Page 5 of 7 FirstFirst ... 234567 LastLast
Results 41 to 50 of 67
  1. #41
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    Default Re: First timer- field prep for field grass
    Looks great! Ready to grow.
    I've gotten lazy in the past about packing/not packing and have even used my 3-wheeler to pack the field. One year, I used my JD110TLB with the hoe off and the loader bucket off and packed a small field that I had rototilled and planted.
    The 110 has R4 tires so, they're flatter and not so aggressive and I figured the tractor wouldn't compact things too awful bad... Well, long story - short; got a great stand, good germination - darn horses pocked it up, pulled up the grass, etc. etc. when I turned them into it late in the fall!
    So, the next Spring I hand filled in the holes and raked and replanted and rolled the crap outta it with that HEAVY roller. That fall; after the first killing frost - the grass did just fine with the horses on it.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  2. #42
    Veteran Member sd455dan's Avatar
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    Rhino 554, JD550G dozer Gilson MTD riding mowers Ford 3000-Sold
    Quote Originally Posted by AKfish View Post
    AKfish
    Thanks , but I think I'm about to ask a remedial question
    On the (horse field in the last post), she wants to over seed it- but even though we know it probably needs lime, planning on just overseeding it (tight budget) . that being said- is the process ? (from how that field is tilled and disced in the picture)
    broadcast seed, then till?-can't be? can it?., then compact, and watch it grow
    or is it- ,overseed, and she has done this before- lightly cover the seeded area with scattered hay and once wet seemed to keep the seed in place? but then eventually the horse will tear it up and pock mark it into oblivion this fall.. I got to admit from here on out I'm a little lost on the best order and the best way to actually seed the field, and the compaction part,
    Sorry this post is probably not well worded.. one more thing I think my sister may have a slit style 6-8' wide fertilizer spreader, think it may need a tire - will check into this In the next couple days -for the actual threads field
    thanks everybody for the all the help, and encouraging words I really do appreciate it dan
  3. #43
    Elite Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    3,409
    central Vermont
    John Deere 5045E
    Quote Originally Posted by sd455dan View Post
    Just top dressing the field with lime and fertilizer will improve the stand of grass that is there now.
  4. #44
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    The #s from the soil test are in!!????First timer- field prep for field grass-soil-sample-test-results-001-a I'm guessing the soil is acidic, just as every one thought , will call the extension office as requested by the lab for explanation of findings and report their recommendations
  5. #45
    Gold Member
    Join Date
    Jan 2012
    Posts
    321
    Moores Hill, Indiana
    MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
    Looks like you already have everything tilled up nicely. Generally the seed is scattered (3-point broadcast spreader or drop seeder) then run over with a cultipacker to get the seed in contact with the soil. The old timers around here who couldn't afford much equipement would scatter the seed then VERY LIGHTLY go over it with the disc. VERY LIGHTLY....as in only let the blades of the disc go into the soil like 1 inch. I want to make sure you read VERY LIGHTLY again or you will bury your seed too deep and it will not germinate. Then after everything germinated and got somewhat established, they would go back over and put lime and fertilizer on. Just make sure it's dry so you don't rut up your nice field.
    MBA = More Bad Advice
  6. #46
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    Yep.. you've got acidic soils. pH of 7 is neutral. Lower values are acidic and higher numbers above 7 are alkaline. You're gonna need to lime it and/or use a fertilizer blend that is sulfate based and provides positive ions (+) to the soil that will neutralize the negative ions (-) that are present in excess with acidic soils.
    Regarding overseeding: I have broadcast timothy seed with my fertilizer application in the late fall on my hay fields and have gotten good results with that - new growth and a thicker stand. The key is too allow the new grass enough time to grow and establish a root base that will 1.) provide energy reserves for regrowth after grazing and 2.) strong enough - large enough that horses won't pull the whole plant outta the ground!
    That's hard to accomplish with standing fields... you want/need to use the acreage; but, the new plants need time.
    The easiest method is to rent/borrow a no-till drill or an overseeder drill. Landscapers and garden supply businesses will sometimes rent overseeders. NRSC offices in Alaska provide no-till drills for rent to landowner's for pasture and hay field improvements.
