Page 9 of 10 FirstFirst ... 678910 LastLast
Results 81 to 90 of 92
  1. #81
    Silver Member DarrylH20's Avatar
    Join Date
    Dec 2009
    Posts
    188
    Epsom NH
    09 1533 Massy
    Default Re: Tractor related bonehead move of the month-I'll start
    Wish I could do work like that. Looks like new.
  2. #82
    Super Member
    Join Date
    Dec 2007
    Posts
    9,873
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Quote Originally Posted by DarrylH20 View Post
    Agreed. You should post photos of other work you have done.
    Actually, there were two bad moves and you recovered perfectly from both of them.
    May I be the kind of person my dogs think I am,
  3. #83
    Join Date
    May 2008
    Posts
    1,670
    Prince Edward Island, Canada
    Kioti DK45SC
    If it were me, this would be the most dangerous time. After doing a great repair job like that, for sure I would manage to ding (or totally smash) it within a week! It's some sort of special talent of mine, I guess.
  4. #84
    Veteran Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    2,060
    North Idaho
    Rhino 554, JD550G dozer Gilson MTD riding mowers Ford 3000-Sold
    I know what you mean, the panels that were repainted had only been drying for 24 hours since they were shot, but I just wanted everything back together so I handled them from the inside and assembled everything. The wife told me to wait (sound of reason) another day for reassembly for parts to dry. If I didn't have a cherry picker then I would have waited but by carefully maneuvering the hood assembly into position managed to get it mounted without scratches. I know there's going to be an Argh or ooops the first time a bucket full of dirt/rock looses a few chunks over the back wall of the bucket and falls on the hood. Tractors are meant to be used and that's what's ahead for this one, but since my dad bought this tractor new, (he passed away about a year ago) I will do my best to take good care of this Rhino because my dad always took good care of it... Thanks everyone for all the great posts, I've enjoyed them and even though a bone headed move on my part started this, I really have enjoyed working on this particular repair and thread
  5. #85
    Join Date
    Oct 2012
    Posts
    2,060
    North Idaho
    [QUOTE=sixdogs;3238084]Agreed. You should post photos of other work you have done.
    (Well I wasn't going to- but since you asked here's the last car i did, bought a a police seizure saleTractor related  bonehead move of the month-I'll start-geo-005-jpgsomebody decided to dance on the roof, needed a clutch ,put that in then found there was no first gear,and by no first gear I mean someone had removed it from the transmission that explained the burned clutch that was in it. Got another 5 speed for it and did a little bodywork, anyway- this paint is the sister to the clear I tried to use, but is a catalyzed single stage urethane, it is one of the best values for its gloss, cost, and durability, at least in my opinion..)
  6. #86
    Super Member
    Join Date
    Dec 2007
    Posts
    9,873
    Central Ohio
    sd455dan--That's pretty impressive work and really something to be proud of. Always post this kind of workmanship and more photos, including close-ups so we can learn from it. I learned a lot from your hood effort.
    Is the catalyzed single stage urethane an isocyanite product that I need supplied air for or is a respirator OK? How about the clearcoat?
  7. #87
    Silver Member mowin's Avatar
    Join Date
    Sep 2012
    Posts
    123
    upstate ny
    JD 3320
    Your dad would be proud..Good job.
  8. #88
    Join Date
    Jun 2012
    Posts
    133
    Evergreen CO
    Ford 8N, Kubota L4240
    RTII,
    Your posting time was off a little: Unfortunately, just as you posted, the thread was hijacked. With respect to your "bonehead" action, I have done the same thing, also. I have finally trained myself to restart the thought sequence every time I get an interruption. I'm especially careful when I'm doing electrical work. (That's another story, not to be shared here.) When working with stuff like tractors, chainsaws, electrical circuits, oxy-acetylene torches, I'm trying to make sure I follow a fairly rigorous set of procedures. One of the best steps is to require a total process start-over, whenever there is an interruption. Thanks for the post, and thanks for the reminder.
    Thread theft occurs all the time. I think almost all posters try not to do it. However, on most posts, there is new information that one or more of us wants to pursue. Sometimes in our enthusiasm we forget to start a new thread. It's one of the smaller "bonehead" actions we all make.
    Anyway, thanks for your post. It got me thinking again.
    PMH
  9. #89
    Join Date
    Oct 2012
    Posts
    2,060
    North Idaho
    Quote Originally Posted by sixdogs View Post
    thanks, some people will tell you that you can use a dual cartridge respirator for organic particulates, that should work for non catalyzed tractor enamel that I finished with, but for isocyanate paints you need a fresh air supplied respirator. I did on a couple occaissions in the past shoot iso 2 k urethane in a garage built booth, it had a very hi volume air system, and I did use the respirator type listed above, and know of some others that still do, but cannot recommend that, many people that have used these paints and have been exposed can become sensitized to the isocyanates so that any exposure can cause asthma attacks or other severe reactions, sometimes permanent... If you are old enough to remember Bohpal India- the Union Carbide plant that produced Methyl Isocyanate a close relative i believe? had a large leak, it killed in excess of 1200 people in a few minutes...After thinking about this some more, and seeing a paint special on (Power Block) I intend on trying some of the water based paints and clears, in the near future... What is a persons health worth, as I get older and after losing another relative just yesterday, anything that can be done to safegard peoples health is a good idea... Sorry for the long post, hope this is helpful
  10. #90
    Super Member
    Join Date
    Dec 2007
    Posts
    9,873
    Central Ohio
    Good advice--I do indeed steer 100% clear of Isocyanates and am on the verge of buying a supplied air system. It's hard for me to justify it just for tractor work when acrylic enamel does a pretty good job for farm equip. Thanks.
Similar Threads
  1. Not really tractor related -
    By LJH in forum Photos
    Last Post: 11-03-2012, 08:42 AM
  2. Not tractor related, but still hydraulic
    By handirifle in forum Hydraulics
    Last Post: 02-04-2012, 08:07 PM
  3. Ford 1510 lug nuts bonehead report
    By Marveltone in forum New Holland Owning/Operating
    Last Post: 12-02-2010, 07:41 AM
  4. HELP How do you Start/ Move a BX23 with a bum neutral start switch?
    By LBrown59 in forum Kubota Owning/Operating
    Last Post: 11-12-2007, 08:28 AM
  5. Dealer Help..Dealer is a Bonehead! 1428v vs 1500 series
    By tractorbroad in forum Massey Ferguson Buying/Pricing
    Last Post: 04-23-2006, 05:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
