Results 1 to 7 of 7
  1. #1
    Join Date
    Jun 2010
    Posts
    193
    N. Mississippi
    Ford 1510
    Default 2 questions on a Ford 1510
    Well OK, one is about the tractor and the other is about my finish mower. First, the tractor. One of my headlights is dim while the other is bright. I removed the dim one to get a replacement and I began wondering if maybe there was a different kind of bulb in each headlight. I took the good one apart and as I removed the bulb from the lens assembly it just turned to powder in my hand It's the part that the bulb gets rotated into and now it won't latch back up in the housing because the fins that lock it in disintegrated. So, I'm wondering if I can get just the base that the bulb screws into, or if I have to get a whole new headlight assembly?Does anyone know? I also need 2 bulbs for it (I want a spare) and I can't find anything like them out online. If anyone knows of a source for any of these items I'd appreciate it. I've put a picture of the headlight assembly below.
    Secondly, I have a finish mower and sometime last season one of the rectangular lock pins that held one of the wheels on got lost and the wheel came off. When it came off, so did one of the spacers that went between the lock pin and thecylinder on the mower housing that the wheel shaft went through. Again, I've included a photo of one of the ones that I still have. I don't really know where to come up with one of those either although I can probably find something but if someone knows where a replacement one might be, I'd be interested in that as well.
    Thanks,
    Mike
    Attached Thumbnails Attached Thumbnails 2 questions on a Ford 1510-1510-headlight.jpg   2 questions on a Ford 1510-finish-mower.jpg
    ___________________________
    1986 Ford 1510
    5' Bushhog (no name version)
    5' Finish Mower
    26 gal Femco 12v trailer sprayer
    2000 52" Great Dane Surfer (18hp Kohler Command)
    ________________________________
    “Being a wealthy redneck has its advantages...”
    Willie Robertson, CEO Duck Commander
    The decisions you make will determine whether you win... or lose.
  2. #2
    Bronze Member Hiltz's Avatar
    Join Date
    May 2009
    Posts
    77
    Michigan
    JD 790
    Default Re: 2 questions on a Ford 1510
    Quote Originally Posted by MikeA57 View Post
    Thanks,
    Mike
    I would find a shop manual ( try ebay) for the part number for your lights and socket. I would think any Tractor Supply store would have spacers or could get them for you. Hope this helps
  3. #3
    Join Date
    Jun 2006
    Posts
    690
    Northern Alabama
    2012 Kioti DK45SE, 1994 JD LX176
    A friend of mine has a Land Pride finish mower, and his lost some wheels once as well. Had to get new spacers from the local dealer.
  4. #4
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    6,262
    Eastern NY
    Case 885, JD 730D, Oliver 660 Ford 4000
    Those fender mounted headlamps are notorious for poor ground connections. Check connections at the lamp, and clean the metal where the fender bolts to the chassis.
    If you can read this, thank a teacher.
    If you are reading this in English, thank a veteran.
  5. #5
    Join Date
    Jun 2010
    Posts
    193
    N. Mississippi
    Ford 1510
    Quote Originally Posted by RickB View Post
    Ahhhhhhh, good point. I'll bet that it is it. I'll check that.
    Thanks!
    1986 Ford 1510
    5' Finish Mower
  6. #6
    Gold Member
    Join Date
    Apr 2011
    Posts
    488
    The spacers can be made by cutting a short piece of pipe with the same I.D. I had problems with the fender lights on my 1710, that appear to be the same as your lights. I ended that headache by removing them, and mounting the rubber mounted utility lights that just have a positive wire. They work great.
  7. #7
    New Member Harlan Bilbrey's Avatar
    Join Date
    Nov 2010
    Posts
    16
    Dover, OH
    Ford 1510 MFWD
    My bulb was burned out, then I had the same problem RickB mnetioned. And cured it the same way. I wound up getting the bulb from a NH dealer. Looked like really good quality.
Similar Threads
  1. Ford 1510 help new owner please
    By Chris 1510 in forum New Holland Owning/Operating
    Last Post: 02-28-2013, 03:59 PM
  2. FORD 1510
    By freddinm in forum New Holland Owning/Operating
    Last Post: 10-24-2012, 02:52 PM
  3. Ford 1510 smoking
    By double hunter in forum New Holland Owning/Operating
    Last Post: 10-03-2012, 12:50 PM
  4. A few questions about Ford 1510 tractor
    By MCross in forum New Holland Owning/Operating
    Last Post: 08-01-2011, 10:03 AM
  5. 1510 Ford
    By Arkhermit in forum Parts/Repairs
    Last Post: 10-30-2010, 09:31 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
