MF135 REAR WHEEL REMOVAL
   / MF135 REAR WHEEL REMOVAL #1
cndh
Hawkchurch, UK
MF135 & Kubota B2530
Has anyone got any tricks of the trade to remove the rear wheels of my MF135. The nuts have been loosened off, it's just a matter of manhandling the wheel and getting it back on
   / MF135 REAR WHEEL REMOVAL #2
That's one way--you and a friend and a bit of grunt work.
I prefer an easier way. I use my 1-ton gantry crane with chain hoist since I work alone.
It's hard enough for me to roll one of those rear wheels around the shop. Getting them reinstalled
without that gantry would be hazardous to my health.:eek:
BTW: that's the rear end of a 1951 Minneapolis Moline BF tractor that I'm restoring.
Good luck.
   / MF135 REAR WHEEL REMOVAL #3
GoodMornin Ray,
Gee that gantry crane looks very nifty !!!
Did you get it through Northern, and how much was it if you domt mind me asking ? ;)
I can see how handy that would be for similar jobs, or splitting tractor etc...
   / MF135 REAR WHEEL REMOVAL #4
when i mounted my r1s on mine i just jacked the tractor to the proper wheel height and wiggled them on. They were heavy as they where loaded but i managed it by myself.
   / MF135 REAR WHEEL REMOVAL #5
There isn't much trick or tips to moving those big tires , just lots of muscle and balance. The only trick is to get the jack height perfect so it slides off by walking the tire back and forth to drop it off the lug bolts and then try not to let it get out of balance. If you start to loose it, just let it fall and get out of the way. A gantry crane would be nice but I have moved them by my self even in the dirt with loaded 18.4x38 tires off our 9000 Ford back when I was a young man. It had dual tires that we put on in the fall for disking and took off in the spring for planting and cultivating so it was a yearly thing to do so it became easier and easier. If they ever fell over, it took a boom pole to get them back up and some digging under to get a chain around the tire.
   / MF135 REAR WHEEL REMOVAL #6
   / MF135 REAR WHEEL REMOVAL #7
Here are the rears on my 1964 MF135 diesel.
They are BF Goodrich 6 ply 18.4-16A tires (18" wide, 16" dia rim, 40" tall overall) and are loaded with water. My guess is that each weigh at least 350 lb loaded, probably more. Haven't had to remove/replace these yet, but that day may be coming.
My 135 is a field tractor that's been modified to squat low for mowing/discing in the olive orchards around here. The front axle spindles have been shortened to keep the tractor level with that BFG rubber.
   / MF135 REAR WHEEL REMOVAL #8
Do you remove the exhaust to go under the olive trees? I'm thinking about a horizontal exhaust for mine to work in the woods.
   / MF135 REAR WHEEL REMOVAL #9
Put some linoleum down on the floor or (if your on a smooth finished concrete floor) under each wheel. Jack and secure each axle side so the wheel touches the floor but can be rocked from side to side.. If you can't rock the wheel it needs to be jacked up just fraction more. The lugs must be centered on the drum holes with no pressure on the lugs. Since your dealing with filled tires, you should have a hefty helper to assist. You should be able to rock the tire in a Z pattern pushing at the center of each side. This rocking motion, you should be able to walk the rim from the drum. The tire has to touch the floor enough to walk it off the drum.
Putting the tires back on is basically the same as removal. If the tire seems it needs to be a fraction higher, then roll on to some cardboard enough to get the correct height so the lugs are centered with the rim holes. This may take a while to rock the wheel in a Z pattern to finally match. Have your tranny and H/L in neutral to turn the drum to line up. if you get the top nut on, your on your way.
Push come to shove, you could drain the tires and save the tire fluid afterwards, refill. -kid
   / MF135 REAR WHEEL REMOVAL #10
I always just use a hydraulic jack so I can easily raise or lower the tractor to the exact height. This is a good time to have a helper to look at the holes to get the alignment perfect rather than pump, check, pump, check etc.
