Page 6 of 10 FirstFirst ... 3456789 ... LastLast
Results 51 to 60 of 92
  1. #51
    Elite Member
    Join Date
    Sep 2009
    Posts
    2,680
    Up State S.C.
    AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
    Default Re: Tractor related bonehead move of the month-I'll start
    Quote Originally Posted by vtsnowedin View Post
    Mine is worth every penny times five. Hope you have the same results.
    I'm not sure. I'll have to go and ask her.
  2. #52
    Silver Member DarrylH20's Avatar
    Join Date
    Dec 2009
    Posts
    188
    Epsom NH
    09 1533 Massy
    Quote Originally Posted by sd455dan View Post
    Here's an update on the body work progress-this a different view after the damage, the home made Attachment 305875Rhino label jinxed me I think
    the hood so far-the metal was stretched so bad that hammer dolly/torch- wet towel wasn't enough. Finally used a 3" cut off tool then pressed it on the log splitter then mig welded and ground it down. anyway here's how it looks so far , Thanks for the input, and you guys are right on the mark there's definitely bondo or Short strand fiberglass in its futureAttachment 305878
    That looks like its going along great
  3. #53
    Veteran Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    Rhino 554, JD550G dozer Gilson MTD riding mowers Ford 3000-Sold
    Quote Originally Posted by DarrylH20 View Post
    Thanks- still working on it when I can, here's the hood now Tractor related  bonehead move of the month-I'll start-rhino-hood-body-work-013-a getting closer...
  4. #54
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,796
    Looks great!
  5. #55
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,102
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Wow, that looks great. Get the correct decals now to seal the deal.
    May I be the kind of person my dogs think I am,
  6. #56
    Gold Member
    Join Date
    Nov 2009
    Posts
    338
    Grimes County, Texas
    Kubota GL 3940
    My last bonehead move with the tractor happened while disconnecting the shredder. Got the three links unpinned and off. Cell phone rang so answered it. After the call, jumped on the tractor and pulled away from the shredder separating the shaft which was still connected! In the woods with nobody around but still felt so dumb I caught my self looking around to see if any one had seen. Lol.
    Putting that thing back together is a three handed job! At the time, just couldn't see myself asking for help.
    Kubota GL 3940, FEL w/ssqa, third function valve, grapple, 6' Landpride cutter, 6' landscape rake, 6' box blade, post hole auger
    "Knowledge is knowing the street is one way. Wisdom is still looking both ways before crossing"
  7. #57
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    Quote Originally Posted by sixdogs View Post
    I had considered that- but the decals are not available for these older Rhino International tractors, Farm Boys stocks and sells most every part to keep these (Shanghai) 554 tractors running, and I'm happy with that, So the decals have been taped off and hopefully everything will work out..
  8. #58
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,972
    KY @ TN line
    2011 LS R3039
    That hood came out really good..
  9. #59
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,102
    Central Ohio
    Yeah, taping decals works fine and I do it myself.
  10. #60
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,899
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Quote Originally Posted by Singalo View Post
    For acute dents, would adding a bit of hit from a torch help to bring the metal back into line while beating it back with body tools?
    Heat on sheet metal is just going to warp it up. Best to cold straighten sheet metal. Structural members can be heated and beat if they are too strong to bend cold
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
Similar Threads
  1. Not really tractor related -
    By LJH in forum Photos
    Last Post: 11-03-2012, 07:42 AM
  2. Not tractor related, but still hydraulic
    By handirifle in forum Hydraulics
    Last Post: 02-04-2012, 07:07 PM
  3. Ford 1510 lug nuts bonehead report
    By Marveltone in forum New Holland Owning/Operating
    Last Post: 12-02-2010, 06:41 AM
  4. HELP How do you Start/ Move a BX23 with a bum neutral start switch?
    By LBrown59 in forum Kubota Owning/Operating
    Last Post: 11-12-2007, 07:28 AM
  5. Dealer Help..Dealer is a Bonehead! 1428v vs 1500 series
    By tractorbroad in forum Massey Ferguson Buying/Pricing
    Last Post: 04-23-2006, 04:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
