Page 9 of 9 FirstFirst ... 6789
Results 81 to 84 of 84
  1. #81
    Join Date
    Aug 2005
    Posts
    203
    Eastern KS
    JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
    Default Re: mowing with the bucket on/off
    Quote Originally Posted by Creamer View Post
    I can attest that it is quite a jolt hitting something with the blade pushing backwards but I still do it because sometimes it just works better. Sometimes it is better to go forward using the blade at an angle. Where you are at in Eastern KS you should not have a traction problem. I only have one when the snow gets to deep and I have turf tires on the rear.
    We have some 6-12" snows at times. Generally 3-6". I have the R4 tires.
    I envision running fwd -- blade at an angle -- drive atop the snow before I push it off with the blade. I have this idea that if that all works, I can clear he driveway in an hour.
  2. #82
    Elite Member
    Join Date
    Feb 2012
    Posts
    3,759
    NE Indiana
    1710 Ford, Versatile 150
    My driveway is about 1/4 mile long and then I have about a 7000 sq ft area in front of the garage that I clean off. 1/2 hour tops unless the snow is so deep that I have to do a lot moving snow so that I have a place to put the new stuff. This will be real rare where you are at but there are times when we get buildup in Northern Indiana. I warn you though that with my turf tires I do a lot of plowing in road gear with a lot of spinning - technique vs power. It is a lot of fun - especially the donut at the end when I do a 180 to come back. Much quicker than a regular turn!
  3. #83
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,681
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    Default
    I recently did some woods mowing and for the first time I removed my FEL for mowing, mostly because of this thread. I did like how much more maneuverable it was in the woods but I didn't like how I could easily ride a wheelie going up any sort if incline! Actually, I suppose it was pretty fun the first couple times but got old when I couldn't steer. I had to use the split brakes more than a few times to get the nose around in a sharp turn.
    I did miss having the grapple on though when I came across some downed trees and couldn't move them out of the way. All in all though, the maneuverability sure was nice.
    Attached Thumbnails Attached Thumbnails mowing with the bucket on/off-image-2749959467-jpg   mowing with the bucket on/off-image-1253848524-jpg
  4. #84
    Platinum Member TerryR's Avatar
    Join Date
    Jan 2009
    Posts
    585
    Boone, NC
    JD 870
    Quote Originally Posted by coloradotrout View Post
    I have a JD 870, a bit heavier than yours, and find it works fine running forward with as much as 8," and our snow is pretty wet often. I found it works best to maintain some speed to be sure the snow rolls off the blade. Drive too slowly and it can build up under the rear of the tractor and actually lift it enough to loose traction. Then it's shovel time.
    Our driveway is a quarter mile, but steep enough that I can only plow downhill, so spend half the time dead-heading back to the top. Still, with a parking area to fuss with, I can still do it in less than an hour except for the few times the drifts are so deep I have to use the FEL, which takes a lot longer.
    Terry
Similar Threads
  1. Replies: 2
    Last Post: 03-15-2017, 10:45 AM
  2. Best Bucket or Bucket/Grapple Combo for Picking Up Firewood Splits
    By My Hoe in forum Kubota Owning/Operating
    Last Post: 08-05-2012, 10:32 PM
  3. Loader JD1070 w/80 Bucket - Can I reverse bucket dump control movement??
    By davefr in forum John Deere Owning/Operating
    Last Post: 10-19-2011, 08:56 PM
  4. Quick attach bucket vs Heavy duty rd. back bucket?
    By willy1947 in forum Kubota Owning/Operating
    Last Post: 06-10-2004, 02:24 PM
  5. 7308 FEL, standard bucket vs heavy duty bucket
    By Mosey in forum New Holland Owning/Operating
    Last Post: 10-11-2003, 11:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
