Page 8 of 10 FirstFirst ... 5678910 LastLast
Results 71 to 80 of 92
  1. #71
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,200
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Default Re: Tractor related bonehead move of the month-I'll start
    So do you need a special paint to airbrush or just normal auto or tractor paint?
    May I be the kind of person my dogs think I am,
  2. #72
    Veteran Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    2,119
    North Idaho
    Rhino 554, JD550G dozer Gilson MTD riding mowers Ford 3000-Sold
    Quote Originally Posted by sixdogs View Post
    Well the black I used was literally shot out of the can in the picture into a one quart cup until there was enough to fill the cup for the air brush and it was thin enough to spray.. I'm pretty sure professional air brush artists that paint flames and do graphics with quality airbrushes use automotive basecoat urethane which is reduced, it dries really fast, that way they can re-tape or shoot multiple colors on top of each other then they shoot an activated or catalyzed clear over the work
  3. #73
    Join Date
    Oct 2012
    Posts
    2,119
    North Idaho
    Quote Originally Posted by sd455dan View Post
    Thanks everyone, No there's no hardener in the paint, it's just car quest tractor Alkyd enamel thinned with about 1 oz. of naptha, and today it's still shiny but it's not fully cured, 45 degrees in the garage this morning so I'll give it another day. I'm concerned about the ultimate hardness and abrasion resistance, the guys said a lot of painters use the equipment paint and then shoot it with a catalyzed urethane clear, which I have used before and still have enough to shoot it with, also thought I might pull the masking off the decals and seal them in at the same time..
    Another update lost some gloss on the color decided to go ahead and clear everything -started with the side panel on the first coat of clear everything looked great, but after waiting for the clear to (flash) the clear bit into the color coat and it started to separate. At this point I can't recommend clearing the color coat of this paint, it's very probable that had this been painted in the summer and more curing time allowed / no problem would have resulted anyway more sanding and repair to get back to where I just was just yesterday, - I think this thread is named right
  4. #74
    Join Date
    Dec 2012
    Posts
    1,199
    Ottawa, Ont
    Ariens
    it depends on the paints you used ...
    enamel (with reducer) can go over lacquer ... but not the other way , the thinner in lacquer will dissolve the enamel (unless baked on)
    your clear coat will probably do the same to any enamel (found in most spray bombs). you can use water based clears if you want to ...
    car enamel ( without hardener) normally takes over 30 days to fully cure by itself ... it skins within the hour, then the VOC's slowly escape thru the hardening surface skin. the thicker the surface becomes, the longer it takes to fully dry.
  5. #75
    Join Date
    Oct 2012
    Posts
    2,119
    North Idaho
    Tractor related  bonehead move of the month-I'll start-rhino-paint-side-panel-after
    Quote Originally Posted by jaotguy View Post
    Well this was actually catalyzed urethane over enamel .
    I have already removed the cleared over enamel- the fact that I could heat it with a heat gun and remove it right down to the urethane primer/surfacer with just a bondo spreader pretty much proves to me that there is no way the equipment enamel was anywhere near fully cured, that being said the guys I get my paint from have at least a couple of autobody shops that routinely use this equipment enamel and clear coat it with this urethane clear. I shot a couple spare test pieces in the enamel, later this summer I'll try shooting it with the clear just to prove to myself whether or not this works, and if the plan is to have a really high gloss sheetmetal on another piece of equipment, it will be the matched urethane basecoat/clearcoat used next time..for now every thing that needed it has been repainted Tractor related  bonehead move of the month-I'll start-rhino-paint-side-panel-after Now to get the sheetmetal back on the tractor..
  6. #76
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,796
    UPDATE TIME: IT'S BLUE.... (Equipment enamel FORD BLUE) figured this is pretty close to one of the 2 colors that was on it, and my 3000 could use some touch up to, so here we go-Attachment 308013 and if this gloss dies down (never used this type of paint before) in the next 24 hours I'm going to clear it with some catalyzed urethane... now to clean up this messy garage!!
    Looks great!
  7. #77
    Join Date
    Aug 2008
    Posts
    1,555
    Barrington, NH
    Bobcat CT230
    Has anyone considered putting a couple of those metal curb feelers on your ROPS as a last second warning system entering or exiting your garage/low barn door?
    I suppose you could get all high tech and use one of those range finder warning systems you can retrofit onto cars with too.
  8. #78
    Join Date
    Dec 2012
    Posts
    1,199
    Ottawa, Ont
    Ariens
    if you are worried about head clearance, it would be too late by the time you stopped..
    if you just want position indicators ( front to back and side to side for parking )
    the cheaper way is to hang balls on strings from the ceiling.....leave 'em just about eye height when in the seat. .... and drive / park between them.
  9. #79
    Join Date
    Oct 2012
    Posts
    2,119
    North Idaho
    The Rhino is finally back together, Tractor related  bonehead move of the month-I'll start-rhino-finished-002-jpgTractor related  bonehead move of the month-I'll start-rhino-finished-003-jpg
  10. #80
    Veteran Member DABSGT's Avatar
    Join Date
    Nov 2011
    Posts
    1,205
    Connecticut
    John Deere 2032r
    Default
    The Rhino is finally back together, <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=308899"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=308900"/>
    Looks real nice, good work.
    Sent from my iPad using TractorByNet
Similar Threads
  1. Not really tractor related -
    By LJH in forum Photos
    Last Post: 11-03-2012, 07:42 AM
  2. Not tractor related, but still hydraulic
    By handirifle in forum Hydraulics
    Last Post: 02-04-2012, 07:07 PM
  3. Ford 1510 lug nuts bonehead report
    By Marveltone in forum New Holland Owning/Operating
    Last Post: 12-02-2010, 06:41 AM
  4. HELP How do you Start/ Move a BX23 with a bum neutral start switch?
    By LBrown59 in forum Kubota Owning/Operating
    Last Post: 11-12-2007, 07:28 AM
  5. Dealer Help..Dealer is a Bonehead! 1428v vs 1500 series
    By tractorbroad in forum Massey Ferguson Buying/Pricing
    Last Post: 04-23-2006, 04:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
