Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Jan 2012
    Posts
    16
    Iowa
    63-64 Ford 4000
    Default Ford 4000 and Dearborn Cultivator
    Hello
    I am hoping to use a cultivator for food plot soil prep. The unit i have access to is a Dearborn cultivator about 7 feet wide. How will my 1963 ford 4000 (gas) pull it? Soils have some clay content. I am hoping this implement will let me work faster than my 3 bottom plow. Any advice is welcome.
    Thank you.
    Attached Thumbnails Attached Thumbnails Ford 4000 and Dearborn Cultivator-image-jpg
  2. #2
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    17,898
    Missouri
    Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
    Default Re: Ford 4000 and Dearborn Cultivator
    I've never saw one of those. As I read your post I thought you were talking about a cultivator designed to do light soil tillage between planted rows. It appears this is designed to do heavy tillage in unworked soil. Can't tell what the shanks look like from the pictures. If it's designed to do heavy tillage it'll hang back pretty hard. Good thing is all you have to do is lift it slightly and till shallower, then do a repeat pass at a deeper setting.
    I grew up around small Ford equipment and a later model Ford 4000 but never saw one of those before. If you get it out of the weeds and ground take another picture. I'd like to see the shanks better. Thanks and good luck!!!
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  3. #3
    Elite Member
    Join Date
    Jun 2012
    Posts
    4,057
    Waynesboro Va
    John Deere X310, JD LA 145
    We pulled one just like that with a ford jubilee, so you should have no problem pulling it. I am not sure you will be happy with the amount of soil it moves, and may want a disc instead.
  4. #4
    Join Date
    May 2006
    Posts
    17,898
    Missouri
    So Ed, is it designed to be used in plowed soil or can it rip untilled soil?? I'd still like to see the design of the shanks. Never too old to see/learn something new!!!
    If your Jubilee pulled it, his 4000 should do it with little trouble.
    Richard
  5. #5
    New Member
    Join Date
    Jan 2012
    Posts
    16
    Iowa
    63-64 Ford 4000
    Quote Originally Posted by Ed of all trades View Post
    Hi Ed,
    Do you think i wont like how much soil it moved because it will disturb too much or too little soil? I planned to start with the cultivator and finish with my disk and drag.
    Thanks for your reply.
  6. #6
    Join Date
    Sep 2006
    Posts
    108
    Kentucky
    Kubota L3400, JD 5220 & 5085E, MF 4243
    Here's your implement:
    DEARBORN FIELD CULTIVATOR FLYER
    If you don't try to bury the shanks, and aren't pulling up a lot of roots, you'll be fine.
    __________________________________________
    MF 4243, JD5220 & Kubota L3400 with all the fixin's.
    Truax FLXII 88
    PLANT NATIVE!
Similar Threads
  1. Dearborn Cultivator and Ford 4000 (gas)
    By shootercase in forum Attachments
    Last Post: 05-04-2013, 11:05 AM
  2. Ford Dearborn 101 plow coulters
    By eray1066 in forum Attachments
    Last Post: 04-15-2011, 03:27 PM
  3. Ford 850 and Dearborn Loader?
    By texasdan in forum Ford Vintage Tractors
    Last Post: 08-25-2010, 09:55 AM
  4. 13 2A dearborn cultivator
    By Neil L in forum Attachments
    Last Post: 03-30-2009, 09:38 PM
  5. Anyone use a Dearborn loader on their Ford 8N/9N
    By jgbanshee in forum Ford Vintage Tractors
    Last Post: 03-22-2005, 02:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
