Page 2 of 6 FirstFirst 12345 ... LastLast
Results 11 to 20 of 55
  1. #11
    Join Date
    Apr 2011
    Posts
    585
    Boston
    L3700SU
    Default
    Quote Originally Posted by DK35vince View Post
    I never felt that extra weight was much help on snow and ice.
    Chains is the way to go.
    Yep...I move snow with a 8000 pound Cat skidsteer, it was horrible in the snow until I put chains on it. Now it is unstoppable.
  2. #12
    Super Star Member Egon's Avatar
    Join Date
    Aug 2001
    Posts
    16,615
    Nova Scotia, Canada
    Default Re: Snow Removal Frustration
    Chains for sure. Some ugly woods type and you will be a happy contented man!
    Remember the rear blades have limits. When they are exceeded start working the bucket. Slower but you'll get thru.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  3. #13
    Silver Member Pine Strip's Avatar
    Join Date
    Dec 2012
    Posts
    232
    Minnesota
    Kubota B-3000
    With the wonderful upturn in the stock market why don't you just ..... "buy a bigger tractor"
  4. #14
    Silver Member KennK's Avatar
    Join Date
    May 2006
    Posts
    126
    NE Illinois
    When the snow is too heavy for me rear blade I just use my front end loader. Yes its slow, but I do my best to think of it as just more tractor time - playing in the snow. Start taking bites that you can handle and it will get done eventually.
    Oh, I make a point of using my FEL to push the snow back off the "edges" so more snow has a place to get put.
    Then again, I have blacktop - not gravel. I've tried using my FEL on my neighbor's gravel driveway with only limited luck - I tend to pick up lots of gravel.
    JD 3320; 300CX FEL; Pat's Easy Change; JD 60" 7-Iron MMM; Frontier MS1105G ground-driven manure spreader; Worksaver UB-745 7' rear blade, Land Pride broadcast spreader, Flexpoint hitch receiver ... oh, and a little JD 125 for the DW
  5. #15
    Veteran Member rekees4300's Avatar
    Join Date
    Feb 2010
    Posts
    1,859
    Indiana
    JD4300 HST 4WD
    Chains are the answer. They make a BIG difference in traction.
  6. #16
    Join Date
    Dec 2012
    Posts
    232
    Minnesota
    Kubota B-3000
    I have turf tires and extra ballast, and have no problems.
    Snow Removal Frustration-ballast_001.jpgSnow Removal Frustration-ballast__box_037.jpg
  7. #17
    Veteran Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    1,658
    NorthEastern, VT
    Kubota L3010DT, Dresser TD7G Dozer
    In my case I had 4wd, loaded R1 tires, and plenty of weight. Tractor was useless on packed snow or ice. Added rear chains and winter traction problems disappeared.
    "If you're not making any mistakes then you're not doing anything"
    L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' Rear Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  8. #18
    Silver Member skspurling's Avatar
    Join Date
    Mar 2011
    Posts
    235
    Missouri
    Kubota B2620
    Default
    Quote Originally Posted by Catfish Man View Post
    Load the tires
    I've got a b2620 with loaded tires. Same boat. You need chains for this last stuff that came through. I've been spinning in and on this crap for the last two weeks. I even thought of getting chains for the front, because the front tires don't grip and just slide around in the deep snow. What do you do for that, except brake steer with the drive wheels. And that 400lbs of beet juice isn't helping much.
  9. #19
    Gold Member xring100's Avatar
    Join Date
    Dec 2012
    Posts
    435
    Livingston County, Michigan
    Kubota M8540
    Default
    Agreed weight does not help much on low coefficient surfaces when the mu level is .1 or less for ever 100 lbs you add you only gain 10 lbs of tractive effort. Or 1000 lbs equal to 100 lbs of force. On dry pavement or hard pack soil you would mu level of ~.7 or more meaning you would would add 700 lbs of tractive effort this applies to level ground. Chains are the way to go they will increase the mu level to 0.4 or better. The other problem with ballast on ice is that on a hill of moderate slope the added weight will reduce you traction and pull you down hill.
    I have a tractor setup that weighs 10,000lbs and r1's it sucks on hard pack or ice even with 4wd on. Even on slight grades. I don't have $1100 to get a good set of chains for the rear right now
    Dave
  10. #20
    Veteran Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    1,307
    In the order of cost effectiveness. 1. rear chains, 2. front chains if you have clearance on steering arms and loader parts, 3, load rear tires, 4, bigger rear blade with offset, 5, front plow 6.5 foot, use dump function for power angle. 6, add third function for power angle to allow front plow to float 7, rear 3PH snow blower. 8, six drunk relatives with snow shovels.
Similar Threads
  1. snow removal
    By gforce15 in forum John Deere Ag Tractors
    Last Post: 01-13-2012, 10:32 PM
  2. Snow Push vs FEL for snow removal
    By OUBrew in forum John Deere Buying/Pricing
    Last Post: 06-11-2010, 04:15 PM
  3. Snow Spring snow frustration - tips welcome
    By bxowner in forum Kubota Owning/Operating
    Last Post: 02-26-2010, 04:30 PM
  4. Snow Snow Frustration
    By MFChief in forum Massey Ferguson Owning/Operating
    Last Post: 01-25-2005, 06:17 PM
  5. Snow Equipment Buying/Pricing snow removal help
    By kokopelli2 in forum Snow Removal
    Last Post: 11-01-2004, 02:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
