a slow death. You never know, thats the point. Even if its just something stupid like a log laying there or a rock thicker than your body is all it could take to save your life. I've had a lot of oh **** moments to the point I know when its not worth it or thought out how it could have went. I've been lucky and it opened my eyes.. I know you dont think it can happen or the chances are slim, but the bad luck floats around and lands on someone everyday! Im sure we could all share stories of seeing bad things happen, which really leads me to wonder why dont you guys think its all that unlikely this stuff couldnt happen to you?
No, it wont damage anything. Everyone is just addressing how dumb it is to do so without making sure it cannot come down without some sort mechanical locking device.
02-14-2013, 08:15 PM #49Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
02-14-2013, 08:31 PM #50Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
I worked heavy construction for 45 years (never injured more than a band aid fix)and saw a few folks killed and a few hurt pretty bad. Never was it equipment failure, it was always lack of attention to ones surroundings either by the person injured or someone else, like a person dropping something onto someone else or someone doing something so idiotic that there was no way they wouldn't suffer from the consequences. Pay attention, think "what if", make preparations for worst case and then do the job. The most dangerous place in the world is your bathtub but I am not going to stop bathing because of it, but I also am not going into a room full of gun powder and strike a match. Will I walk under an un-blocked hydraulic controlled FEL, absolutely as long as no one is in close proximity to the controls. I trust the equipment not to fail, but I wouldn't trust anyone to not touch the controls or hit the wrong one. Would I walk under something with ropes or cables holding it up, no way, I've seen them break without warning.
Similar Threads
Leave it running?
By GreatWhitehunter in forum John Deere Owning/OperatingReplies: 20Last Post: 05-05-2009, 07:43 PM -
On a JD 2320 can you leave the loader on and drive on and off the 62 mmm deck?
By JDGREEN1 in forum John Deere Owning/OperatingReplies: 6Last Post: 04-25-2008, 07:57 PM -
Leave it or love it!
By Farmwithjunk in forum Related TopicsReplies: 4Last Post: 11-08-2005, 01:56 PM -
Think I'll leave this alone for a while...
By riptides in forum PhotosReplies: 0Last Post: 11-11-2003, 07:28 PM
