Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default I almost made some scrap metal today
    I was pulling out some small trees this evening. I had a couple that would not come out with it hook the draw bar on the tractor. I got the draw bar for the 3PH and bent the thing. I never really gave it any thought. I know my neighbor uses a cat 1 draw bar his on his New Holland TL90 and t5040. If I would have had a anti rotation device I may have not bent it. I guess a draw bar is not meant to be used for pulling like that.
    It was out 1 9/16"
    I straightened it in the press. I don't know if it will be okay to use or not.
  2. #2
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    6,887
    Northern Vermont
    Kubota, Case, Deere
    Default Re: I almost made some scrap metal today
    After years of skidding logs my neighbors looks worse than that.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  3. #3
    Super Member
    Join Date
    Jul 2009
    Posts
    8,427
    SW WA
    Kubota BX2360
    Get one of these for your drawbar:
    I almost made some scrap metal today-243701d1325116223-hauling-logs-drawbar-hook
    Bruce
  4. #4
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    I have a clevis in the draw bar already. I just wanted to transfer some more weight to the back of the tractor to pull the trees out.
  5. #5
    Join Date
    Dec 2012
    Posts
    139
    wilmington, NC
    Kubota L3400
    Looks like you need to use the center draw bar for those hefty trees.
    I doubt pulling like that is very good for your lift arms with no support from the top link. I could be wrong though.
  6. #6
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,423
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    I have had different drawbars over the years, some are better than others. When I had my first dozer a Deere 450 with worn tracks years ago I remember using my 4020 with a horizontal drawbar to raise the side of the dozer to get the track back in place. Worked fine with no problems for a year or so, wound up with a new drawbar later and bent it like a pretzel.
  7. #7
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    17,932
    Central Ohio
    Kubota MX5100
    Yep, drawbars are not strong in that direction...
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  8. #8
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Quote Originally Posted by trktrman View Post
    It was in a quick hitch so it was supported by the top link.
  9. #9
    Super Member
    Join Date
    Feb 2011
    Posts
    8,975
    Virginia
    yes
    Default
    Quote Originally Posted by jenkinsph View Post
    This one is made in china.
  10. #10
    Join Date
    Feb 2013
    Posts
    647
    Thornville, Ohio
    No longer Searching. Mahindra 3016 Shuttle
    94BULLITT,
    That you were able to straighten it says it was fairly low grade steel as you suspect. Certainly not forged like in days past.
Similar Threads
  1. Newbee to metal fabrication with scrap Q's
    By LotsofGreenGrass in forum Build-It Yourself
    Last Post: 03-22-2011, 10:13 AM
  2. scrap metal on farm
    By hernando in forum Projects
    Last Post: 01-14-2008, 10:31 PM
  3. Where do you get your Scrap metal?
    By Iplayfarmer in forum Build-It Yourself
    Last Post: 07-09-2006, 08:23 PM
  4. Grapple,Scrap metal and etc.
    By sanman in forum Customization
    Last Post: 01-07-2005, 10:09 PM
  5. Scrap Metal Recycling
    By herdfan in forum Projects
    Last Post: 09-07-2004, 02:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
