Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. #1
    Gold Member
    Join Date
    Jun 2009
    Posts
    284
    Shenandoah County, VA
    Kubota B7300
    Default Instead of bucket hooks
    The guys who make bucket hooks tell me my loader bucket isn't big enough to handle them. Now I'm looking for something else that will let me lift things that are too bulky to go in the bucket.
    Here's my latest brainstorm: The crossbar between my boom arms is a hollow tube. I'm thinking to run a length of heavy chain through that tube, and put hooks on either end. I can hang things from the hooks, and the hooks will stop the chain from falling out of the tube. Any reason that's not a good idea?
    Attached Thumbnails Attached Thumbnails Instead of bucket hooks-loaderpipe-jpg
  2. #2
    Elite Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Kubota B2620 with BH65 backhoe, Ford 2N
    Default
    Personally, I would reinforce the bucket edge and put hooks on them.
    If you put the chain thru the tube, it would work, I think, but being behind the bucket, it would not be as convenient for hooking up stuff.
  3. #3
    Super Member s219's Avatar
    Join Date
    Dec 2011
    Posts
    6,684
    Virginia USA
    Kubota L3200 Deere X380 Kubota RTV-X
    Default Re: Instead of bucket hooks
    That front bucket is fine for hooks -- many people here have hooks on the front loaders of kubota B series. If you're worried about the lip, just mount them farther back on the top of the bucket:
    Instead of bucket hooks-img_2842-jpg
  4. #4
    Join Date
    Feb 2012
    Posts
    732
    Germanton, NC
    Kubota MX5100F IH McCormick Farmall 140, Massey Ferguson 135
    +1 on reinforcing and adding hooks. A section of 3" channel behind the top bucket lip would work fine. Then weld your hooks to that.
  5. #5
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,643
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Default
    Quote Originally Posted by Ted Summey View Post
    re
    +2 on reinforcing! Or just paint the bucket green and you'll be fine!
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  6. #6
    Bronze Member Tchara's Avatar
    Join Date
    Feb 2013
    Posts
    77
    Temple, TX
    Branson 3520R
    Green?!!!
    Branson Red!
  7. #7
    Gold Member
    Join Date
    Mar 2010
    Posts
    253
    East Texas
    I welded some flat stock vertically between the back of the bucket lip and the back wall of the bucket. About 5-6 pieces evenly spaced. I can hook a chain to any of those pieces. Works really good for me. Over time the bucket top bent slightly in the center. I had to straighten it and reinforce the bucket lip/top of bucket with a piece of angle iron.
  8. #8
    Join Date
    Nov 2011
    Posts
    1,643
    Default
    Quote Originally Posted by ETpilot View Post
    Had you painted it green it would have never bent like that!
  9. #9
    Bronze Member mmurphydds's Avatar
    Join Date
    Dec 2012
    Posts
    52
    Fergus Falls, MN
    JD 4720
    Quote Originally Posted by ShenandoahJoe View Post
    I have done that on the last two tractors I've owned and have had great results with what you are suggesting. I also had bucket hooks on the last tractor and found them to be useful, but I use the tube and chain setup more frequently. I drilled a hole in the center of the tube and placed a grade 8 bolt through the tube and through the center-most link in the chain, that way the chain can't shift. Works great.
    Mark
    JD 4720, 400X FEL, JD MX6 Brush Cutter, 72" JD 7-Iron MM mower, 7ft Farm King disk, 6ft LandPride scraper/pulverizer, 7ft King Kutter II rotary tiller, 7ft King Kutter landscape rake, 6ft Buhler box scraper, 2-row Yetter planter, 3pt quick hitch, 3pt trailer hitch lift, 3pt carryall, Hydraulic top link, Wallenstein BX62 chipper
    JD X720, 60" 7-Iron mower, 47" front-mount snowblower.
  10. #10
    Silver Member Burtonbr's Avatar
    Join Date
    Nov 2012
    Posts
    137
    NC
    Kubota b2620, LA364 loader.custom rear remotes, THUMB bucket grapple, 60" box blade 72" landscape rake &many other toys
    The loader lift capacity is not huge on the CUT's, so it doesn't take much reinforcement for the hooks, some 3/16 or 1/4" is all it takes.
    I've tested these to the max lift a few times.
    But the chain idea should work too..
    Attached Thumbnails Attached Thumbnails Instead of bucket hooks-image-jpg
Similar Threads
  1. Strengthened bucket, added bucket chain hooks
    By hyperrust in forum Attachments
    Last Post: 03-22-2012, 12:00 AM
  2. "T" Hooks & Bucket Hooks
    By crash325 in forum Customization
    Last Post: 05-16-2011, 01:13 PM
  3. Help with bucket hooks on Deere HD Bucket
    By nmu98 in forum John Deere Owning/Operating
    Last Post: 09-03-2008, 06:59 AM
  4. Yet again, bucket hooks.
    By whodat90 in forum Customization
    Last Post: 12-06-2006, 04:42 PM
  5. New Bucket hooks
    By Von in forum Photos
    Last Post: 05-28-2001, 08:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
