Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Jan 2012
    Posts
    115
    Montross Virginia
    New Holland TC26DA
    Default Wheel Spacers?
    Anyone use wheel spacers on their TC26DA. The tractor is only 4 feet wide and quite tippy on side slopes.
    I am thinking that a 2 or 3 inch extension on each side would help? Anyone with experience with them?
    Next question of course is where to get them at a reasonable price.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Platinum Member Deere Dude's Avatar
    Join Date
    Feb 2011
    Posts
    879
    Fox Lake, WI
    John Deere 3720
    Default Re: Wheel Spacers?
    I don't know your tractor, but I have a JD 3720 and was "seeminly" tippy. I put a couple 2" spacers on each side and put fluid in the tires and it made all the difference in the world to me. I got them from Skid Steer Solutions and they cost around $350 or so for 4 spacers. They have salesmen that could help you with the exact one you need.
    3720, Frontier 6' BB; 6' Rear Blade.; Loaded tires and Ballast Box; Dirt Scoop.
    X740; 62" Deck; w/47" Snoblower; 42" Hydraulic Tiller.
    54" Front blade; 48" Belly Blade
  4. #3
    Join Date
    Jan 2012
    Posts
    115
    Montross Virginia
    New Holland TC26DA
    Thanks for the info Deer Dude. I already have filled tires and it helps some. My manual also says I should have about 460 pounds of ballast on the back. Guess I need to build a ballast box. My manual also says to not put any sort of spacer on the front tires or even reverse the wheels as it may damage the axle or other parts. I checked Skid Steer and they sell spacers in sets of four. I will only need two for the back. Also their web site didn't indicate that they had anything to fit the New Holland CUT. $350 is a bit rich for me for two spacers.
  5. #4
    Join Date
    Feb 2011
    Posts
    879
    Fox Lake, WI
    John Deere 3720
    Quote Originally Posted by caps View Post
    How steep is the hill if I might ask?
    I wouldn't put spacers in the front and I haven't hear of anybody that does, but I would keep looking for 2" spacers for the rear. Wheel Hub Extensions - Unverferth Wheel Products may have something but I think they are expensive. Wheel weights would help obviously but they are expensive also but that would be my next solution.
    I tried reversing my wheels and a lot of people do that, but I noticed my wheels had dimples of some sort that would butt up against the hub so the wheel would not fit flat against the hub without ruining something, so I couldn't reverse mine without damaging the wheel either.
    A weight box would help for FEL work and they are cheap to buy or build but I don't know how effective they would be for side way tippiness. It seems the center of gravity would not be lowered much for the whole tractor with a weight box.
  6. #5
    Advertiser MotorsportTech's Avatar
    Join Date
    Sep 2011
    Posts
    20
    Hey Caps,
    We're a new sponsor on the forum here and we manufacture custom wheel spacers. Do you still need some?
    Motorsport Tech
    775-351-1000
    www.Motorsport-Tech.com
    Like us on facebook! for deals, sales and news.
  7. #6
    Join Date
    Jan 2012
    Posts
    115
    Montross Virginia
    New Holland TC26DA
    deere Dude,
    My whole property is pretty hilly. Nothing but swales and ravines. One hill that I cut drops 6 feet over a 15 foot distance. Even going straight up and down is a bit frightening.
  8. #7
    Join Date
    Jan 2012
    Posts
    115
    Montross Virginia
    New Holland TC26DA
    I may but haven't decided yet. Just this morning I was talking to one of my neighbors who owns several tractors spread out over a couple farms. He told me to get rid of the tractor before I kill myself. He suggested that I get one of the utility type four wheelers or a smaller subcompact/garden tractor with a mid mounted mower deck. I bought the tractor because I had three jobs that I wanted to do with it. (and I always wanted one anyhow and the price was right). I have completed two of the jobs and was told by the county that I couldn't do the other one. I wanted to put a road thru the property down to the lake at the bottom of the hill. Add a walkway and then a pier. County says I can't put anything within 100 foot of the water that disturbs the land. Its a wetland and I could only put an elevated walk way to a floating pier but no road. I did bookmark your website so I will check it out if I decide to go with the spacers.
    Thanks,
    john
  9. #8
    Join Date
    Sep 2011
    Posts
    20
    Hey John,
    We'll be here! Good luck on your projects!
    Motorsport Tech
    775-351-1000
  10. #9
    New Member
    Join Date
    Nov 2010
    Posts
    7
    motorsports your web site does not load
  11. #10
    Silver Member kentuckydiesel's Avatar
    Join Date
    May 2004
    Posts
    133
    Caps,
    My grandfather used to have a little mfwd ford with a mid-mount mower back in the late 80's through the 90's. He got some wide turf tires put on it and went all over his property (which was at least as hilly as yours).
    Go talk to your dealer...tell them the tractor isn't stable enough. I'm sure they can handle this issue. If your tractor really can't handle a wider stance, I would trade it in and get something built better. Tractors have had adjustable wheels/axles almost since the day they were invented.
    -Phillip
    SPIDER TRACTOR: '95 John Deere 5200 MFWD making around 60hp--12.4-24 8ply Goodyear R1 front tires--18.4-26 10ply Goodyear R2 fluid filled rear tires--Tires are set 8' 2" wide for maximum stability on hills--540 Loader with forks and custom fabricated bucket.
Similar Threads
  1. Traction GC Chains, Wheel Weights, Wheel Spacers
    By FDuce in forum Massey Ferguson Owning/Operating
    Last Post: 12-18-2010, 10:23 AM
  2. Where can I get wheel spacers
    By Smoody in forum Yanmar
    Last Post: 10-06-2009, 04:17 PM
  3. bx 24 wheel spacers
    By hdbear in forum Kubota Owning/Operating
    Last Post: 07-22-2009, 06:00 PM
  4. WHEEL SPACERS?
    By Coastline in forum ATVs & Utility Vehicles
    Last Post: 01-19-2008, 05:35 AM
  5. Wheel spacers
    By bswole in forum Kubota Owning/Operating
    Last Post: 10-27-2004, 07:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
