Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    Platinum Member 3v0's Avatar
    Join Date
    Jan 2013
    Posts
    521
    Oklahoma Pan Handle, United States
    Kubota BX2200
    Default Toe hooks re-purposed as bucket hooks?
    I was looking at the bucket hooks on another thread and it got me thinking that there had to be other hooks one could use. I expect these would work.
    tow hooks
    Toe hooks re-purposed as bucket hooks?-z-s0039_thumbnail-jpg
    Or maybe these Harbor Freight hooks
    Toe hooks re-purposed as bucket hooks?-image_15855-jpg
  2. #2
    Elite Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    Default Re: Toe hooks re-purposed as bucket hooks?
    Those hooks will work but need to be bolted on. Often the steel on bolt-able hooks is not suitable for welding.
    Also, if their rating is available, see how they compare to grab hooks made to be welded on. Grade 70 grab hooks are rated to 6,600 pounds.
    If there is no rating then they should probably be avoided as the quality of the steel is questionable. Nothing worse than carrying around something valuable and the hook fails.
    The Harbor Freight hook has a rating of 10,000 pounds...but it is Harbor Freight. It will likely be fine but proceed with caution. Price is quite reasonable.
    2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
    2002 Kubota L48 TLB, 12", 18", 24" HD buckets
    2001 Kubota BX2200, Turf, LA211 FEL
    7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
  3. #3
    Join Date
    Jan 2013
    Posts
    521
    Kubota BX2200
    The hooks in the other thread were also bolt on. My thinking if 2 of these tow hooks are strong enough to pull out a stuck 4WD pickup they are good enough to bolt to a loader bucket.
  4. #4
    Join Date
    Feb 2012
    Posts
    732
    Germanton, NC
    Kubota MX5100F IH McCormick Farmall 140, Massey Ferguson 135
    It depends on what you intend to use to do lifting - straps or chains? It also depends on what you have on the ends of the straps or chains - hooks or loops? You need to know the weight rating and/or grade of your hooks. Just because they may be sold for pulling an off road vehicle out of a ditch doesn't necessarily mean they have adequate strength for that purpose or any other.
    Many welded on bucket hooks are for intended for use with chain - grab hooks. Some put a combination of grab hooks and slip hooks on their buckets. Others install lifting rings as well. I wouldn't count on bolt on hooks unless I was sure of the grade of the hook and bolts.
    I have two welded grab hooks on mine.
  5. #5
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,826
    Trivoli, IL
    SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
    prefer a combo hook. were i can drop a link between a slot. without having to "hook chain back onto itself" ((you still should re hook chain back onto itself)) but it is that slot that can make life easier. and kinda holds the chain without having to deal with "slack in chain" and chain sliding through a loop.
    and then a "loop" for other chains / ropes / cables. that makes everything multi purpose. that i like.
    no idea what the hook type is called.
    Toe hooks re-purposed as bucket hooks?-id-bucket-hooks-png
    Ryan
  6. #6
    Join Date
    Jan 2013
    Posts
    521
    Kubota BX2200
    I like the look of the hook Ryan.
    Also how strong a hook one needs depends on the tractor/loader. I have a BX2200. Not much point in 6000lb hooks.
  7. #7
    Super Member
    Join Date
    Jul 2009
    Posts
    8,562
    SW WA
    Kubota BX2360
    The style of the first one in post #1 was provided with some Jeep Cherokee receiver hitches. Probably available from other sources, too, but don't buy one from the link. That is for RC model trucks.
    Here are some higher rated hooks for those with large tractors:
    http://winchlines.com/merchant.mvc?S...oad_And_Towing
    Bruce
  8. #8
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,683
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by bcp View Post
    Rigging Products, Inc. Sales Online: *PAIR*B2801A EXTRA HEAVY DUTY TOW HOOKS
    Rigging Products, Inc. Sales Online: *PAIR*B2801C 3 HOLE TOW HOOKS
    Bruce
    I want some of these tires... checkem out.. only $29 per PAIR
    Rok Lox 2.2 Comp Tires
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  9. #9
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,826
    Trivoli, IL
    Quote Originally Posted by 3v0 View Post
    went a looking i thought it was a "sticky" thread in one of the main forums. someone was selling/making more of a V shape hook, that was either weld on or bolt on. though it may be more like hooks shown in this thread with a part circle shape. but there was more "re-enforcement" at the tip of the hook.
    other words when ya roll the bucket all the way down, the chain will want to roll to the "narrow tip" of the hook. and that is about point were hook will either bend or brake, or chain slips off. and the hook i was thinking about, had some extra re-enforcement and longer tip of the hook, to reduce chance of chain slipping off and/or bend when ya at them odd ball angles, and needing just that little more.
    ya know, what your land is like better than anyone else and what you need the hooks for. but just saying, ya might want to look at a different set of hooks even if it costs ya 10 to 30 bucks more.
    Ryan
  10. #10
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,826
    Trivoli, IL
    and as soon as i post, i see below thread. "ken's hooks"
    Loader Ken's Bolt On Bucket Hooks
    Ryan
Similar Threads
  1. "T" Hooks & Bucket Hooks
    By crash325 in forum Customization
    Last Post: 05-16-2011, 02:13 PM
  2. Loader Expanded slip hooks vs grab hooks
    By Jeffnew in forum Kubota Owning/Operating
    Last Post: 04-16-2011, 12:24 AM
  3. Bucket Hooks
    By tofriendscreek in forum John Deere Buying/Pricing
    Last Post: 08-25-2009, 06:52 PM
  4. hooks for my bucket
    By jmt1271 in forum Projects
    Last Post: 09-02-2006, 05:09 PM
  5. Bucket hooks
    By BlacknTan in forum Kubota Owning/Operating
    Last Post: 07-31-2006, 10:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
