Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Jul 2013
    Posts
    2
    okehampton, Devon
    john deere 2850 & a massie
    Default radio problems john deere 2850
    hi everyone,
    my latest problem that i am trying to fix is this.
    Recently we have had a young lad come to our farm to work, i told him to charge the battery of the tractor, he did so charging the battery on max and on the jump start setting all night then the next morning took the positive cable off but left the negitive on. the result was not pretty!. we tried for 3 day to ressurect the battery but in the end i had to go and buy two new batterys as both were dead.
    having gotten the new batterys i started it up where upon i discovered why my tractor is going through battery charge like no other. when it started i heard a static like noise ...terified that this was the battery i killed the ignition and checked to make sure i had hooked it up right all was fine. so started it up again, the static noise came again (please note that i only have 40% hearing in the one ear the other hears nothing) so after five min of locating the noise i discovered that the radio will not turn off and is slowly draining the battery.
    so here's my question, is it an somewhat easy and fairly straight forward job to disconnect the radio from the battery? (we long lost the antena so we never have the radio on its more of a decorational feature ;D) i could not locate a 'eject' button that allows me to remove the radio face (besides this will not solve the shorting out problem that is draining the batteries) , so it looks like a whole removal job with a screw driver and a pair of cutters which sounds a bit involved. Some advice and instruactions would be much appreaciated
    thanks
    p.s. i didnt know which forum to post this in sorry. :s
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,086
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: radio problems john deere 2850
    Not being familiar with a 2850 is radio mounted in the cab headliner with a grill such as in the parts photo from a 2950? If so remove 6 screws holding grill lower radio/grill to access elect connector plug.
    Attached Thumbnails Attached Thumbnails radio problems john deere 2850-cc3561_________un31aug98-gif
Similar Threads
  1. Security & Theft Radio stollen from a John Deere 650H. Need radio wiring diagram.
    By kenvc in forum John Deere Owning/Operating
    Last Post: 06-03-2013, 02:47 AM
  2. 4320 John Deere Radio Install
    By 1speedy77 in forum Parts/Repairs
    Last Post: 11-24-2012, 07:06 PM
  3. John Deere Radio wires
    By Nelson Farms in forum John Deere Owning/Operating
    Last Post: 05-29-2012, 10:44 PM
  4. John Deere Radio not keeping time.
    By Goalie in forum John Deere Owning/Operating
    Last Post: 07-18-2010, 09:49 AM
  5. want to add radio to new John Deere 5420
    By tootall in forum John Deere Owning/Operating
    Last Post: 10-11-2004, 10:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
