Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Aug 2012
    Posts
    9
    Bark River, MI
    Cub Cadet 7264
    Default 3pt mower preference question
    I am looking into possibly purchasing a John Deere 272 3pt finishing mower and I'm not sure if I like the idea of no wheels in the front. I have always seen the finishing mowers with 4 tires on them but not just the 2 in the back. Is there a reason (cutting or mowing) that they have mostly all gone to the 4? Should I look for the 4 wheeled type?
    What are your opinions?
  2. #2
    Join Date
    Mar 2013
    Posts
    108
    arkansas
    workmaster 45
    Default Re: 3pt mower preference question
    my next door neighbor had a john deere with just 2 gauge wheels in the rear and he hated it. good luck -ray
  3. #3
    Elite Member
    Join Date
    Sep 2009
    Posts
    2,681
    Up State S.C.
    AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
    My brother said he had problems using a shreader because his 3pt hitch drifts down. I believe he also said the 4 gauage wheels prevented this problem with the finish mower.
  4. #4
    Elite Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    4,967
    Detroit, Michigan
    Massey Ferguson 241, Case 580 Super M Series 2, Cat D3B
    I don't like the idea of just 2 wheels. You want a finish mower to follow the ground, not how the tractor is moving. There are times when the tractor is moving up, and the mower is still level, or maybe moving down. If the mower has four wheels, it follows the ground, giving you an even cut. If you have only two wheels, the front of the mower will pull up with the tractor, and you won't cut anything. If you run a brush hog for any length of time, you'll see how that can happen, because they usually only have rear wheels.
    The other thing is that with only two wheels, you're constantly adjusting the 3pt height to match the ground contour. With four wheels, you drop the mower, and that's it....it already follows the ground contour.
  5. #5
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,204
    Central Ohio
    Kubota MX5100
    I had a JD 261 mower with only the two gauge wheels. It was a great mower. But it all depends on your terrain. They dont do well on a rolling property with lots of little "knolls". But mostly flat and or a flatish hillside, they are great.
    I did use check chains though. Attached to the front of the mower and up to the tractor. That allowed you to just lower the 3PH lever and forget about it. Those mowers also have the swinging toplink mount, so it does follow the ground a little. If its in good shape, $600 or so is a fair price. Any less and its a heck of a deal IMO. Any more.....judgement call.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  6. #6
    New Member
    Join Date
    Aug 2012
    Posts
    9
    Bark River, MI
    Cub Cadet 7264
    Thanks for your input. That's what I was thinking about the 2vs4 wheels. I don't really want to depend I the tractor keeping a set hight and have to avoid scalping or raising the mower because of the terrain. $600 would be a great price. This one has seen very little use and the asking price is $1,600. Which happens to be a ballpark price for what I've seen.
  7. #7
    Join Date
    Apr 2008
    Posts
    18,204
    Central Ohio
    Kubota MX5100
    Wrong time of year to buy a mower. But thats why I said judgement call. I believe they made those mowers for quite some time. So it could be 25 years old, or just a few years old. If it is a newer one, and looks like new, then maybe $1600 is justifiable.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  8. #8
    Veteran Member chim's Avatar
    Join Date
    Apr 2002
    Posts
    2,373
    Lancaster County, PA
    Kubota L3200, Ford 1210
    I haven't had any Deere mowers, but do like the 4-wheeled RFM's because they mow without scalping on uneven ground.
  9. #9
    Join Date
    Jul 2011
    Posts
    105
    Billings, MT
    kubota L3400, Farmall 'A', Farmall F-14, Ford 860, JD 4520
    A finish mower with only 2 wheels? Yeah, I would have to pass on that. I would imagine that if you bought it at the right price then there is a chance that a person could modify it and add 2 more wheels to it. A big chance of course. I bought a used woods 72in mower that only had one season on it for $2500.00. I really hated to spend that kind of money for a mower but I have 2 seasons on it and am really happy with it and glad that I bought it.
    Steve
    3pt mower preference question-mower2-jpg
  10. #10
    Veteran Member MHarryE's Avatar
    Join Date
    Feb 2009
    Posts
    2,105
    Northeastern Minnesota
    Kubota M7-171, Kubota M110GX, IH 4386, IH1486, Case 301.8, Kubota L6060, plus many others
    Default
    My finish mower has the usual 4 wheels and an anti-scalp roller in mid-front. I consider this a minimum.
    Kubota M7-171, L6060, RTV 900XT, GR2120
Similar Threads
  1. Replies: 15
    Last Post: 05-13-2013, 03:10 PM
  2. Third Function Preference
    By mangus580 in forum Hydraulics
    Last Post: 01-14-2013, 06:39 PM
  3. Is this a scam? Vineyard preference?
    By ffgoo in forum Kubota Buying/Pricing
    Last Post: 05-14-2012, 10:20 AM
  4. HST pedal preference
    By bill177 in forum Massey Ferguson Owning/Operating
    Last Post: 07-29-2008, 05:40 AM
  5. ? Tire preference ?
    By GerardC in forum Kioti Buying/Pricing
    Last Post: 03-14-2004, 11:40 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
