Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 48
  1. #11
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: True Third Function- factory or do it myself
    paulwestski ,
    Logically, the 3ed function should be after the FEL, so the FEL relief will protect the 3ed function operation.
    On your 3ed function kit installation, where is the relief valve for the 3ed function, before or after?
    Did they come off the hyd block and then to the 3ed function, and then to the FEL?
    Does your FEL valve have a relief valve, or is the tractor relief valve in the hyd block?
    If you 3ed function is before your FEL valve, if you activate the 3ed function, does it not shut off the flow to the rest of the implement hydraulics. Solenoid operation is usually full on or off, except for proportional solenoid circuitry.
    If the 3ed function valve is after the FEL valve, then if you are only using half lever on the FEL valve, there is fluid for the 3ed function.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  2. #12
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    17,638
    Missouri
    Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
    Quote Originally Posted by crazyal View Post
    Are you sure that the 3rd function is a true remote? For some reason I thought it wasn't so I was never really interested in adding one.
    My OEM 3rd function is simply a solenoid operated hydraulic valve that is plumbed using the PB from the loader valve assembly. In my opinion it's a true remote but maybe someone with more hydraulic savvy than I can answer that for sure.
    It's definitely not a diverter valve setup which I wasn't interested in having. When shopping for my tractor I looked at a NH T4050. One thing I didn't like was that they use a diverter valve to operate their 3rd function thru the bucket tip circuit.
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  3. #13
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    If there is a 3ed function, where is the first and second function?
    Is it just an extra circuit, and is it self protecting.
    Is there a forth function, and so on down the line?
    J.J.
    Git er done.
  4. #14
    Advertiser EverythingAttachments's Avatar
    Join Date
    Mar 2009
    Posts
    3,618
    Newton NC
    Which One do you want to know about?
    If anyone can solve it, you can J_J. Your posts quite often amaze me!
    Travis
    Ted Corriher
    www.EverythingAttachments.com
    1-866-581-5818
    A family-owned American Company that also sells quality Made in USA Implements every chance we get! We pride ourselves on giving good product information and putting the needs of our customers above our own!
  5. #15
    Join Date
    May 2006
    Posts
    17,638
    Missouri
    Quote Originally Posted by J_J View Post
    Knowing my hyrdaulic knowledge is lacking, I'll tackle these questions.
    In my case, first function is loader boom lift, second function is bucket curl. Then the PB of the loader valve is plumbed to the IN of the 3rd function valve. So as JJ described earlier, if I am not using 100% of the capacity of my tractor's system in the first two functions, there is flow leftover to cause action in the 3rd function. When I reach 100% flow capacity of the tractor, all flow beyond stops.
    Hmmmm,,, is it an extra circuit and self protected?? I'm gonna guess no on extra circuit, it's simply a continuation of the circuit supplying flow to my loader valve because it comes off the PB. Same with my rear remotes and 3pt, they too are continuations of the original circuit. With that I'd say my tractor only has one circuit. As for self protected,,, I'm gonna guess that it is not.
    As for fourth function and so on down the line. Yes. My tractor starts at the loader valve supplying boom lift and curl, then 3rd function, then rear remotes, then 3pt lift.
    How'd I do JJ??
    Richard
  6. #16
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    2,001
    Rochester, MN
    Kubota BX2230
    Default
    Quote Originally Posted by ovrszd View Post
    How'd I do JJ??
    I'm hydraulically challenged. Are you saying that if I have 2 remotes (fel, curl) that my 3ph basically is 3rd in line? And if I added a 3rd valve for either a grapple or something in the rear, that the 3ph then becomes 4th in line and so on? I would have guessed that the 3ph would be first in line because it is "right there" in the rear end. But it sounds like it is really last.
    Sent from my iPad using TractorByNet
  7. #17
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    RaydaKub
    Your 3pt is usually last valve in series and dumps into the hyd tank.
    J.J.
    Git er done.
  8. #18
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    How'd I do JJ??
    Don't know where the 3ed function came from or a definition for for the term.
    Although open center hyd circuits have all valves in series, they should always have a relief valve before any other hyd component after the pump.
    In a closed center hyd system, there is usually a single relief valve close by the pump, and the other hyd valve do not need a relief valve.
    If the 3ed function is first in line from the pump, I would say that it is not protected.
    If it comes off the hyd blk, there is usually a relief valve on the hyd block.
    I think of a a 3ed function as an extra circuit that can be used for just about anything, grapple, 4-1 bucket. etc.
    3ed function valves are also PB capable if the flow is available. .
    Sometimes the 3ed function may not have full pump flow, due to other valves/cyl using the hyd fluid.
    A 3ed function can be used independently of any other hyd circuit as long as there is an external relief valve before the 3ed function.
    I did find this excerpt for a CAT brochure.
    Auxiliary Hydraulics
    Auxiliary hydraulics provide
    unparalleled versatility allowing you to
    select the configuration that best suits
    your application. Third function only
    or packaged with fourth enables the use
    of almost all work tools. Fifth and sixth
    function hydraulics are also available
    for responsive independent positioning
    of work tools with multiple hydraulic
    cylinders such as snow plows with
    hydraulically movable snow wings
    J.J.
    Git er done.
  9. #19
    Gold Member paulwestski's Avatar
    Join Date
    Mar 2011
    Posts
    326
    VA Beach & Amherst, VA
    Kubota L4240
    paulwestski ,
    If the 3rd function valve is after the FEL valve, then if you are only using half lever on the FEL valve, there is fluid for the 3ed function.
    JJ
    I've been studying the parts diagrams for the kubota 3rd function and loader. The best I can determine is the 3rd function comes directly off of the Hydro pump and then feeds the loader valve, loader valve feeds the top cover of the transmission, which feeds both the rear remotes and the three point.
    What I really need is the installation manual for the Kubota 3rd function option.
    True Third Function- factory or do it myself-loader-hydro-lines-jpgTrue Third Function- factory or do it myself-3rd-function-hydro-lines-jpg
    Kubota L4240 HST+ R-4's,
  10. #20
    Join Date
    Mar 2011
    Posts
    326
    Kubota L4240
    JJ is the winner
    The hydraulic block included with the kubota 3rd function kit does contain a relief.
    Part 170 on the parts diagram.
    Lesson learned here...Pay attention all you workshop hydraulic engineers!!!!!
    What JJ said...the first valve off of the pump or Hydro block must have the pressure relief in it.
    When planning my home brew setup I did not consider this.
    I don't believe the valves offered at Surplus center have the pressure relief in the subplate.
Similar Threads
  1. Kubota L4240 Factory 3rd function Kit
    By Rockgod in forum Kubota Owning/Operating
    Last Post: 01-06-2018, 03:48 PM
  2. Replies: 27
    Last Post: 05-04-2013, 10:06 PM
  3. Kubota Factory 3rd Function Plumbing
    By crazyangel in forum Kubota Owning/Operating
    Last Post: 05-01-2013, 08:27 PM
  4. Loader help. grapple install. true 3rd function pics attached
    By hitman104 in forum New Holland Owning/Operating
    Last Post: 01-29-2012, 11:52 AM
  5. True Hyd. Third Function kit
    By deerhunterf350 in forum Build-It Yourself
    Last Post: 11-15-2006, 11:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
