Page 7 of 10 FirstFirst ... 45678910 LastLast
Results 61 to 70 of 92
  1. #61
    Veteran Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    2,061
    North Idaho
    Rhino 554, JD550G dozer Gilson MTD riding mowers Ford 3000-Sold
    Default Re: Tractor related bonehead move of the month-I'll start
    Quote Originally Posted by sd455dan View Post
    I had considered that- but the decals are not available for these older Rhino International tractors, Farm Boys stocks and sells most every part to keep these (Shanghai) 554 tractors running, and I'm happy with that, So the decals have been taped off and hopefully everything will work out..
    UPDATE TIME: IT'S BLUE.... (Equipment enamel FORD BLUE) figured this is pretty close to one of the 2 colors that was on it, and my 3000 could use some touch up to, so here we go-Tractor related  bonehead move of the month-I'll start-rhino-new-blue-paint-004-a and if this gloss dies down (never used this type of paint before) in the next 24 hours I'm going to clear it with some catalyzed urethane... now to clean up this messy garage!!
  2. #62
    Elite Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    Nice shine. Obviously not your first attempt at painting.
  3. #63
    Super Member
    Join Date
    Dec 2007
    Posts
    9,874
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Quote Originally Posted by vtsnowedin View Post
    That's really shiny. Was hardener added?
    May I be the kind of person my dogs think I am,
  4. #64
    Silver Member DarrylH20's Avatar
    Join Date
    Dec 2009
    Posts
    188
    Epsom NH
    09 1533 Massy
    That came out awesome
  5. #65
    Join Date
    Oct 2012
    Posts
    2,061
    North Idaho
    Quote Originally Posted by sixdogs View Post
    Thanks everyone, No there's no hardener in the paint, it's just car quest tractor Alkyd enamel thinned with about 1 oz. of naptha, and today it's still shiny but it's not fully cured, 45 degrees in the garage this morning so I'll give it another day. I'm concerned about the ultimate hardness and abrasion resistance, the guys said a lot of painters use the equipment paint and then shoot it with a catalyzed urethane clear, which I have used before and still have enough to shoot it with, also thought I might pull the masking off the decals and seal them in at the same time..
  6. #66
    Veteran Member Jay4200's Avatar
    Join Date
    Nov 2005
    Posts
    2,011
    Hudson/Weare, NH
    L4200GST w/ LA680 & BX2200D w/ LA211
    Had been working on my Rhino tractor cleaning a magnet that's in the main intake feed line, before the hydraulic pump for the loader. Had the hood tilted forward for access and decided to cycle the loader to check for leaks, you can probably guess what happened next....
    Going to try to repair the damage. Hope no one else has done anything like this??Attachment 305608
    I see so many tractors that have that same dent/crunch on Craig's List. I've always wondered how it was done. Now, I know!! Awesome.
    Edit: Sa-weet repair job. Nice work.
    JayC
  7. #67
    Join Date
    Oct 2012
    Posts
    2,061
    North Idaho
    Wow, that looks great. Get the correct decals now to seal the deal.
    Well after dTractor related  bonehead move of the month-I'll start-rhino-decal-repair-001-jpge taping the decals I realized just how bad the one side looked so using the suggestions of taking advantage of harbor freights products- broke out the $8 airbrush kit ,sprayed some fiz can black into a cup , loaded up the little airbrushTractor related  bonehead move of the month-I'll start-rhino-decal-repair-003-jpg and this is how it looks now,by no means perfect but better than it was Tractor related  bonehead move of the month-I'll start-rhino-decal-repair-004-jpg
  8. #68
    Super Member
    Join Date
    Dec 2007
    Posts
    9,874
    Central Ohio
    The decals look great. I don't understand the whole airbrush thing but $8 sounds like Harbor Freight. Do you mix the paint special or thinner?
  9. #69
    Join Date
    Oct 2012
    Posts
    2,061
    North Idaho
    Thanks, lets see the paint part of the airbrush- I couldn't find any liquid black enamel in a can,except for oil based paint, and the Tractor related  bonehead move of the month-I'll start-airbrush-001-jpghobby store was closed, I had hoped to get testors model paint so after striking out in town I just took a can of Rustoleum flat black and sprayed it into a paint mixing cup until there was enough liquid to fill the air brushes cup no mixing or thinner. As for the decal, masked off the new blue paint then just enough of each letter or # and used the air brush to touch up the black surround.
  10. #70
    Veteran Member DABSGT's Avatar
    Join Date
    Nov 2011
    Posts
    1,191
    Connecticut
    John Deere 2032r
    Default
    Looks great. Good idea!
    Sent from my iPad using TractorByNet
Similar Threads
  1. Not really tractor related -
    By LJH in forum Photos
    Last Post: 11-03-2012, 08:42 AM
  2. Not tractor related, but still hydraulic
    By handirifle in forum Hydraulics
    Last Post: 02-04-2012, 08:07 PM
  3. Ford 1510 lug nuts bonehead report
    By Marveltone in forum New Holland Owning/Operating
    Last Post: 12-02-2010, 07:41 AM
  4. HELP How do you Start/ Move a BX23 with a bum neutral start switch?
    By LBrown59 in forum Kubota Owning/Operating
    Last Post: 11-12-2007, 08:28 AM
  5. Dealer Help..Dealer is a Bonehead! 1428v vs 1500 series
    By tractorbroad in forum Massey Ferguson Buying/Pricing
    Last Post: 04-23-2006, 05:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
