Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    Massey Ferguson GC2400
    Default Re: Ford 1700 Clutch
    Quote Originally Posted by schneidvt View Post
    I am in the process of replacing the clutch on a 1500 at the moment. I went ahead and drained all the fluids before starting and removed the lines. I figured it would be better than potentialy crimping or bending them when I split the case. I started a thread about it a couple weeks ago that you can take a look at (Ford 1500 clutch replacement).
    Jason
    His thread is here:
    http://www.tractorbynet.com/forums/p...placement.html
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  2. #12
    New Member
    Join Date
    May 2011
    Posts
    5
    Snohomish, WA
    Ford 1700
    Default
    So the tractor is split. The pressure plate levers failed. They must have been out of adjustment. Does anyone know how to get the flywheel off.
  3. #13
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    The flywheel should have 6 bolts or so in the center that bolt it onto the crankshaft. If you've removed the 4 to 8 bolts that hold the pressure plate onto the flywheel(and remove it) you should see the bolts I'm talking about. Like this: First picture is the pressure plate, second is the flywheel........these pics are NOT from your machine.
    Attached Thumbnails Attached Thumbnails Ford 1700 Clutch-0996b43f8021ddc3-jpg   Ford 1700 Clutch-0996b43f80e430ee-gif
    Don
Similar Threads
  1. Ford 1700 and Ford 1710 parts machines - now what?
    By bspeedy in forum New Holland Buying/Pricing
    Last Post: 06-04-2015, 12:47 PM
  2. Ford 1700 clutch adjustment
    By 284 International in forum New Holland Owning/Operating
    Last Post: 12-09-2011, 02:10 PM
  3. Ford 1700 engine stalls when clutch is let out Can anyone help?
    By wilsonbus in forum Ag Tractors & Machinery
    Last Post: 07-15-2010, 10:46 AM
  4. ford 1700 clutch problem
    By Bickley Valley Cyril in forum New Holland Owning/Operating
    Last Post: 01-03-2010, 09:13 AM
  5. Ford 1700 Clutch Replacement
    By Piper Pacer in forum New Holland Owning/Operating
    Last Post: 02-05-2009, 02:25 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