    AKfish
  7. #47
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    Got to meet with the Extension Educator, and was very helpful in working out the quantities of the chemicals , to be applied
    they punch the size of the field in length x width= just under an acre, then the amount of lime to bring the field back to a ph of 7.0 worked out to just about a ton. The local Co-Op sells the re-usable poly bags of 1000 lbs. of lime so will be picking up 2 of those , the purity has to be near 100% to use those #s or recalculated by %age,
    organic matter at 7.3% was ok ,the Ammonium, was ok and also the Nitrate
    The K -potassium was also plenty ,actually high, and finally the Phosphorous was low at 2.5 ppm need to apply 30lbs. once a year to this field...to the 3rd year and i guess ( if memory serves -this one lasts for a few years once it's up)
    Ok the costs that I have checked - lime 1000lbs. poly bag $143.82 x 2 =287.64+tax=$304.90
    haven't checked phosphorous yet
    $75.00 a day for a pull behind roller and have not picked out the seed for sure Educator suggested the blue grass mix / wife not crazy about that one... TBD..
    Also picked up the fertilizer spreader from sister (going to need work- flat tire , the pto driven belt drive is heavily corroded and frozen) ,it was getting dark ,need to unload and pressure wash and check it out I believe its a King??
    Anyway- that's where everything stands today, and it's getting late will update when more progress progresses
  8. #48
    Silver Member paulemar's Avatar
    Join Date
    May 2011
    Posts
    187
    Pittsburgh, PA
    Kubota BX25, 60" MMM, 3 point hitch
    Default
    Maybe I'm missing something, but that sounds a bit high for lime to me. I can get pelletized lime retail from Tractor Supply for $3.99 a 40 lb. bag. 25 of those is 1000 lbs. and costs $100 plus tax. I just did this same thing and being as it's pelletized, I easily spread it with my Brinly pull behind spreader.
    BX25, "60" MMM, 3 point hitch, Brinly 12" cat 0 1 bottom plow, TSC Countyline carry all, Kubota ballast box, 4X4 Loyal drag harrow, BXpanded Piranha tooth bar, Bro-Tek rear skid plate, Bro-Tek wheel spacers, Bro-Tek backhoe ripper tooth. Kubota BX2763A front plow, Phoenix T4 48" rototiller, Harbor Freight Quick Hitch, BXpanded Quick-on Work light Kit, Mark Hodge stabilizers.
  9. #49
    Join Date
    Oct 2012
    Posts
    2,105
    North Idaho
    Quote Originally Posted by paulemar View Post
    That's great- if the price is lower, the price quoted is from calling the local Co-Op. I just assumed they would be the most reasonable, and have to pay a fee for the two polly bags until they are returned...
    We also have a (big R) store and Home depot guess I will check with them.. and their price, the lime from Co-Op is dolomite/ lime the other way it is sold is by 50lb. bags atc$10.85 each or $9.30 each 10 or more, but that is even more money...
    does the lime you bought have a purity rating on it? Not sure if the lime qouted here is ground or pelletized
    The fertilizer spreader pto was froze solid got it broken loose but when I rotated the shaft in the direction the PTO runs it immediately ran one of the belts off of the idler pulley- will pull it apart , no one knows exactly how long ago it was used and the drop rate control needs work (bent up and frozen) anyway thanks for the heads up on the pricing - hoping this is not related to geographical location...
  10. #50
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    I'm about to put in an order for 8 tons of lime. I got a quote from the largest Ag supplier in the State and the Pelletized lime is $485/ton, the Ag lime is $295/ton and a coarse, granulated Ag lime is $250/ton. It will cost me an additional $35/ton to have it trucked down to my place from Anchorage - 165 miles.
    Based on what I'm paying - it looks like you're paying too much! Or, it's not really Ag lime..
    AKfish
Similar Threads
  1. Proper implement for field prep
    By drjay9051 in forum Attachments
    Last Post: 09-25-2007, 12:58 PM
  2. Corn Field To Grass Field
    By Crash20 in forum Projects
    Last Post: 01-13-2007, 11:33 AM
  3. Grass on a Ball Field
    By Renob in forum Projects
    Last Post: 10-23-2006, 09:42 PM
  4. Field to Yard Prep
    By BrettW in forum Attachments
    Last Post: 03-31-2003, 07:02 AM
  5. old Corn Field to Grass
    By MIMark in forum Projects
    Last Post: 03-25-2002, 09:49 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
