Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Feb 2013
    Posts
    18
    lyons ny
    deere
    Default Transporting Batwing Mower
    I am won a mowing contract and am renting a batwing 16' mower and also a 80-100 hp tractor. I'm mowing 170 acres. I have a newer 1 ton truck but none of my trailers are setup to haul the tractor so I may hire it out. About 50 miles one way for the tractor- about 30 miles one way for the mower.
    It depends on which tractor the dealer will have on the lot to rent if I will haul it myself. I'd like something on the lighter end and no cab is needed since I hope to only be mowing for about 4 days.
    I don't plan on hauling tractor and mower together
    How much does a 16' mower weight? How narrow are they folded up?. I've only used 6 ft bush hogs before never a batwing. Could I pull the mower down the road behind my truck, or will it be too much weight for my truck and tow hard? If the tractor isn't at the same rental place as the mower, how would the mower be loaded/ unloaded? The rental place may have way of loading it, but then how would I unload at my location? I don't think the tractor will have a loader as it's not needed( or maybe now it will be)
    I called mower rental place and they said I could tow it behind my pickup, which seems to be my only option right now
    thanks for your help
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Transporting Batwing Mower
    Transporting Batwing Mower-jdmower-jpgi've moved a 15' jd151 batwong mower on a 16' car hauler before.
    we folde dhte deck and backed it on.
    if i had to do it over again.. I'd just have pulled the ball on my truck and use dhte drawbar for m the mower with a pin.. like the tractor pulls it and roaded it..e tc.
    to guess on width.. 1/3 times total width.. plus a lil. if you guess 6' for the center panel and a lil deck fold overhand on ech side i think you will be fine.
    i didn't think i had a pic of the mower ont he trailer.. but i found one.
  3. #3
    Join Date
    Nov 2012
    Posts
    1,530
    mansfield,Il
    john deere
    Quote Originally Posted by Soundguy View Post
    You alright there old buddy?
  4. #4
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    Quote Originally Posted by kevin37b View Post
    not sure what you are asking?
  5. #5
    Veteran Member kneedeep's Avatar
    Join Date
    Apr 2012
    Posts
    1,068
    Central AL & MS Delta
    Mahindra 3510 and Mahindra 8560 Cab 4WD
    Looks like you were fat fingering the keyboard or having a mild stroke (SP) !!
    PROUD AIR FORCE DAD
  6. #6
    Join Date
    Mar 2010
    Posts
    2,110
    There is a chart someplace on here that gives you your mowing times. you might want to look it over as I do not believe 4 days is going to get it done.
  7. #7
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    Quote Originally Posted by kneedeep View Post
    i type on a tablet pc.. i've mentioned this multiple times
    are we down to bring up spelling errors?
    i'm outta this thread. try to help and people piss and moan.
    later.
  8. #8
    Join Date
    Nov 2012
    Posts
    1,530
    mansfield,Il
    john deere
    Just a little funnin there , sorry to upset ya .
  9. #9
    Veteran Member D7E's Avatar
    Join Date
    May 2006
    Posts
    2,251
    manitoba
    Many
    Quote Originally Posted by firecatf7333 View Post
    If you wont be doing it often why not just drive it . Would only take 2 hours.
  10. #10
    Silver Member kentuckydiesel's Avatar
    Join Date
    May 2004
    Posts
    138
    later.
    Hmmm...massive overreaction.
    -Phillip
    SPIDER TRACTOR: '95 John Deere 5200 MFWD making around 60hp--12.4-24 8ply Goodyear R1 front tires--18.4-26 10ply Goodyear R2 fluid filled rear tires--Tires are set 8' 2" wide for maximum stability on hills--540 Loader with forks and custom fabricated bucket.
Similar Threads
  1. 15 foot batwing mower
    By johnvickl in forum Attachments
    Last Post: 08-04-2010, 03:24 PM
  2. woods batwing mower
    By m7040 in forum Attachments
    Last Post: 06-03-2010, 11:39 AM
  3. Advice on batwing mower.
    By radman1 in forum Ag Tractors & Machinery
    Last Post: 01-23-2009, 12:23 PM
  4. Batwing mower suggestions
    By Slippy in forum Attachments
    Last Post: 05-11-2007, 04:22 PM
  5. Tow behind batwing mower
    By Mith in forum General Lawn & Garden
    Last Post: 11-18-2006, 10:39 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
