Results 1 to 3 of 3
  1. #1
    Member petergreen's Avatar
    Join Date
    Mar 2007
    Posts
    26
    Spain, Europe.
    Lamborghini R1.40
    Default Plow size/weight
    Hello friends!
    My machine is a Lamborghini R1 40, as you can see in this thread: http://www.tractorbynet.com/forums/o...i-r1-40-a.html
    I've been using the tractor for about 2 months. No major problems whatsoever. But recently I decided to purchase a used plow (see attached image). It weighs about 400kg (880 pounds).
    My surprise was that the hydraulic system could barely lift the implement. And it was incapable exert full force to turn around the thing (it has a spring-firing system).
    In spite of all of that, the tractor pulled the plow in easy terrain, but it certainly was at the limit of the machine.
    My question is, for this machine, do you think that a 400kg plow is too heavy? The tractor weighs about 1600kg (tyres filled with water). Could it be that the hydraulic pump is defective?
    Plow size/weight-plow-jpg
  2. #2
    Join Date
    Jan 2012
    Posts
    153
    Alabama
    Kubota M7040, Kubota B2710
    Default
    I think it may be too big for your machine. I pull an 800 pound disc with my 70hp tractor (bigger tractor, and a disc provides less resistance).
  3. #3
    Join Date
    Mar 2007
    Posts
    26
    Spain, Europe.
    Lamborghini R1.40
    Default Re: Plow size/weight
    Yeah, I think that I need a smaller plow for my tractor.
    I found this video: Aratura autunnale 2010 - YouTube
    I think that plow would be perfect for me.
Similar Threads
  1. Snow Attachments Snow plow weight concern
    By furnitureguy in forum Snow Removal
    Last Post: 09-08-2010, 07:04 PM
  2. Landscape trailer size and weight
    By HK45 in forum Trailers & Transportation
    Last Post: 04-09-2008, 08:54 PM
  3. HP and weight vs plow size and depth of snow
    By bx24 in forum Build-It Yourself
    Last Post: 12-31-2007, 07:01 PM
  4. Snow Snow Plow And Weight Questions
    By Bob_Bullock in forum New Holland Owning/Operating
    Last Post: 03-15-2006, 06:18 AM
  5. Size Matters (but not as much as weight)
    By chim in forum Attachments
    Last Post: 06-08-2004, 12:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
