Page 4 of 9 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 83
  1. #31
    Silver Member Lightnsound's Avatar
    Join Date
    Jan 2011
    Posts
    135
    Pen Argyl PA
    Kubota B7610
    Default
    I bought mine from tirechains.com, and was pleased with their customer service. The Duo-Grip indicates the pattern of the cross chains. Duo Grip has a lot of chain and it stays up on top of the tire treads without falling between the bars.
    V-bar chains have little V shaped pieces welded on the cross chains. They dig in hard like sharp cleats. You can get the duo-grip chains, and other designs, with or without the v-bars.
    Just go on their website, and see what designs they have available in your tire size.
    Another option I have messed with is studding the tires with screw-in studs. I bought some on eBay and tried them on my front tires. They work well, but don't go on and off like chains and they ate the garage floor more than I liked.
  2. #32
    Join Date
    Nov 2004
    Posts
    167
    Nebraska
    Kubota B2400 HST
    Default Re: Snow Removal Frustration
    Here's my new-to-me plow that I mounted on my FEL for plowing snow on my B2400. I've only used it once in a decent 6 inch snow. Overall it worked great. I did have some steering issues. Going around turns the front tires would lose their grip. I bought some chains for the front which, hopefully, will alleviate this problem. Chains on the rear helped tremendously.
    Attached Thumbnails Attached Thumbnails Snow Removal Frustration-083-jpg   Snow Removal Frustration-070-jpg
  3. #33
    Elite Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    Quote Originally Posted by coldstream View Post
    Wow, 3 pages of replies. Thanks for the great input folks. Since traction is the root cause of my problems I believe that I will start budgeting and planning for a set of chains. Based on your replies that seems the most likely way to improve my performance in the snow. Now, regarding chains, are there different styles and designs? Lightnsound mentioned the "V-Bar Duo" chains being pretty aggressive. Is that a style or a brand (I'll google it)? I wonder how much a set of chains will break the bank. . .Attachment 306854
    Of course there are different designs and applications. The most aggressive chains work great but if the operator insists on spinning he can tear up a paved drive ,concrete or asphalt, pretty quick. These work great but cost real money new.
    ice chains
  4. #34
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    load the tires and add chains
    Murph
  5. #35
    Veteran Member DABSGT's Avatar
    Join Date
    Nov 2011
    Posts
    1,202
    Connecticut
    John Deere 2032r
    Default
    Quote Originally Posted by vtsnowedin View Post
    ice chains
    If you are concerned about tearing up paved or concrete try the rubber chains. I picked them up this year and had no problem unless ice under the snow on my hill but nothing will help on ice.
    Sent from my iPad using TractorByNet
    Attached Thumbnails Attached Thumbnails Snow Removal Frustration-image-174329905-jpg
  6. #36
    Super Member
    Join Date
    Aug 2004
    Posts
    6,750
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Loaded tires, double link cross studded ice chains, rear blower, heated cab and front plow.
    Nothing stops me! (except wet sticky snow as the chute occasionally clogs.)
    And my radio entertains me.
    The double cross chains actually rarely spin as they grip so well, the only time I spin is on non compacted snow base, like off side of the drive when I decide to push back the snow banks.
  7. #37
    Silver Member KennK's Avatar
    Join Date
    May 2006
    Posts
    170
    NE Illinois
    My wife & I have some property in Northern Wisconsin (lots of snow). Right now I don't have to worry about plowing, but eventually we will retire there. My plan is to have a rear 3PT snowblower, so I don't have to worry about pushing anything. That will allow me to keep the FEL on. I can see where a front-mount snowblower would be nicer, but cost and the ease of mounting the rear 3PH version seems preferable to me.
    JD 3320; 300CX FEL; Pat's Easy Change; JD 60" 7-Iron MMM; Frontier MS1105G ground-driven manure spreader; Worksaver UB-745 7' rear blade, Land Pride broadcast spreader, Flexpoint hitch receiver, Titan (palletforks.com) 42" pallet forks w/ spears ... and a little JD 125 for the dear wife
  8. #38
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    Quote Originally Posted by KennK View Post
    When you spend a couple of long nights pretending you are an owl you just might change your mind. Keep your options open.
  9. #39
    Gold Member BuilderML's Avatar
    Join Date
    Nov 2012
    Posts
    480
    Tolland, CT
    CCY SX3100
    Coldstream,
    I would add weight to your scraper blade. You should be able to come up with some way to do it. Maybe dumb bell weights mounted on a pin welded to the center of your pivot point on your blade. Weight will make a big difference when trying to move snow. I personally would never load the tires some times you need to make the machine as light as possible. Once loaded your stuck with them. My driveway is 1200 feet long, I use the loader for my snow removal not the best but its what i have. I made a 500lb ballast block for the 3pt and it turned the tractor into a tank. The last blizzard we just had was 33" inches of snow and thats without the snow drifts. Needless to say it took me 8 hrs to clear all the snow off 1200 ft plus the house area. Sometimes you just need to make due with what you have. Like you said you don't get that many big storms so i would not load the tires, i would find a away to add weight to the blade. Also add some weight to the loader bucket when scraping, Grab a nice scoop of snow and see if it helps.
    Good Luck
  10. #40
    Silver Member tony binkowski's Avatar
    Join Date
    Jan 2011
    Posts
    149
    green bay packer land
    2011 b3000
    save up get a blower your pain will melt away with a big smile!!!!!!!!!!!!
    Badgerboy
Similar Threads
  1. snow removal
    By gforce15 in forum John Deere Ag Tractors
    Last Post: 01-13-2012, 10:32 PM
  2. Snow Push vs FEL for snow removal
    By OUBrew in forum John Deere Buying/Pricing
    Last Post: 06-11-2010, 04:15 PM
  3. Snow Spring snow frustration - tips welcome
    By bxowner in forum Kubota Owning/Operating
    Last Post: 02-26-2010, 04:30 PM
  4. Snow Snow Frustration
    By MFChief in forum Massey Ferguson Owning/Operating
    Last Post: 01-25-2005, 06:17 PM
  5. Snow Equipment Buying/Pricing snow removal help
    By kokopelli2 in forum Snow Removal
    Last Post: 11-01-2004, 02:12 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
