Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 35
  1. #21
    Veteran Member fordmantpw's Avatar
    Join Date
    Mar 2013
    Posts
    1,995
    Central MO
    John Deere 2720
    Default Re: Blackberring clearing
    Quote Originally Posted by vabiker23518 View Post
    Wish I was closer, I'd come pick those tasty berries first!
    Yep!
    You could get a ratchet rake. It works well for clearing up messes like that. It would take a bit more time than the dozer, though.
  2. #22
    Veteran Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    Blackberries don't like to be mowed. Mow over them for a couple of years, and they'll disappear (except the inaccessible areas, of course).
    The small trees are another problem. It depends on what you wish to do with the field. If you wish to do hay, a dozer might be the best alternative. If you want it for pasture, perhaps try one of these tree grinders.
    The trees might come back quicker than the blackberries though.
    If you doze it, you will need to pile everything up and burn it. And, dirt & tree roots is a pain to deal with, although I've chopped the dirt out of half burnt rootballs and burnt them again... and again, until they finally disappeared.
  3. #23
    Elite Member
    Join Date
    Jun 2006
    Posts
    2,809
    West Cascades, Washington State USA
    PT 422
    I use my rough cut mower. It mounts on the front of my tractor on the FEL so make it real easy to see where im mowing and also mows a path for me to travel on. I cut maybe once a year depending on location and every other in others.
  4. #24
    Join Date
    Sep 2010
    Posts
    165
    Michigan
    Landini 85F Deere 5425 Ford 1920
    Hit 'em with Garlon. Come back a week later with the brush mower, and go slow.
    A flail chopper would work, but seeing as how you don't know exactly whats in the tangles, stick with the Brush mower.
    Replacing an inner tube here and there, or a Mower blade is cheap.
    Start mangling Flail hammers, and you're into more money than a new Brush mower.
    I get tempted to attack stumps with ours now and then, but a couple decades ago I watched the cousin attack one, and do a couple grand worth of damage in a few minuites...so the temptation is always brief.
  5. #25
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,923
    Northern Vermont
    Kubota, Case, Deere
    I use my dozer on them and then spread grass as soon as possible. But has anyone tried something like a Harley rake? It would be easier to transport than a dozer.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  6. #26
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,681
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    Default
    Quote Originally Posted by cqaigy2 View Post
    Could you give some details of this setup?
    Tractor size, how the mower works, mower size etc?
  7. #27
    Gold Member scaredychicken's Avatar
    Join Date
    Jul 2012
    Posts
    296
    Salmon Arm BC, Canada
    John Deere LT160, Arctic Cat 400 ATV
    My first thought was eat the berries, then Burn the overgrown bushes that are in the way. A controlled burn is probably the only way to do it effectively, and probably best done in the fall - so first step is to harvest what you can, and then beat them up with the tractor and equipment throughout the summer, finish them off with a hotdog roast in October. Blackberries (like Rhubarb) are best ONLY in the area that you want them in.
  8. #28
    Gold Member
    Join Date
    Sep 2009
    Posts
    335
    Western KY
    Kubota M6800 w/1600 hrs., Case Farmall 95 w/800 hrs., Long 2510 w/1100 hrs, Cat 236B2 Skidsteer w/1000 hrs
    Default
    I just finished cleaning up about 17 acres of trees & blackberries. I started out with my tractor & bush hog but ended up renting a brush cutter for my skid steer. All together I spent about 30 hours on it. I was able to cut all of the trees that were 3.5" diameter less.
    Blackberring clearing-forumrunner_20130619_064436-jpg
    Blackberring clearing-forumrunner_20130619_064603-jpg
    Blackberring clearing-forumrunner_20130619_064728-png
    Blackberring clearing-forumrunner_20130619_064806-jpg
  9. #29
    Elite Member
    Join Date
    Jun 2006
    Posts
    2,809
    PT 422
    Quote Originally Posted by Piston View Post
    Not wanting to hijack this thread so ill be brief. Power-Trac made in Tazewell VA. mine is a 22 horse, quick attach implements, mower is hydraulic 48" pretty stable on side hills, articulated so it's easy to get around trees and other obstructions which is the main reason i got one. I wouldn't want to try to plow a field with one.
  10. #30
    Member
    Join Date
    Feb 2007
    Posts
    47
    Well wanted to give an update with some pictures for everyone.... I ended up renting a dozer with a brush rake on the front.. It worked great. The dozer was a JD 450H (about 15k) so had to have it delivered. But there was not too much there to stop it.... Now I just need to figure out how to get rid of the brush pile (no burning at this location, in the urban growth boundary) :^(... I spend about 10 hours on site last Friday working on this. This fall I will keep it mowed down and try and plant grass for him...
    One funny part of the story, The first place I was going to rent from decided they did not want to rent to me because I was going to use it to clear blackberries... They did not want to scratch the dozer I wonder what you are suppose to use a brush rack for then?
    Anyway here are the after shots...
    Blackberring clearing-area-cleared-jpgBlackberring clearing-area-cleared2-jpgBlackberring clearing-dozer-jpgBlackberring clearing-pile-stuff-jpg
    The before shots just to compare...
    Blackberring clearing-photo-1-jpgBlackberring clearing-photo-jpg
Similar Threads
  1. Clearing Help
    By PForce in forum Land Clearing Equipment
    Last Post: 06-02-2012, 01:09 PM
  2. Clearing job
    By D7E in forum Land Clearing Equipment
    Last Post: 01-26-2010, 05:42 PM
  3. Clearing saw
    By Sideways in forum Build-It Yourself
    Last Post: 12-09-2009, 08:14 AM
  4. Clearing
    By dtd24 in forum Projects
    Last Post: 06-12-2007, 06:08 PM
  5. clearing
    By Kerrminator in forum Projects
    Last Post: 10-23-2006, 11:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
