Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    New Member
    Join Date
    Feb 2013
    Posts
    5
    schoharie ny
    johndeere 790 compact
    Default 790 JOHNDEERE
    Bottom radiator hose stays cold top hose is hot tractor does not overheat???any ideas thanks Dee
  2. #2
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Default Re: 790 JOHNDEERE
    Quote Originally Posted by DEEMEESE View Post
    Bottom radiator hose stays cold, top hose is hot, tractor does not overheat???, any ideas???, thanks Dee
    Sounds like it isn't warmed up enough to open the thermostat.
    Are you having any problems with it ?
    ::Sent from a standard desktop keyboard::
    My Photobucket
  3. #3
    Gold Member pedalstomper78's Avatar
    Join Date
    Aug 2010
    Posts
    450
    Ohio
    Case/IH DX33
    Radiator getting warm also? What is the gauge on the tractor saying?
    The forums are a great place to find information....but also a great place to find speculation. Only you can determine the real problems with your tractor. We're here to help you find the correct way to do it.
  4. #4
    New Member
    Join Date
    Feb 2013
    Posts
    5
    schoharie ny
    Hey thanks No problems ran it for a half hour or more loadin firewood,,,felt the hose cold on the bottom warm on top hose..Reason i checked i had to add alittle antifreeze to the overflow resevoir ??but no overheating problems ?/
  5. #5
    New Member
    Join Date
    Feb 2013
    Posts
    5
    schoharie ny
    Temp gauge stay in the green way down in the green never gets even halfway up the guage
  6. #6
    Elite Member
    Join Date
    Dec 2002
    Posts
    4,711
    Foster, RI
    Mahindra 3016
    This is quite common. I believe the JD stat opens at 160*. I changed my stat recently and my bottom hose is still cool to the touch. My top hose isn't that hot either.
  7. #7
    New Member
    Join Date
    Feb 2013
    Posts
    5
    schoharie ny
    Thanks may be that ,,,
  8. #8
    Join Date
    Aug 2010
    Posts
    450
    Ohio
    Case/IH DX33
    I would go with the tractor isn't running that hard and is just using a wee small bit of the capacity of the radiator. Run it and have fun. The only way that I would be concerned was if it was heating up on ya.
  9. #9
    Veteran Member crashz's Avatar
    Join Date
    May 2005
    Posts
    1,234
    NH & Upstate NY
    John Deere 770, Kubota L2501
    Default
    My 770 does the same thing. I replaced the thermostat, coolant, temp sensor and hoses. Still, it only creeps up to about 1/4 of the way when working in the summer.
    I've had a wonderful evening, but this wasn't it. ~ Groucho Marx
  10. #10
    Elite Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,898
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    Welcome to the forum Dee.
    Never had any troubles with my 790 in the summer, it runs just fine!! Now the operator has nearly croaked a time or two in the 98 deg weather lol. To be more serious, I've never felt the hoses on mine after running it a while, but now you got me wondering and I will check it the next time I've had it running for a while.
    Btw, in case you aren't aware, there's a simple little trick you can do to the 790's to increase the hydraulic pressure. The hydraulic relief valve is set to 2000psi at the factory, but it can be safely increased to 2500 psi and give you a little more lift capacity on the loader (if yours has one) and on the three pt lift too. I did it to mine, and it makes a difference. If you're interested, there are several threads on it and you can use the search function and you should be able to find some of them. Basically it involves adding some shims that you can get at your JD dealer for about $10 bucks.
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, 5 1/2ft Cultipacker, 5ft Sitrex finish mower, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, Leinbach #11 Field Cultivator, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    It's not how slow you mow... it's how well you mow slow!!
Similar Threads
  1. 2950 johndeere
    By 2950johndeere in forum John Deere Ag Tractors
    Last Post: 10-09-2011, 08:05 AM
  2. JohnDeere 112
    By nobody cares in forum John Deere Owning/Operating
    Last Post: 09-07-2011, 08:45 AM
  3. Johndeere LT 155
    By Johndeere3720 in forum General Lawn & Garden
    Last Post: 06-25-2009, 09:36 PM
  4. Johndeere 4010
    By Johndeere3720 in forum Buying/Pricing/Comparisons
    Last Post: 03-25-2009, 05:59 PM
  5. JohnDeere x475
    By brittgers in forum John Deere Lawn & Garden
    Last Post: 03-14-2006, 08:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
