Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Join Date
    Jul 2002
    Posts
    73
    Alabama
    JD4710
    Default Help with trailer decision .............
    Have a JD 4710 with 460FEL and 48BH. Tow rig is a 2500HD GMC. Looking at either a 16 foot Big Tex gooseneck dump or 24 foot gooseneck flatbed. The tractor with the hoe mounted and FEL resting on the gooseneck should fit inside the dump. With the MX6 rotary cutter instead of the hoe it should hang about 4' off the back. According to Alabama public safety office the 4' hanging off is okay as long as it is lit and/or flagged appropriately (guy at the trailer place said it was illegal - not sure who is right.
    I've searched the site and read a lot about both types of trailers. Basically on the fence and need to get pushed off one side. Would like a 20 foot gooseneck dump flatbed (or drop sided) but cannot find anything like that in my area.
    Any advise is appreciated.
  2. #2
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Default Re: Help with trailer decision .............
    How much hauling of things that need a dump bed do you do? And what sort of materials? That would be the deciding factors I guess.
    Both are nice rigs, the flat bed is better than the dropped or dump bed because it can be easily loaded with a forklift with nothing in the way. And the fenders in a dropped bed pin you down to a maximum width with no leeway, guess that would be the same for the dump bed too.
    Can't say about the 4', it is not illegal here, but if 4' or more it needs a flag.
  3. #3
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,721
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    same question.. do you need the dump bed.
    if dumping is a 'MUST' then that pins you.
    I know I can't really haul my old ford 850 tractor with a light duty loader and a woods 6500 hoe on a 16' flatbed. puts all the weight in the wrong place for bumperpull. if it were gn.. it might make a significan't difference.
    on the other hand.. i really like my flatbed gn. as other sated.. no fenders inthe way. easy to load with a laoder or forklift. but it don't dump.....
    weigh your needs.
  4. #4
    Veteran Member kneedeep's Avatar
    Join Date
    Apr 2012
    Posts
    1,076
    Central AL & MS Delta
    Mahindra 3510 and Mahindra 8560 Cab 4WD
    I have a Betterbuilt 22' Bumper pull that was built to my specs. The plant is in Double Springs, Al and they are good people to do business with. They will build any type of trailer you want.
    I would recommend at least talking to them about a custom trailer.
    I only move the TLB from the farm to home and some personal heavy hauling. I have a lot of money in my tractor and I want to move it safely with a good trailer that meets my needs.
    http://www.betterbuilttrailers.com
    Help with trailer decision .............-4-11-13-backhoe-1-a
    PROUD AIR FORCE DAD
  5. #5
    Elite Member Rustyiron's Avatar
    Join Date
    Mar 2011
    Posts
    4,211
    Lakes Region, Maine
    M 9540 Kubota
    I think a lot of guy's think that they'll have a dump truck when they get a dump trlr. If your planning on hauling gravel or dirt, a dump trlr/pu tk can realistly only haul a meaningless load of either. They are great for mulch, clean up jobs, or even a small load of logs, but a 5 ton pile of gravel (depending on your job) is a suprisingly small pile! My 2cents says hire a real truck when you need it and go for the deck over.
    I also had a Betterbuilt GN deckover, it was a good trlr.
  6. #6
    Join Date
    Jul 2002
    Posts
    73
    Alabama
    JD4710
    My only "must" would be the ability to transport my tractor, the rest of the uses are just general trailer uses. Hauling larger items, moving duties, temp storage area, hauling limbs and debris, landscape material (mulch), etc...... dump ability is just handy for me since I'm getting older
  7. #7
    Join Date
    Mar 2011
    Posts
    4,211
    Lakes Region, Maine
    M 9540 Kubota
    10-4 on the dump, gravity is a good thing when applied properly!
  8. #8
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    If you have stake pockets on the flatbed, you can put sides on it for hauling some of that stuff. And some things don't dump as well as I think they ought to either.
    I had a load of composted horse manure in my 1-ton dump and it just wasn't moving. I ended up pulling it down with the FEL bucket as much as I could. It was pretty damp/wet, I think that's why it was clinging.
    Things like stone pour off from the top and back of the load, and other things don't move unless the whole load slides. So, there is some physics/material science involved.
  9. #9
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,917
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    I found the perfect trailer for me, 4' pop-up dove tail, 5' dovetails tend to drag a lot.
    For hauling square hay bales, ramps make a back stop.
    Help with trailer decision .............-p9062364-jpg
    For round bales, leave the deck down and ramps hold the last one or two in place.
    Help with trailer decision .............-p7310009-jpg
    For equipment, ramps slide in to match tread width, and support the rear when driving up on them.
    Help with trailer decision .............-p9062369-jpg Help with trailer decision .............-pc190002-jpg
    I ordered it with the receiver hitch and wiring to pull another trailer behind it.
  10. #10
    Gold Member Bigkrank's Avatar
    Join Date
    Jan 2009
    Posts
    322
    NW Ohio
    I know this guy will build equipment trailers that can dump almost as high as a dump trailer. Saw some of his stuff couple years ago, looked good.
    Ron's Trailers, Inc. 419-691-RONS(7667)
    Several garden tractor pullers
    Kubota B2630
    Kubota ZD1211
    Ford 655D backhoe
    Bobcat T190, various attachments
    Numerous Farmalls
Similar Threads
  1. Trailer Decision Help
    By Willie71 in forum Trailers & Transportation
    Last Post: 06-01-2010, 08:22 PM
  2. Big decision, HELP!
    By dieselram in forum Kubota Buying/Pricing
    Last Post: 06-12-2008, 10:39 PM
  3. Need bigtime help on trailer decision
    By LabLuvR in forum Trailers & Transportation
    Last Post: 03-24-2008, 10:05 AM
  4. Trailer Decision
    By Bellville in forum Trailers & Transportation
    Last Post: 04-15-2004, 03:48 PM
  5. Trailer Decision
    By Bellville in forum Owning/Operating
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
