Page 4 of 10 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 92
  1. #31
    Join Date
    Oct 2012
    Posts
    628
    Southern Utah
    John Deere 3120
    Default Re: Tractor related bonehead move of the month-I'll start
    I'm sure glad this subject is tractor-specific. Haven't had enough seat time with mine to accomplish anything boneheaded (yet), however, if expanded to trucks, street & dirtbikes my input might crash the server - pun not intended.
  2. #32
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,091
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Quote Originally Posted by troutsqueezer View Post
    Harbor Freight sells a body/fender repair kit for cheap. Worked beautifully on my tractor hood, fenders, roof.
    Search results for: 'body fender'
    I have used these tools to repair a surprisingly similar dent. Take your time, do the bondo skim coat, repaint and re-decal and you'll feel better.
    You can also watch online videos on how to use the body tools as well.
    May I be the kind of person my dogs think I am,
  3. #33
    Elite Member The kid's Avatar
    Join Date
    Apr 2012
    Posts
    4,166
    Middle Tennessee
    1965 135 gasser, 1967 135 diesel
    Quote Originally Posted by sd455dan View Post
    Well I feel a little better Knowing that I'm not the only one....Have removed the sheet metal and getting ready to look at trying to straighten the hood Attachment 305636 Here's the sheet metal ,couldn't stand to leave it on the tractor looking like that.
    If you have an Harbour Freight close by they have a body tool kit pretty cheap. or... Use a ballpin hammer and a anvil vise ought to do it. I've actually used my box scraper to bang against straightening boo boo's out. Now your tractor has character.
  4. #34
    Platinum Member JD 4520's Avatar
    Join Date
    Apr 2011
    Posts
    851
    NW WA
    John Deere 4520
    Default
    Quote Originally Posted by /pine View Post
    Many owners of tractors with quick attach loaders have creases across their hoods...
    Fortunately I haven't had this happen...what are you referring to that happens with quick attach loaders?
    Gary
    JD 4520, 400X FEL, Frontier Front Blade, Box Blade, Rotary Cutter, Landscape Rake, 48" Wildkat Grapple and PHD
  5. #35
    Veteran Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    Rhino 554, JD550G dozer Gilson MTD riding mowers Ford 3000-Sold
    I see I'm not alone, sometimes its just a momentary thing, like looking for a dripping hydraulic line instead of watching the loaders movement-and of course after crushing the hood there wasn't a drop of oil from the reconnected line.!!! Thanks for the body work suggestions , I've already painted a few cars, but this chinese tractors sheet metal is like .060 thick, its much harder to work than most cars sheet metal, sooo something special is in order and since the tractor was involved in the first place why not make it do part of the workTractor related  bonehead move of the month-I'll start-rhino-body-work-003-jpg hey that worked pretty good, That gives me another idea..Tractor related  bonehead move of the month-I'll start-rhino-body-work-004-jpg
  6. #36
    Elite Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    I have that exact same wood splitter. Check that the return hose going to the filter doesn't chafe on the work table bracket just above it.
  7. #37
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    Quote Originally Posted by vtsnowedin View Post
    l Thanks, I'll check - looks like about 3/8" clearance, ok so far, although 2 years ago I did see a recall for this model at another store that sells them. It was for a sticking hydraulic valve problem, the serial#s were from a different run than the one we purchased.. Has been trouble free.
  8. #38
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    I may have pounded my bracket down a bit by dropping big blocks of rock maple on it. Other then that it works fine but it is relatively new yet.
  9. #39
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,365
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    We have the same model but it might have different stickers. On ours, 5 or 6 of the bolts that hold the "table" on each side have snapped. Debating if we want to just fix it, or make up a log lifter...
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  10. #40
    Join Date
    Mar 2010
    Posts
    82
    VA
    JD 1026R
    Quote Originally Posted by JD 4520 View Post
    I think he's referring to using the loader bucket or forks without having put in the retaining pin. I spent 3 hours fishing my forks out of a dumpster that way. That is the funny story, the unfunny story that happens is people curling with the load up high and the bucket unpinned... and having everything roll back and fall on them since the bucket is free to pivot.
    JD1026R - 53" FEL, 60D MMM, 5' RB, 5' LR, 4' BB, 260 BH, 4' Tiller, TSC PHD, 5' Grader
Similar Threads
  1. Not really tractor related -
    By LJH in forum Photos
    Last Post: 11-03-2012, 07:42 AM
  2. Not tractor related, but still hydraulic
    By handirifle in forum Hydraulics
    Last Post: 02-04-2012, 07:07 PM
  3. Ford 1510 lug nuts bonehead report
    By Marveltone in forum New Holland Owning/Operating
    Last Post: 12-02-2010, 06:41 AM
  4. HELP How do you Start/ Move a BX23 with a bum neutral start switch?
    By LBrown59 in forum Kubota Owning/Operating
    Last Post: 11-12-2007, 07:28 AM
  5. Dealer Help..Dealer is a Bonehead! 1428v vs 1500 series
    By tractorbroad in forum Massey Ferguson Buying/Pricing
    Last Post: 04-23-2006, 04:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
