Results 1 to 7 of 7
  1. #1
    Elite Member
    Join Date
    Sep 2009
    Posts
    2,681
    Up State S.C.
    AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
    Default Reverse the tread
    I need to move some dirt down a hill a few feet to make a level spot for a shop and road behind my house. The hill is pretty steep and I have trouble backing up it. The ag tires pull fine going in the direction of the tread and I'm thinking that I might reverse them so I can push the dirt down hill with the loader and still be able to back up for the next push. Has anyone ever done this and if so, how well did it work?
  2. #2
    Platinum Member Notforhire's Avatar
    Join Date
    Nov 2011
    Posts
    853
    Southwestern Virginia
    JD 5055E
    Default Re: Reverse the tread
    I have no personal experence with reversing tires, but I have seen tractors with one tire reversed. I guess it was common practice working for in sand/ gravel pits years ago. You would use the steering brakes to give traction to the correct tire.
    Bill
  3. #3
    Elite Member
    Join Date
    Sep 2009
    Posts
    2,681
    Up State S.C.
    Thanks, Bill. There was a tractor for sale somewhere the other day with one reversed tread. You probably just explained why it was done.
  4. #4
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    I have seen the tires reversed on a old Farmall M that was used for pulling. The tread designed to help drop the dirt/mug out from between the lugs when going forward so reversing them will cause it drop the mud and get better traction in reverse.
    When I see a tractor with one tire on backwards I have to think that the person installed the tire on the wrong way (dish in or out) and instead of dismounting it and changing the direction they left in on backwards.
  5. #5
    New Member johndeerejohn's Avatar
    Join Date
    Mar 2009
    Posts
    9
    Pa
    John Deere 3120
    I can't say it wouldn't help but the way I see it it's more about weight distribution. as soon at the tractor is headed down hill the weight on the drive tires shifts forward. and with most of the weight of a tractor foward of the drive wheels I don't think the tread direction would matter much. I would think you would have better luck putting ballast behind the rear wheels. That's just my two cents.
    Everything else tastes like chicken, but why don't eggs?
  6. #6
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,917
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by stuckmotor View Post
    It worked well for me, I could really tell the difference. It is easy to do, just raise the back, support it securely, unfasten one wheel, roll it to the other side, unfasten that side roll it to the first side and fasten them on, That is it, reversed!
    I had to do it on the front, but same result. I was working in some sloppy stuff!
    Reverse the tread-p5180152-jpg Reverse the tread-pc080005-jpg Reverse the tread-pc080006-jpg
  7. #7
    Elite Member
    Join Date
    Sep 2009
    Posts
    2,681
    Up State S.C.
    John,
    You're probably right about the ballast. I haven't had this tractor very long and don't yet have a ballast drum or a heavy implement to use for balast so, I thought I'd check out my options before getting down in the dirt tomorrow.
    Xfaxman,
    Thank you very much. There's nothing like experience!
Similar Threads
  1. Tire choices for zero turn. IE turf tread or bar tread
    By zsqure in forum General Lawn & Garden
    Last Post: 10-23-2012, 06:48 AM
  2. Replies: 7
    Last Post: 06-20-2012, 01:40 AM
  3. More Tread Questions
    By gltrap54 in forum Kubota Owning/Operating
    Last Post: 04-11-2008, 06:16 PM
  4. CK-30 tread width
    By Dachshund in forum Kioti Owning/Operating
    Last Post: 09-21-2007, 02:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
