Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
  1. #11
    Join Date
    May 2011
    Posts
    826
    Trent Hills, ON
    Kioti DK40SE HST
    Default Re: Instead of bucket hooks
    Instead of bucket hooks-g209-jpg
    I just drilled a hole in the top lip of my bucket in the middle and put a threaded shackle in. I only had a 1 ton one laying around but both it and the bucket edge had no trouble lifting my 1000+lb box blade off my trailer. I don't seem to lift many things using a chain but it seems fine for the odd job.
    2011 DK40SE HST
  2. #12
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,555
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Not sure what loader you have, but the LA302 on our B7500 is going to get a piece of 1.5x1.5 angle welded on to cover the top lip and 3 hooks welded to that.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  3. #13
    Bronze Member ghenges's Avatar
    Join Date
    Apr 2012
    Posts
    93
    Greensburg PA
    Farmall
    Quote Originally Posted by ShenandoahJoe View Post
    The guys who make bucket hooks tell me my loader bucket isn't big enough to handle them. Now I'm looking for something else that will let me lift things that are too bulky to go in the bucket.
    Here's my latest brainstorm: The crossbar between my boom arms is a hollow tube. I'm thinking to run a length of heavy chain through that tube, and put hooks on either end. I can hang things from the hooks, and the hooks will stop the chain from falling out of the tube. Any reason that's not a good idea?
    A reinforcing piece of 2x3x1/4 rectangular tubing side to side atop the bucket would be ideal. It appears there is enough of the bucket side plates sticking up to accomplish an excellentjob. It will be all closed up and neat in appearance.
    2x3x1/4 rectangular tubing in this application is strong in tension, compression and is resistant to torsional forces.
    A 2x2x1/4 rectangular tubing would actually be strong enough to be an option.
    "I know the end of humanity is near when my tractor comes with a place to store and plug in a cell phone, but no tool box" -- God's Country
  4. #14
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,965
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Reinforce the top lip with a piece of angle dimensioned to lay flat on the top lip and reach the FEL bucket top wall. Stitch weld it with about 3" of weld every 12". Weld your hooks to the angle centered at the cylinder attachment points. Some folks put them in the middle also, but I have never found a need to have a hook in the middle. If I want to pick from a single chain in the middle, I drape the chain across both hooks and let it hook back into itself in the middle like a Y. That puts the load equal on both hooks and no danger of bending the lip.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  5. #15
    Veteran Member grnspot110's Avatar
    Join Date
    May 2007
    Posts
    2,352
    MO
    John Deere 1953-40S, 790, 755, 314, 70 I & Power King 2418
    I prefer a boom for lifting:
    Instead of bucket hooks-farm-037-small-jpg
    I do have small hooks on my bucket, but seldom use them, much prefer to use the boom. I store my tractor/loader with the "quick-tach" bucket off, so I just put on whatever I need at the time, bucket, boom or forks. ~~ grnspot
  6. #16
    Gold Member Kioti Tom's Avatar
    Join Date
    Jan 2012
    Posts
    483
    Industry, Pa- - 5 mi. north of Ohio River
    Kioti DS4510, Ford '48 8N, Ford '53 Jubilee, Power King 1614
    Quote Originally Posted by yelbike View Post
    Had you painted it green it would have never bent like that!
    Green????? NOPE, Kioti Orange. I shrunk a couple of JD's and keep them in the vortex air cleaner
    sump jar on my 8N.
    Kioti 2012 DS4510 with FEL
    Ford 1948 8N
    Ford 1953 Jubilee
    Power King 1614
    Various 3 pt. equipment
    Sold: Ford 1946 2N, Kioti 2011 DS3510
  7. #17
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,386
    Lancaster County, PA
    Kubota L3200, Ford 1210
    Here's what I did for the last two tractors. Pieces of heavy angle iron with notches cut to drop chain into. They're a lot handier than hooks and with all the notches you can do multiple loops of chain. It's also easy to throw leftover chain into the slots to prevent it from dragging. Simple matter of drilling holes for the ends of the slots and then making two saw cuts from the edge to each hole to get a nice slot with a rounded end. Bolt-on installation and tough as nails. Never bent anything and I've hooked onto a few things the tractor refused to pick up.
    Instead of bucket hooks-chain-hooks-jpgInstead of bucket hooks-level-1-jpg
  8. #18
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,643
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Default
    Quote Originally Posted by chim View Post
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=308786"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=308787"/>
    Nice and simple. I really like that!
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  9. #19
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    7,065
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds operating weight
    I think you should contact Ken at Ken's bolt on grab hooks. He is The Bucket Hook Guru here on T-B-N and I am sure he is familiar with your B7300 kubota and its bucket. Very helpful person. Read the section on his web site regarding bucket reinforcement. I have used Ken's 5/16" bolt on grab hooks in forestry work WITHOUT REINFORCEMENT for 18 months with no problems. My B3300 is a couple increments up the Kubota scale relative to your B7300. If I have not had problems in heavy use, you certainly will not either.
    But ask Ken......
    Ken's Bolt on Grab Hooks
    Attached Thumbnails Attached Thumbnails Instead of bucket hooks-img_0329-jpg   Instead of bucket hooks-img_0325-jpg
  10. #20
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Joe, I am real curious, who are these "guys who make bucket hooks" that told you that?
    Can you weld, or do have a friend that does? There are quite a few options, some involve welding and some don't-so if we know this answer we could help more.
    As for your chain idea, I think it would work OK, but the load would close to the grill guard, and I think you will loose a lot of lifting height.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
Similar Threads
  1. Strengthened bucket, added bucket chain hooks
    By hyperrust in forum Attachments
    Last Post: 03-22-2012, 12:00 AM
  2. "T" Hooks & Bucket Hooks
    By crash325 in forum Customization
    Last Post: 05-16-2011, 01:13 PM
  3. Help with bucket hooks on Deere HD Bucket
    By nmu98 in forum John Deere Owning/Operating
    Last Post: 09-03-2008, 06:59 AM
  4. Yet again, bucket hooks.
    By whodat90 in forum Customization
    Last Post: 12-06-2006, 04:42 PM
  5. New Bucket hooks
    By Von in forum Photos
    Last Post: 05-28-2001, 08:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
