Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Member kozman's Avatar
    Join Date
    Apr 2010
    Posts
    27
    Farmington, NH USA
    Kubota B3200HSD
    Default Re: Kubota B3200HST 50 Hour Service
    Quote Originally Posted by 94BULLITT View Post
    You should also re-torque your loader bolts.
    Definitely plan to do that too.
  2. #12
    Silver Member shucksters's Avatar
    Join Date
    Mar 2013
    Posts
    191
    TN
    Kubota L4240 HST+ FEL C/A Kubota BX2370 + FEL/60"MMM Kawasaki Mule ProFXT EPS LE
    It's nice to get to know your tractor better....I think I'm going to do mine along with someone else who has a little more know-how at 50.....
  3. #13
    Join Date
    Apr 2010
    Posts
    27
    Farmington, NH USA
    Kubota B3200HSD
    So I went to see mu local kubota dealer to pick up the necessary filters. After doing some research, I found out that all I really needed to do was change the oil and some filters and that was about that. Even the air filter may not need to be changed years is you're using it more in the winter, which I am. Going to take the plunge tomorrow and give it a try.
  4. #14
    Join Date
    Apr 2010
    Posts
    27
    Farmington, NH USA
    Kubota B3200HSD
    Very excited! I just finished everything for my 50-hour service and did it myself. Only two issues were that the manual didn't say that there were 2 oil drain plugs, just one. The big pain in the a** was that once you unscrew the HST Transmission filter, you need to unscrew the brake control to get it out of there. They could have made that easier. Also, the people at Tractor Supply don't know much so do you're research before you go. I have to send half the stuff back.
  5. #15
    Join Date
    Jun 2004
    Posts
    1,759
    Northeast MA
    Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
    Quote Originally Posted by kozman View Post
    2. Added "rare earth" (neodymium) magnets to the all the drain plugs. Rare earth magnets are much stronger than then conventional household magnets. Plus they don't lose as much holding strength with temperature.
    3. Added "rare earth magnets to the various filters.
    Thanks for the info. I'm new at this so what are the magnets for anyway?
    I didn't see this answered yet - the magnets are to capture any metal filings or shavings that might end up in the oil to lessen the chance that they get pulled back into the engine. It shouldn't happen anyway because the filter should catch them - but better safe than sorry.
    I'm coming up on the 50 hour service on my B3200 also - I think I'm at 44 hours right now so it might be next weekend. Is putting synthetic oil (like Mobil1 ) - worth it? I've always used Mobil1 in all my cars and I put it in my BX23 when I had that too.
  6. #16
    Join Date
    Nov 2007
    Posts
    753
    PA
    Kubota L3130 HST 4x4
    Sorry I didn't provide an answer to your question, but Jim_wilson has it covered. There are times when the machining chips are not adequately cleaned during manufacturing and resulted in some ugly contamination issues. Below are several pictures I copied from this site to give you an idea what could happen. I like modifying the drain plugs to accept the powerful magnets for visual reference when changing the fluids.
    Examples from other threads:
    Kubota B3200HST 50 Hour Service-metal-shavings-01-jpg Kubota B3200HST 50 Hour Service-metal-shavings-02-jpg
    Kubota L3130 HST 4x4, FEL LA723 w/QA and BH90 Backhoe
    Kubota L4740-3 Cab, HST, FEL w/Heavy duty bucket w/cutting edge
    Snow Blower: L2185 72" front mount w/hyd rotation and electric chute, 7' back blade, carry all, 48" Pallet Forks w/QA, Sun Shade, Turf tires & Rubber Chains for the winter, Extra forward and rear lighting. BearCat 73454 Wood Chipper. LandPride RCR2672 Rotary Cutter. Ballast Box Approximately 390 hours on L3130
  7. #17
    Join Date
    Jun 2004
    Posts
    1,759
    Northeast MA
    Quote Originally Posted by moship View Post
    Where did you get the magnets that you used? I'm going to have to do the 50 hour service on my tractor shortly and it would be a good opportunity to add them.
  8. #18
    Join Date
    Nov 2007
    Posts
    753
    PA
    I bought them at a local hardware store, but it is more like hardware stores of 20 years ago when they actually carried useful items. Below is a picture of the ones I bought. They can be had in a variety of diameters and thickness. Perhaps a local hobby or craft store might carry them. These magnets are incredibly strong.
    Kubota B3200HST 50 Hour Service-img_0459-jpg
    Here is one example of where they can be purchased online. K&J Magnetics - Strong Neodymium Magnets, Rare Earth Magnets
Similar Threads
  1. Kubota B2920 50 hour service
    By Davebota in forum Parts/Repairs
    Last Post: 11-11-2012, 12:22 AM
  2. 50 Hour service on my Kubota 500
    By JimmyJ321 in forum ATVs & Utility Vehicles
    Last Post: 10-23-2012, 10:45 PM
  3. 50 hour service for Kubota b7510
    By jkm in forum Kubota Owning/Operating
    Last Post: 05-31-2007, 10:34 PM
  4. 50 hour service-Kubota or Amsoil?
    By longears1 in forum Kubota Owning/Operating
    Last Post: 11-10-2004, 08:27 PM
  5. Kubota BX 50 Hour Service Question
    By Junkman in forum Kubota Owning/Operating
    Last Post: 04-11-2004, 10:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
